Another Lcg, Hiline hood, Mid arms - Page 5 - JeepForum.com
post #61 of 70 Old 03-10-2011, 04:59 PM
lumpster
lumpster's Avatar
How about an update on how its holding up, and what you think of how it performs now that you have had it for 3 years or so like this.
lumpster is offline
post #62 of 70 Old 09-20-2011, 11:04 PM
LilSteve97TJ
Bump. Guess he got off the board it seems?
97 TJ
98 Taco
LilSteve97TJ is offline
post #63 of 70 Old 11-05-2011, 11:20 PM
AstroZombie
That's near perfect!
2004 Black Rubicon. Locker mod and a few other things...
USN Jeep Club Hull # 199
AstroZombie is offline
post #64 of 70 Old 11-29-2011, 03:21 PM Thread Starter
White99tj
Still around just put the jeeping on hold for now.
White99tj is offline
post #65 of 70 Old 08-25-2012, 08:50 AM
funshootin1
you done puttin jeeping on hold yet... this jeep is the perfect setup...stealing most of your ideas. thanks for posting all these pics.
TURBOCHARGED JEEPS ROCK!
funshootin1 is offline
post #66 of 70 Old 08-25-2012, 11:34 AM
mikebyn
anymore info on centering the 8.8 is there a write up you used somewhere
2006 Tj: 2" BB, 1" BL, 33's
Build Thread:
http://www.jeepforum.com/forum/f22/2006-tj-dd-shooting-35s-37s-1258213/#post12088091
mikebyn is offline
post #67 of 70 Old 08-25-2012, 04:40 PM
funshootin1
I should have done that centering deal. just didnt occur to me at the time but its so simple. basically you need a second long side axle from another 8.8 and you measure cut and sleeve the tube making both sides equal length. i just spent 4 hours powerwashing the turd as prep for the rear mid arm project. unfortunately my finacial situation doent allow for high end components in my control arms at this point..the project wasnt planned, I sheared both upper control arm brackets off the frame last saturday so i placed an order for some prefab link mounts and im making the truss from scratch, also my control arms are being made from a combo ok jk stock arms, leftover rustys lca's with center threaded swivel design and spare tubing laying around..the temp links will be decent enough that i can wheel it till i can build nicer units. outboarding the shocks out back and extending the front pockets will come later too... all these pics on this thread are a great help.
post #68 of 70 Old 08-27-2012, 04:39 PM Thread Starter
White99tj
Still not Jeeping.
But I did pick up a HP44 with Chevy outers, high steer arms, 5.13 gears and Detroit.
So it looks like I have some work to do on the Jeep. Its been close to four years since my last round of major mods.
post #69 of 70 Old 08-27-2012, 04:44 PM Thread Starter
White99tj
Link to my pirate thread showing the suck down winch mod.
http://www.pirate4x4.com/forum/showthread.php?t=593450
post #70 of 70 Old 03-31-2014, 07:55 PM Thread Starter
White99tj
Its been awhile since my last post.
Im currently swapping the AX15 for an AW4 transmission. Got a great deal on the tranny and im tired of shifting.
I used STU'S write up and as always right on. (His write up makes it look easy.)
Its one heck of a lot of work.
hiline fender w/snorkel(arb) and other inside stuff MODUS TJ Wrangler Technical Forum 15 10-24-2011 04:35 AM
Hood prop or lay the hood right back on the windsheild frame? Jeeeeeeeeeeeeep YJ Wrangler Technical Forum 27 01-29-2010 04:55 PM
Currie lower arms shorter than my old arms? vetdezracer TJ Wrangler Technical Forum 17 12-04-2009 05:13 AM
Short arms w/ tummy tuck, or long arms? P89Jeeper TJ Wrangler Technical Forum 5 08-16-2008 05:47 AM
hiline flares frankiefire702 TJ Wrangler Technical Forum 2 07-11-2007 08:07 AM
