Antifreeze HOAT? - JeepForum.com
post #1 of 2 Old 04-28-2004, 09:36 AM Thread Starter
JFiorentino
JFiorentino's Avatar
Antifreeze HOAT?
Hello all, I recently needed to add some coolant to my 2004 TJ. I checked my 2004 Chrysler shop manual and it said that I must use Mopar HOAT antifreeze. It goes on to say that you must not mix any other type of coolant, or risk voiding your warranty
I did a little research on the web and found the following article:
http://www.coolprofits.com/articles/...-Glysantin.htm
According to the article, the proprietary Mopar HOAT (hybrid organic acid technology coolant) appears to be be made by Valvoline who also makes Zerex, Glysantin G 05 (Available at your local Pep Boys car parts store).
I picked up some Zerex G05, and the container states that it's compatible with newer Diamler Chrysler vehicles. It meets or exceeds the required MS-9769 standard.
Just thought I'd share.
Digger
JFiorentino is offline
post #2 of 2 Old 04-28-2004, 09:52 AM
jkulbeth
jkulbeth's Avatar
That's good info. Thanks!
I believe the stuff they're putting in these days is supposed to be environmentally friendly. Don't mix regular antifreeze with the enviro type -- you'll likely get crap precipitating or building up in your cooling system. Not fun. It'll mess up the pump and thermostat, and you'll run hot eventually because of the build up.
I used to package antifreeze and call tell you from experience they're all just about the same. Not ALL, but most. But you can't mix the enviro stuff with the regular stuff... they don't get along very well. Pick a brand and stick with it. If you don't, make absolutely certain you flush your system completely before changing brands or types. And get a name brand -- don't go cheap. We packaged some stuff once that was a blending error. We were going to have to scrap the batch, but someone came in and bought the stuff under their own private label. It had the consistency of snot when it got below 60 degrees. Nasty stuff. And they still sold it.
Here's a thought -- check the label on the enviro stuff... it likely has propylene glycol in it. Now grab a can of a diet soda with something other than NutraSweet in it.... bet it has the same stuff. Isn't that pleasant? But don't go drinking a gallon of enviro antifreeze... it'll still do you a world of bad. Stick with beer.
2004 Wrangler Unlimited, Shale Green, soft-top, Shrockwork Rocker Guards, Kumho 31x10.5 AT's
Green Jeep Club Member #119
jkulbeth is offline
Coolant - HOAT okstatendn TJ Wrangler Technical Forum 31 10-03-2015 09:12 PM
What the HOAT are you talking about? KilgoreTrout TJ Wrangler Technical Forum 36 01-09-2013 11:02 AM
Coolant, green, HOAT or Dex-Cool dkeith TJ Wrangler Technical Forum 16 08-21-2009 11:17 AM
using too much antifreeze? paul olllllllo TJ Wrangler Technical Forum 17 09-22-2007 08:15 AM
AntiFreeze DMBwezz03jeep TJ Wrangler Technical Forum 5 01-18-2005 07:24 AM
