Any info on Rancho RS7000MT Shocks - JeepForum.com
post #1 of 8 Old 11-30-2012, 02:32 AM Thread Starter
DallastheJeeper
Its time for new shocks. Im interested in the new Rancho RS7000MT. Im more concerned with handling and responsiveness than ride smoothness. Does not seem like anybody has reviewed these yet so if you have any info please comment.
|^^^^^^^^^^^^^^^\ ||__
|.......PBR BEER TRUCK.... ||""\_____\
|____________________/||__/----|
#5-06 Salvage Rebuild LJ
Metalcloak Bumper, Overline fenders and Corner guards.
3.5" Sus Lift
1'' Body lift and engine lift
#4-98 TJ Sahara RIP :(
#3-42 GPW Project. Currently on hold Sand blasted the body and it was held together by screen and bondo so new Tub needed
#2-88 Comanche Currently getting a frame off rebuild and a 4bt.
#1-1994 Power Wheels Wrangler
DallastheJeeper is offline
post #2 of 8 Old 11-30-2012, 10:19 AM
Pine_Cat
Pine_Cat's Avatar
Nice, firm ride on road. I read a comment like that in one of the mags, like JP or Offroad, and I agree with it. I have not driven a vehicle equipped with Bilsteins, so I can't tell you whether Bilstein is firmer than Rancho. Some people find Bilsteins too firm, but most like them.
Rancho claims that the 7000s have 10-stage digressive valving, so they won't shake you up off road, and I've enjoyed them both on and off road.
When I was in the market, I was not able to find a gas-charge spec for the Ranchos, but I think Monroe Reflex monotubes are in the 220-240 psi ball park. That would appear to place Monroe monotubes above non-monotube shocks. By contrast, Bilsteins are at 360 psi. Monroe/Tenneco does provide good fitment specs for its brands, including Rancho, so I bought the ones that appear to be a good fit for my stockish set-up.
I called Skyjacker, and they were not able to give me a gas-charge spec for their monotubes (they might consider it proprietary).
Rancho's website also claims one of the 7000's benefits is "reduced road harshness," so consider the possibility that they might not be as firm as Bilstein.
Pine_Cat is offline
post #3 of 8 Old 11-30-2012, 11:04 AM
Rancho_Lifts
Vendor
Rancho_Lifts's Avatar
FYI, I have an e-mail into my engineers to see if I can share my image I have of the 10 stage valving broken down.
I also have a request on the gas charge # as well.
It maybe proprietary though. I will keep you posted on the info I receive.
Rancho_Lifts is offline
post #4 of 8 Old 12-03-2012, 03:07 PM
Rancho_Lifts
Vendor
So this is the info my guys were kind of enough to give me.
On the gas charge spec we are between 270-300 PSI, depending on application.
On the valving it is 10 stage, we have 5 on the compression and 5 on the rebound. It gets into propriety area for us, FYI.
Thanks a lot!
post #5 of 8 Old 12-08-2012, 06:42 AM
Pine_Cat
Pine_Cat's Avatar
Thanks a lot!
Makes sense. On road, at ride height, I've found the Rancho 7000 monotubes to be firm and responsive. I feel that I have a lot more awareness about what my axles are doing after installing these firm monotubes.
At the same time, these shocks soak up the larger bumps, so I guess that means the velocity-sensitive valving is working! Also, the multi-stage valving is giving me the amount of off-road "give" that you want in an off-road shock.
So, I would call it an ideal blend of on-road firmness / responsiveness and off-road flex. Thanks for a great product!
Curious about whether the ten-stage valving is predominantly velocity-sensitive, or also positional? Wondering if I have to be right at the recommended ride height for maximum firmness, or if the monotubes give me the same results with a slightly different height?
I'm riding 1" above my shocks' intended application, because I wanted progressive springs (and I like the results too much to cut the springs). I've read that digressive valving is generally a function of velocity experienced by the shock?
Pine_Cat is offline
post #6 of 8 Old 12-08-2012, 09:24 AM
Gary2
A place out west that specialized in Broncos ( James Duff ) when I used to have them way back when had a theory for shocks on a coil spring suspension that always provided a good ride for me . He had shocks built to his specs he had said . His idea was to let the coil spring take care of most of the compression in order to have a good ride and let the shock put more effort into controlling the rebound . I don't know the ratio he used but instead of being like the fore mentioned Rrancho being 50/50 it may of been more like 60/40 for example . I ended up using his shocks on a Chevy pick up also that I had cranked up the torsion bars on and it then seemed to have an exaggerated rebound when ya hit good sized bumps in the road a they helped that a lot. I think that theory would work for us on Jeeps as well but who knows how each shock is set up other than no we know the Rancho 7000 is about 50/50. Its a spec I had always wished to see included in all of their Dazzle the customers with BS advertisements most publish.
Gary2 is offline
post #7 of 8 Old 12-08-2012, 11:16 AM
Pine_Cat
Pine_Cat's Avatar
I hear ya Gary, but we're in a niche market segment. That's one of the reasons why there are very few ten-stage monotubes offered to the general public, and even fewer if you have an unusual application.
Upgrading your shocks is the least expensive way of upgrading your ride, but I imagine that most Jeepers are running less expensive shocks than the Bilstein 5100s or Rancho 7000s that appeal to performance-oriented customers.
Bilstein's and Rancho's websites name performance attributes that we can read about in technical literature. The performance attributes they name are not "dazzle," even if their websites happen to look great. I can't fault the big guys for being reticent about participating in the custom shock market, and I can't fault them for declining to offer specs that are generally provided by makers of custom shocks.
Pine_Cat is offline
post #8 of 8 Old 12-08-2012, 01:28 PM
Gary2
I am not asking for custom shocks , has nothing to do with custom shocks . I am just asking for a standardized set of specs of some kind so we the consumer can have a better idea as to how the shock will fit our needs compared to a different model or brand shock . I understand you can ask on a forum but everyones wants and ideas ,opinions may be different . Nothing any different than say a tire has . their is enough information available about a tire that the specs alone can pretty much tell you if it is right for you or not .
Gary2 is offline
