Another turn signal flasher issue - JeepForum.com
post #1 of 1 Old 05-14-2012, 03:49 AM Thread Starter
gbeckwith
A couple of years ago my 06 TJ flasher quit working in emergency flasher mode when the key was out. So I replaced the flasher with a non-OEM unit in case I wanted to go the LED route. Well that flasher was operating strangely from the get go. Can hear it flashing even when I haven't told it to do anything.
Last night I had to pull over on a country road and got a good dash indicator that the emergencies were working. Front ones were, rear ones weren't. Tested the turn signals and all was fine. Oh, yeah. Sometimes this flasher works in no-key mode and sometimes it doesn't.
Your collective recommendations for flasher that really works is appreciated.
gbeckwith is offline
flasher , tj , turn signal
turn signal flasher issue? fang_x TJ Wrangler Technical Forum 12 03-27-2012 12:04 PM
Turn signal flasher Doc Holiday TJ Wrangler Technical Forum 5 08-16-2011 07:38 PM
Turn signal flasher vijay YJ Wrangler Technical Forum 3 05-07-2011 01:45 AM
turn signal/emergency flasher issue dadstoy YJ Wrangler Technical Forum 7 06-11-2008 07:02 AM
Turn signal flasher 93Sahara TJ Wrangler Technical Forum 1 10-23-2003 02:50 PM
