Any issues with 1.25" Body lift on auto trans?
| Great deals on Mickey Thompson Tires @ Jeephut.com | RCV Heavy Duty Axle Shafts Now Shipping at Baseline4x4.com | Poison Spyder Brawler Rockers! |
#1 | |
I've seen several threads about problem with shifter linkage on manual trans jeeps when doing a body lift. Is it any more or less of a problem with an automatic trans?
It's something I'm interested in but don't want to create new problems.
4.0L Auto. D30/D35 3.07 gears, 1.25" Spidertracks spacers, RC 2.5" lift, 1.25" BL, 32 x 11.5 x 15 BFG MT tires, Brown Dog 1" MML, M.O.R.E Bombproof MM Brackets, Big Daddy Tie Rod, KC Daylighters, Smittybuilt swing away spare tire- bumper, XRC8 Winch Also have 2006 WK Red Jeep Club #493 36,602 posts behind Jerry Bransford and getting further behind each day! |
#2 |
With the auto it has a cable to shift it into gear, You wont have to mess with it at all. Just the T-case linkage.
Couple TJ's and a XJ |
#3 |
x2. And the t-case shifter linkage adjustment is very straightforward. You may or may not need the bracket that comes with the JKS 1.25" BL, but wait until you have everything back together and try to shift, as you may be fine.
Trombino -- '04 TJ -- Rubicon Express 4.5" Superflex + 3/4" Front Spacers, OME Shocks, Currie Rear Shock Relocators, JKS 1.25" BL, JKS BMML, JKS Quicker Discos, 15x8 Cragar Soft 8's, 35x12.50 BFG KM's, LoD Heavy Duty Rear Tire Carrier, Chopped Front Bumper, Uniden 520XL w/ 3' Firestik II, Skyjacker Steering Box Skid, Rusty's Engine Skid, IPF H4 Conversion w/ Fatboys, Hella 500 Windshield Driving Lights, Tomken Gas Tank Skid, ARB Rock Sliders, PSC Rock Ring (D30), Riddler (D44), MV50 OBA, Rusty's Air Tube, TBS, Flowmaster 40, Dana 44 with Trac-Loc, Warn XD9000i w/ Grill Guard The Wife -- '02 KJ Limited -- Pre-Lowered, Full Mopar Skids, 245/70-16 General Grabber AT2's, Trac-Loc Rear, Flowmaster 50 SUV |
#4 |
Thanks. This helps me make my buildup plans
#5 |
98 TJ 32rh auto and no problems with my JKS 1.25" BL. No T-case adapter needed.
#6 | |
Not tryin to hijack but...
What if you have a t-case drop kit in?
2.5 Liter club memer #169-Red Jeep Club meber #491 Quote:
#7 |
You shouldn't have any problems at all with the t-case drop. All i did when i put the drop spacers in was spray some lubricant on the adjuster rod, Loosened it, And installed the spacers and sometimes all you have to do is go back and tighten it back up as it will slide with the drop, If not tighten it, get in and play around with the lever so you know which way it has to go. I set mine in the 2-hi position, I read some place you put in 4-lo, But i have never popped out of gear or had any odd grinding noises or being able to shift into 2-4-4 at any bind. Chances are, you wont have to mess with it.
#8 | |
Well, several times while wheelin at tellico I have shifted into 4L and put it in gear, it would slip out of 4 low and cause some kinda grinding noise. I have to cut the engine, shift the tcase into 2H and trans back to park then restart and try again. Sometime's Id have to back up or pull forward a bit to get it to stay in 4L.
#9 |
Was your jeep rolling slightly when you shifted to 4-lo? To get a good transition to 4-lo, You should have it rolling a little and you will hear the gears crunch together which makes a good connection and wont pop out of gear. Id try an adjustment to be sure, When in 4-lo, Your shift lever should not be resting far back against the stop, It should have a sweet spot between t-case neutral and low. Sounds like it was just bound from an obstacle and wouldn't engage all the way, If it happens again, Put your T-case and tranny in neutral, Let it roll and pull back to try and see if its just a binding issue. If it is, AA has a bracket that mounts on the T-case and is well worth the money.
#10 |
I just added a 1.25" bl to my auto tj and I can't get it into 4low, rolling, stopped, rubbing my stomach and patting my head at the same time, nothing works. It wont even go up into neutral. I put the linkage bracket on and I am not running a t-case drop on my rc 2.5" kit. Any ideas?
Blue Jeep Club Member #151 Arizona Jeep Club Founder |
#11 |
you might need to notch the bracket? i notched mine, its shift better than stock
FOR SALE:SOLD 2000 TJ 2.5" CLAYTON L.A. W/HYDROS, SYE/XJ SHAFT, 4:10 GEARS, 8.8 MINI SPOOLED, LOC-RIGHT FRONT, 1" BODY LIFT, 1" MML, 35" MAXXIS BIGHORNS, RE GEN 2DISCOs, BELLY UP, ALCOS IN FRONT, WARN X8000I |
#12 |
04 TJ auto No problems with the jks 1.25 BL . Stefanwlsh take a look at you linkage If it dont look level or close to try the others holes in the bracket . + you still have to adjust the adjustment bolt .
#13 |
Novak shifter bracket.
2006 LJ Rubicon |
#14 |
Well I didn't have any trouble out of my auto transmission but when I tried to remove the 4 bolts to the Tc bracket connected to the jeep body every rubber grommet broke on all 4 bolts. I bought the AA adapter instead of putting the crappy stock bracket back on. The AA bracket works great.
#15 |
Do it right or not at all
![]() Join Date: Jan 2003
Novak's shifter is the entire shifter, it's not just a bracket. Mine has been a disappointment, especially in view of the PITA installation process. I'm not real happy with how it shifts. I may have upwards of 16 hours into mine getting it installed and shifting properly over several sessions.
Gone to King of the Hammers, back Sunday! Jerry's Geezer Jeep II Website Getting Savvy... Coolest offroad magazine ever! CRAWL Magazine When you have a choice, buy American.
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
