Antifreeze/Coolant Smell but no leak... - JeepForum.com
post #1 of 9 Old 11-10-2009, 05:55 AM Thread Starter
greta
Hi all, hope everyone is doing well.
For about the last 1 month I smell antifreeze whenever I get out of my jeep. I have been consistently checking and there does not appear to be any type of leak (no pools or wet spots under the jeep) and additionally, the jeep does not appear to be losing any antifreeze (it has maintained proper levels without addition of more fluid).
Any idea what may be causing this?
Any advice is appreciated!
Thanks,
ben
greta is offline
post #2 of 9 Old 11-10-2009, 06:00 AM
NotURMailman
NotURMailman's Avatar
You most likely have a very small leak that only leaks under pressure and is small enough that it burns off rather quickly. I would pressure check the system and look very closely at the seams between the radiator core and tanks. Pressurize the system to the cap's rated pressure. Also test the cap.
equipped... And loving it!
I drive on the right side, what's wrong with you?
It's difficult to take you seriously. It's like you're an easily perturbed autistic teenager who's drunk typing the whole time.
NotURMailman is offline
post #3 of 9 Old 11-10-2009, 06:47 AM Thread Starter
greta
alright, thanks for the help!
Probably a pretty dumb question to most, but how does one go about pressurizing the system to the caps rated pressure and how do you test the cap? my guess is that by pressurizing you mean to have the jeep running and then check for small leaks???
greta is offline
post #4 of 9 Old 11-10-2009, 08:24 AM
gmaus
I would check the heater core for a leak if you smell it when you get into the Jeep.
gmaus is offline
post #5 of 9 Old 11-10-2009, 08:28 AM
MUDDYSAHARA
with a pressure tester, and i think autozone will loan you one. you could also look around the thermostat, water pump, heater hoses. noturmailman is probably right, that it is burning off before it shows in your driveway. when looking around, look for a white residue build up, that will help you pinpoint your leak. good luck dude.
MUDDYSAHARA is offline
post #6 of 9 Old 11-23-2009, 05:28 PM Thread Starter
greta
okay. will do! thanks for taking the time to help me out!
greta is offline
post #7 of 9 Old 11-23-2009, 05:29 PM Thread Starter
greta
thanks my friend!
greta is offline
post #8 of 9 Old 04-28-2010, 04:17 PM
capnsilver
did you ever find your leak mine is doing the same and i cant find it
capnsilver is offline
post #9 of 9 Old 04-28-2010, 04:28 PM
wushaw
Rockin jeep
wushaw's Avatar
Check the top tank of the radiator, that's where mine leaked for 50k miles before I finally replaced it.
wushaw is offline
Slight Antifreeze Smell Inside, But No Inside Leak? Rick_Fury TJ Wrangler Technical Forum 5 02-04-2010 09:12 PM
smell of antifreeze jturner18 YJ Wrangler Technical Forum 12 11-20-2009 04:13 PM
I smell antifreeze balbright TJ Wrangler Technical Forum 4 10-31-2009 05:56 PM
Antifreeze smell allmopar YJ Wrangler Technical Forum 4 02-19-2007 07:25 PM
Antifreeze Smell ajboyd TJ Wrangler Technical Forum 13 01-18-2005 02:24 PM
