Anti-lock front - rear - neither question - JeepForum.com
post #1 of 8 Old 07-28-2013, 10:14 AM Thread Starter
Hosejockey61
I just swapped in an '05 Rubi D44 and it does not have anti-lock brakes. My front D30 does.
Should I leave the fronts connected without having an anti-lock rear? I have the wiring harness for the tone rings but the D44 doesn't have the tone rings. Am I better off just leaving the rears disconnected or should/can I simply install the necessary parts whatever they may be?
Hosejockey61 is offline
post #2 of 8 Old 07-28-2013, 11:01 AM
Jerry Bransford
Administrator
Jerry Bransford's Avatar
The ABS system won't work if one axle has ABS & the other doesn't. If you want ABS, it should be a relatively simple task to find a pair of D44 axle shafts that have the required tone rings since later model Dana 44 equipped TJs had ABS as an option. Once you install the axle shafts with the required tone rings, it is a simple matter to transfer the sensors from your old axle to the brake backing plate of your replacement axle.
Jerry Bransford is offline
post #3 of 8 Old 07-28-2013, 11:10 AM Thread Starter
Hosejockey61
Do i have to buy new shafts or can i just buy the rings and press them on? I have chromoly shafts so I would rather just go without ABS instead of going back to stock shafts...
post #4 of 8 Old 07-28-2013, 11:20 AM
nickfast
2003 WJ
Depends on the profile of the shaft where the rings would fit.
Might entail a trip to your local machine shop with tone rings and both sets of shafts. (hint-I would machine the rings to fit, not the shafts)
Nick
nickfast is offline
post #5 of 8 Old 07-28-2013, 11:21 AM
Jerry Bransford
Administrator
The chromolly shafts make it unlikely the tone rings would fit. It looks like it is time to bite the bullet & just disable your ABS system which is what I ended up having to do with my previous TJ's ABS when I also replaced the rear axle with a D44. I would like to have ABS but I'd rather have the chromolly shafts like I'm running too.
post #6 of 8 Old 07-28-2013, 11:24 AM Thread Starter
Hosejockey61
That's what I figured! Thanks Jerry!
post #7 of 8 Old 07-31-2013, 11:50 AM Thread Starter
Hosejockey61
Before I go off hacking away, if I simply cut the ring tone sensor lines will I have a permanent dash light activated? Is there a write up somewhere to do this a correct way?
post #8 of 8 Old 08-02-2013, 06:40 PM
Jerry Bransford
Administrator
You'll have to disable the ABS system completely somehow. On my '97, all I had to do was pull both ABS relays out of the Power Distribution Center but I don't think it's that easy on later model TJs.
anti lock brakes , dana 44 swap , rubicon
