Another Overheating TJ.. what next? - JeepForum.com
post #1 of 66 Old 07-12-2011, 11:41 PM Thread Starter
eruji
Another Overheating TJ.. what next? **SOLVED**
2001 TJ sport 4.0
Ever since the weather has been getting into the 90 here in so. cali my jeep overheats while idling. This only happens on my way home from work and after ive been on the frwy then stop at a drive in or let it idle for more than 5 minutes. Also, it will sometimes boil in the reservoir as soon as i turn the motor off.
Whats strange is that the temp guage does not slowly raise it goes from 210-220 to redline instantly. If i can get back out on the road and do at least 40mph it will then quickly go back down to 210-220. Seems like the gauge is acting funny. Ive tried turning on the heater and dont notice any reduction in temp. So im not sure if its actually overheating or the gauge or sensor is screwy.
What ive done so far:
New heater core a couple of years ago
new aluminum radiator one year ago
new water pump since april
new thermostat as of this last weekend
new serp belt last weekend
new fan clutch last weekend
EDIT: new rad cap last weekend
no change. still overheats at idle and boils after shut down.
what next?
runs fine otherwise..
is there any way i can monitor engine temp with another device.. diy temp sensor? something? seems strange to me.
where is the temperature gauge getting its data from? ( i think ive read that its not the coolant temp sensor)
eruji is offline
post #2 of 66 Old 07-13-2011, 12:04 AM
robncar
robncar's Avatar
Do you still have the factory fan shroud installed? One way to monitor temp (and other things) is with a ScanGaugeII.
Sent from DROID2
http://www.jeepforum.com/forum/f9/diy-alignment-kit-steps-w-pics-2264465/
robncar is offline
post #3 of 66 Old 07-13-2011, 12:22 AM
BYuen
BYuen's Avatar
Have you made sure you burped the cooling system adequately so there isn't any air in there? I usually run the Jeep up to normal operating temp with the heat blowing and radiator cap off to burp all the air out. You could also try replacing the radiator cap. They're real cheap. A bad cap will let things boil over. I just replaced mine recently.
2001 White TJ Sport
2013 Black JKU Rubicon 10A
BYuen is online now
post #4 of 66 Old 07-13-2011, 12:33 AM
willis36
willis36's Avatar
when you "burp" your system, you need to have the heat on, not the ac. it also helps if you either park on a hill or raise the front of the vehicle.
willis36 is offline
post #5 of 66 Old 07-13-2011, 12:52 AM
BYuen
BYuen's Avatar
Oops that's what I meant! lol corrected it.
2001 White TJ Sport
BYuen is online now
post #6 of 66 Old 07-13-2011, 05:23 AM
Knuckelhead
AFSOC Retired
Knuckelhead's Avatar
Why?...
Knuckelhead is offline
post #7 of 66 Old 07-13-2011, 05:41 AM
bardb
Originally Posted by Knuckelhead View Post
Why?...
To force coolant through that loop of the cooling system in case some air is in there.
For the OP, auto or 5sp? Any obstructions in front of the radiator other than the ac condenser?
bardb is offline
post #8 of 66 Old 07-13-2011, 06:23 AM
Knuckelhead
AFSOC Retired
How is turning the heat on going to force coolant through that loop.
OP, have you tried a new radiator cap?...
post #9 of 66 Old 07-13-2011, 06:30 AM
JBTJ
Coolant flows thru there regardless of the settings of the heater.
JBTJ is offline
post #10 of 66 Old 07-13-2011, 06:31 AM
tan305
when you turn on your heat coolant goes in to the heater core so it will push out any air that could be in there. are you losing coolant besides the boil over?
tan305 is offline
post #11 of 66 Old 07-13-2011, 06:40 AM
JBTJ
Not on mine it doesnít. I can tell by the hoses going to and from the heater core. Engine running and heater switch off both hoses get hot. Means coolant is flowing thru the heater core. If it didnít run thru there then the return line would not be hot, it would be cold.
JBTJ is offline
post #12 of 66 Old 07-13-2011, 06:57 AM
tan305
have you tryed back flushing the system to make sure nothing is in there blocking it up
tan305 is offline
post #13 of 66 Old 07-13-2011, 07:08 AM
unlimitedlj
In front of your radiator is there any thing obstructing it like leafs or anything like that? If there's enough of anything there it will restrict the air across your cores and cause it to run hotter had it happen to a buddy of mine in his Jeep once he cleaned it hasn't had a problem since.
unlimitedlj is offline
post #14 of 66 Old 07-13-2011, 07:10 AM
unlimitedlj
Could be sending unit too.
post #15 of 66 Old 07-13-2011, 07:10 AM
lancer27
Air pockets can get trapped in the system, causing false temp readings and not allowing correct circulation
97 tj i6 3.5 RE superflex lift. hp dana 30 4.56 gears ausie up front. dana 44 33spline alloy usa shafts arb rear. tom woods supper short sye and matching cv ds. 35x12.50x15 goodyear MTR's with kevlar. york OBA system. Metal Cloak High Arch tube fenders!(my favorit mod!!!)
lancer27 is offline
cooling , overheating , radiator
2.5 overheating booyah93 YJ Wrangler Technical Forum 2 06-24-2010 10:26 AM
YJ almost overheating booyah93 YJ Wrangler Technical Forum 1 06-08-2010 07:51 AM
Overheating rubi03 TJ Wrangler Technical Forum 3 10-10-2006 08:07 PM
YJ 5.0 overheating ,need help Jets22 YJ Wrangler Technical Forum 20 10-01-2006 07:47 PM
overheating, HELP! chrisvr6 TJ Wrangler Technical Forum 5 09-01-2006 11:11 PM
