any good aftermarket radiators? - JeepForum.com
post #1 of 8 Old 01-14-2006, 06:56 PM Thread Starter
sentry65
I have a manual 98 TJ wrangler 6 cylinder with AC and the radiator is shot with a big leak so I need a new one.
Are there any out there that are better than the OEM ones? Are there any other parts I might as well replace while the work is being done?
are these any good or is there something better?
http://www.radiatorbarn.com/s7.asp?a...L+ENGINE+SIZES
thanks
(tried searching, but apparently no threads are really jumping out at me)
sentry65 is offline
post #2 of 8 Old 01-14-2006, 07:04 PM
99jeeplover
this is one i want to know aswell.
You can get radiator hose kits, high flow water pumps ect from hescosc.com
99jeeplover is offline
post #3 of 8 Old 01-14-2006, 07:07 PM
TJJEEPER
TJJEEPER's Avatar
I replaced mine last year, and Radiator Barn was the best deal that I found. Got it quick and it bolted right in!
JEEP, Not Just a Vehicle. A WAY
97 TJ, 4.0, 5sp, OME Susp., 1 3/4 coil spacers, 1" BL, 35" Xterrains, Dynatrac Trail 60 with ARB, D30F, 4.56's, LockRite F, Discs F&R, K&N, Borla Header, Flowmaster Super 44 Off-Road Muffler, Front LineLock, Diehard Platinum P-1...
06 Commander
TJJEEPER is offline
post #4 of 8 Old 01-14-2006, 07:45 PM
chewrocks
Go to page two and there is a thread discussing radiators. I would stay away from the stock style plastic top and get a metal topped radiator.
chewrocks is offline
post #5 of 8 Old 01-14-2006, 08:19 PM
martinsburgjeep
I is the laws
martinsburgjeep's Avatar
just installed one today, got it from radiator.com delivered in a day, bolted right in, no problems and done in less than an hour
signature
martinsburgjeep is offline
post #6 of 8 Old 01-14-2006, 10:55 PM
method84
method84's Avatar
CFS 3-row all metal
method84 is offline
post #7 of 8 Old 01-14-2006, 11:39 PM
Varnish
Varnish's Avatar
I went with radiatorbarn.com last year and am real happy with it. Got here quick, installation was easy, and no problems (knock on wood). I just went with a 2-row and did not mess w/replacing anything else while I was in there, if it aint broke don't fix it I figured (in this particular instance).
'98 TJ, '06 LJ, '88 YJ
Varnish is offline
post #8 of 8 Old 01-15-2006, 02:05 AM Thread Starter
sentry65
thanks, is the waterpump easy to replace?
should I go for a 180 degree thermostat? Live in AZ.
The jeep doesn't see any hardcore offroading, 99% is all city driving with some occasional light offroading
sentry65 is offline
Are these aftermarket headers any good? yellojeeper TJ Wrangler Technical Forum 1 03-03-2009 08:19 PM
Good aftermarket clutch? daaaaaan YJ Wrangler Technical Forum 9 12-19-2006 08:34 AM
Aftermarket mirrors any good? drew2000 YJ Wrangler Technical Forum 4 06-12-2004 11:20 PM
Good aftermarket A/C? rickdrop YJ Wrangler Technical Forum 11 07-31-2003 06:54 AM
Aftermarket Radiators 97sahara TJ Wrangler Technical Forum 5 01-06-2003 11:20 PM
