anti-rock or bumper to smooth out ride - JeepForum.com
post #1 of 69 Old 01-13-2011, 07:20 AM Thread Starter
jeepinhokie
I currently have a 2.5" Old Man Emu Heavy Duty lift on my 04 TJ. The HD kit was designed for jeeps with heavy bumpers and armor, of which i have none. Thus making my ride slightly stiffer than i would like, considering i went with OME for ride quality.
so my question is which would make the biggest difference in ride quality, a Rokmen Mecernary bumper at about 80lb or an Anti-Rock sway bar. i would love to purchase both, but i think the wife might have a problem with it.
opinions from those with the Anti-rock as to how much is smoothed out their on road performance would be great.
do i have enough lift so that the Anti-Rock doesnt need modification? i know its for 4" and i have roughly 3"
they would be going on the blue TJ below.
HOKIES UNITED!
jeepinhokie is offline
post #2 of 69 Old 01-13-2011, 07:40 AM
biffgnar
biffgnar's Avatar
IIRC I trimmed the links a little on my AR (3" BDS springs in front). Probably wasn't necessary though. Works fine.
Not sure about AR really affecting ride quality. Depending on what setting you have it on it affects body roll in corners, but just going down the road hitting bumps, pot holes, etc. doesn't seem to me its doing much (good or bad) for ride comfort.
Romney in 2020!
biffgnar is offline
post #3 of 69 Old 01-13-2011, 07:44 AM
Imped
Imped's Avatar
Antirock. Don't add a bunch of weight to smooth out the ride. The antirock has more advantages than a heavy bumper.
OlllllllO
IndyORV
Imped is offline
post #4 of 69 Old 01-13-2011, 07:46 AM
Racing66atv
anti rock won't help ur ride smoothnes any. If anything it would make it worse because at the stiffest setting it's still a touch softer than your stock sway bar. And idk how a bumper would help the ride quality either. Possibly look into getting a set of new softer shocks or possibly rough countrys long arm upgade?
Racing66atv is offline
post #5 of 69 Old 01-13-2011, 07:47 AM
biffgnar
biffgnar's Avatar
I should have commented on this also. I'm a big believer in weight savings. Address your problems other ways.
Romney in 2020!
biffgnar is offline
post #6 of 69 Old 01-13-2011, 07:49 AM
Fropleyqk
Fropleyqk's Avatar
adding weight to smooth the ride is a terrible idea. The anti-rock isnt going to do anything to smooth it out either. I'd imagine new springs would cost less or equal to both of your proposed ideas. I know you said you have the kit, but for clarity, are you running OME shocks?
Fropleyqk is offline
post #7 of 69 Old 01-13-2011, 07:51 AM
TheMusicMan
Obviously the only way to make a straight hit like a speed bump feel softer is by adding weight.
My vote is for an Anti-Rock swaybar though.
A list of conditions that the Anti-Rock will help smooth out ride more than a heavy bumper; Potholes, Speed bumps at shopping malls which you often drive over slightly diagonally or with just one side of the vehicle, Driveways such as at petrol stations or shopping malls.
Basically anything that isn't a straight front on hit for the suspension, or anything that only hits one side of the vehicle (potholes).
TheMusicMan.
TheMusicMan is offline
post #8 of 69 Old 01-13-2011, 07:51 AM
srfnfly227
And I thought your Jeep rode well. You could always go back to stock and have it ride like mine
srfnfly227 is offline
post #9 of 69 Old 01-13-2011, 08:10 AM Thread Starter
jeepinhokie
yes i am running the OME shocks. so switching to a softer shock isnt really an option.
HOKIES UNITED!
post #10 of 69 Old 01-13-2011, 08:11 AM Thread Starter
jeepinhokie
nahh my dentist would have something to say when he has to replace all my fillings after they fall out riding in yours.
HOKIES UNITED!
post #11 of 69 Old 01-13-2011, 08:14 AM Thread Starter
jeepinhokie
i guess i'm confused. i have heard people saying that their TJs ride smoother after installing the AR. b/c the axel is less tightly linked to the frame, thus allowing the impact from the road to be absorbed by the springs and shocks.
HOKIES UNITED!
post #12 of 69 Old 01-13-2011, 08:20 AM
Imped
Imped's Avatar
That's correct. The stock sway bar is excessively stiff and makes it known. The AR will make an improvement.
OlllllllO
IndyORV
Imped is offline
post #13 of 69 Old 01-13-2011, 08:23 AM
JeepDVL45
Back in the game
JeepDVL45's Avatar
why not the anti-rock AND a bumper?!?!? (you could always go aluminum)
JeepDVL45
"Real men hide their feelings, WHY?!
BECAUSE IT’S NONE OF YOUR ****** BUSINESS!!!!
Men do not cry. Men do not pout. Men jack you in the ******* jaw and say…thanks for comin’ out." - Boondock Saints II
JeepDVL45 is offline
post #14 of 69 Old 01-13-2011, 08:23 AM Thread Starter
jeepinhokie
do you think that removing the sway bar would give me an approximate feel for how the AR would feel on the softest setting? i realize the AR would stiffen it up a little.
HOKIES UNITED!
post #15 of 69 Old 01-13-2011, 08:26 AM Thread Starter
jeepinhokie
i would love to get both, but like i said the wife would more than likely shoot me.
HOKIES UNITED!
help me get a smooth ride with a near perfect YJ postaldave YJ Wrangler Technical Forum 31 04-27-2010 08:04 AM
Any one with currie anti rock + warn front bumper? WILLY348 TJ Wrangler Technical Forum 5 01-07-2010 06:56 PM
best lift for smooth ride? petercaldwell JK Wrangler Technical Forum 3 03-04-2009 08:53 PM
Anti Rock and bumper cutting chappy84 TJ Wrangler Technical Forum 2 01-31-2008 05:36 PM
currie anti rock and arb bumper Nikos TJ Wrangler Technical Forum 3 09-24-2006 09:50 PM
