Another tire size/MPG question - JeepForum.com
post #1 of 8 Old 01-06-2011, 08:30 PM Thread Starter
05WK98TJ
Right now I have 31x10.5 Hercules MT and I am looking at either 31" or 33x10.5" BFG AT. I have a 4.0L 5 speed and 3.73 gears and I am wondering if I will gain/lose MPG with the 31" or 33" AT. And how much would it be?
And what if I ran a 33x12.5 AT what would the MPG difference be?
Thanks
05WK98TJ is offline
post #2 of 8 Old 01-06-2011, 08:39 PM
R U STUCK
As long as you keep the 3.73's. The 33's. You will be looking about a 2 mpg drop city. And about the same on the highway.
'04 TJ Rocky Mountain, 4" Fabtech, Sitting on 35"s
Jeep Selling Guru...
IG: R_U_STUCK
R U STUCK is offline
post #3 of 8 Old 01-06-2011, 08:52 PM Thread Starter
05WK98TJ
I assume if I went with 32x11.5 AT's the difference would be 1 mpg. Is there any difference between AT and MT tires affecting MPG's?
05WK98TJ is offline
post #4 of 8 Old 01-06-2011, 09:10 PM
AFjeepMan
at's do have a minor benefit when it comes to mileage, but it's slim when looking at the same size...maybe .5 mpgs to 1mpg max
2005 Wrangler TJ, 3 1/4" RC lift, Cragar Soft 8's 32" BFG Mud Terrains, Smittybilt SRC D-Ring bumpers, Smittybilt XRC8 winch, Body Armor Rockcrawler side guards
[_l_,[____],
l----L - OlllllllO-
(o)_) (o)_)--)_)
Wife≥Jeep>GF
Relearn your priorities.
WANTED: SYE and cv shaft...good condition and good price. for a TJ with about 5-6" of lift.
AFjeepMan is offline
post #5 of 8 Old 01-06-2011, 09:17 PM Thread Starter
05WK98TJ
ok well I would be more worried about the noise from the MT's. I will be driving about 300 miles round trip on weekends(half of them) in the fall when I go to college. So everything helps. Looks like 33x10.5 will be the way to go.
05WK98TJ is offline
post #6 of 8 Old 01-07-2011, 10:07 AM
R U STUCK
If it seems that the 3.73's are not pushing your tires good enough for you. Look into going to a re-gear of 4.10's. On hills or going up small grades you may notice where you made it in 5th gear. You maybe shifting down to 4th to keep your speed up. But it isn't a big deal.
IG: R_U_STUCK
post #7 of 8 Old 01-07-2011, 10:32 AM
atgreene
i have 33's MTRs with 3.73 gears and i get 14 MPG
|______
|l ,[____],
l---L –OlllllllO-
()_)-()_)--o-)_)
atgreene is offline
post #8 of 8 Old 01-07-2011, 10:41 AM
JeffBowser
If you are concerned with noise and do a lot of hwy commuting, MTs are not the way to go. The better ones will start out OK, but with wear will get noisier. If you are just looking for a good looking tire, with decent on and off road performance, have a gander at the Duratracs.
JeffBowser is offline
33 , mpg , tire
Tire Size Question (Not about maz size) Mike318_ YJ Wrangler Technical Forum 5 01-09-2009 03:51 PM
tire size question Jeepman85 TJ Wrangler Technical Forum 2 07-08-2007 06:20 PM
Question about tire size wriver82 JK Wrangler Technical Forum 2 06-02-2007 07:54 PM
Question on tire size??? BigNunz6 TJ Wrangler Technical Forum 10 12-29-2006 10:36 PM
Another Tire Fit Question. Real Tire Size? Gene K YJ Wrangler Technical Forum 2 04-06-2003 09:37 PM
