Another Overheating TJ.. what next? - Page 5 - JeepForum.com
post #61 of 66 Old 07-05-2012, 03:46 PM
mrblaine
Wizard of Brakes
mrblaine's Avatar
Originally Posted by eruji View Post
Thanks guys, feeling a bit better about myself now. I did a google search for similar issues and found a pic of another radiator that has the same folded pattern from the swollen radiator tubes. BTW, no high pressure air or water used to flush things out.
Do you know if yours was OEM or aftermarket?
I am Savvy
blackmagicbrakes.com
mrblaine is online now
post #62 of 66 Old 07-05-2012, 03:50 PM Thread Starter
eruji
mine was an aftermarket brand was Silla - all aluminum. I tried to find an OEM replacement but could not wait for it to be shipped, I ended up with whatever they had at the local autozone.
eruji is offline
post #63 of 66 Old 07-05-2012, 10:21 PM
M1ark
Fan clutch is bad.
M1ark is offline
post #64 of 66 Old 07-09-2012, 09:48 PM
peopenn
2001 keep grand cheorkee. Anti freeze boils, goes
Quickly to "overheat ". In the "red"
Just replaced radiator and new head gasket within a month of each other. What else can
Go wrong. Ready to cut
peopenn is offline
post #65 of 66 Old 07-10-2012, 04:09 AM
peopenn
[QUOTE="peopenn"]2001 keep grand cheorkee. Anti freeze boils, goes
Go wrong. What else can cause this. This was the exact issue when gasket was replaced. ]
peopenn is offline
post #66 of 66 Old 07-10-2012, 09:33 AM Thread Starter
eruji
quick update, jeep is still not overheating. new radiator is working. I took it through a slow drive through on a very hot day (100 degrees) and it slowly got to about 222, but quickly down to 210 after moving. No boiling sound when i stop.
peopenn.. how about other components?
entire coolant system: can you pressure test to make sure there are no leaks
heater core: is it clogged up, can you flush or bypass for testing
thermostat: is it working, you can replace or remove for testing
lower hose: does it have the spring in it? is it collapsing under pressure
radiator cap: you can replace or have it tested
water pump: is it failing? usually leaks through weep hole
ac condenser: is it clogged with mud and bugs
assuming your radiator and head is sealed correctly Im not sure what else you can check
eruji is offline
cooling , overheating , radiator
2.5 overheating booyah93 YJ Wrangler Technical Forum 2 06-24-2010 10:26 AM
YJ almost overheating booyah93 YJ Wrangler Technical Forum 1 06-08-2010 07:51 AM
Overheating rubi03 TJ Wrangler Technical Forum 3 10-10-2006 08:07 PM
YJ 5.0 overheating ,need help Jets22 YJ Wrangler Technical Forum 20 10-01-2006 07:47 PM
overheating, HELP! chrisvr6 TJ Wrangler Technical Forum 5 09-01-2006 11:11 PM
