Another Lcg, Hiline hood, Mid arms - Page 4 - JeepForum.com
post #46 of 70 Old 04-08-2009, 12:27 PM
cgmrdc
1988 MJ Comanche
subscribed! Im at work so i cant see pics... but im getting ready to do exactly what youve done! I have 2.5 coils 1in bl/mml and will be going to 35s... hp30 and 8.8, i currently have RE monotubes for 3.5-4.5 lift so i plan on relocating them with ford shock towers too.
quick questions. what is the width of the recentered 8.8? ive been thinking about doing this too but was worried id be a lot wider than stock... not a big fan of that look...
TIA
cgmrdc is offline
post #47 of 70 Old 04-08-2009, 12:33 PM
Unlimited04
This post/info=my opinion
Unlimited04's Avatar
where do you get the Ford shock towers? internet says they're PN E5TZ*18183*A, wondered if you cut them off something or bought them new?
Useful Write-Ups:
Fabrication & Build:
Funny:
Unlimited04 is offline
post #48 of 70 Old 04-08-2009, 12:35 PM
RUBtjICON
Well by that part number, they went to an '85 Truck
All Who Drive Jeeps Are Not Jeepers - Willy 3:16
RUBtjICON is offline
post #49 of 70 Old 04-08-2009, 01:30 PM Thread Starter
White99tj
TIA
I made the sleeve 2 7/8" long for the 8.8. 2 7/8" is the diff between the two axle shafts. I had about 5" side into both sides of the axle. So the total length of the sleeve was about 12 7/8". Hope you are following this.
This will make the 8.8 like 5/8" wider on both sides than the front axle not noticable IMO.
If you have a sleeve made, have the machine shop cut a 1/4 key way the length of it. This will slide over the weld seam inside of the axle tube. This will make sure the outer tube is properly lined up with the main axle.
I used Stu's numbers to start with then adjusted for the offset.
White99tj is offline
post #50 of 70 Old 04-08-2009, 01:33 PM Thread Starter
White99tj
Just went to the ford dealership and got them.
post #51 of 70 Old 04-08-2009, 01:38 PM
cgmrdc
1988 MJ Comanche
im gonna send you a pm over on KCJC... im a member there too...
cgmrdc is offline
post #52 of 70 Old 04-08-2009, 02:58 PM
solarpower
Looks like your still using the factory mounts at the axles, have you had any issues with them after some trail rides??
Nice build. Clean work.
04 TJ "U" package
06 XK Commaddy 4.7
solarpower is offline
post #53 of 70 Old 08-05-2009, 11:55 PM Thread Starter
White99tj
I did a suck down winch a few months back, I will get some pic on here soon.
My post on pirates has the pics of it if you want to look.
http://www.pirate4x4.com/forum/showthread.php?t=593450
post #54 of 70 Old 02-01-2010, 11:49 AM
pjku79
any issues yet?
97 TJ, d44 arb locked, 2.5" bds lift, 35" tires, JKS adjustable control arms
pjku79 is offline
post #55 of 70 Old 02-01-2010, 11:00 PM
rs4race
cool build. I like relocating stuff like the shock mounts and whatnot. That seems like alot of flex.
My Build
http://www.jeepforum.com/forum/f22/rs4races-build-957569/
rs4race is offline
post #56 of 70 Old 02-02-2010, 12:53 PM
wrangler2007
love this thread Beautiful work man
Other Vehicles:
07 Mustang, Whipple, 465 rwhp, Magnaflow, Hurst , AVIC D3, Spec 3+, BMR CA's, Autometer, FRPP Springs
08 F150 5.4L, Super 40 SIDO, Roush Grille, Edge Evolution, Truxport, 2.5" AS Level, 1.5" AAL, 35x12.5x20 Nitto Trail Grapplers
wrangler2007 is offline
post #57 of 70 Old 03-09-2011, 06:58 PM
Shmoore
Any pics of this thing wheelin?
Shmoore is offline
post #58 of 70 Old 03-09-2011, 06:59 PM
Shmoore
Awesome jeep btw very similar to the height I wanna be at with 35's
Shmoore is offline
post #59 of 70 Old 03-09-2011, 07:31 PM
tangotag
Cool Mods. I am new to major mods and have a couple questions.
Any concerns running shocks mounted in single shear on the bottom like that?
It did not appear in one photo that the 8.8 differential was welded to the axle tubes with a low-hydrogen rod.(Maybe the picture angle just didn't show it)
Would a 4 link apply too much stress to the pressed in tubes?
tangotag is offline
post #60 of 70 Old 03-10-2011, 03:59 PM
rage1
Great job. I'm planning mid arms and rear ford mount. Got the shock mounts and frame mounts for the arms. Rokmen will build the arms when I call in the measurements. Bilstein 12" shocks are already on with Currie springs. Cool to see something similar.
2003 Rubicon, modified
rage1 is offline
hiline fender w/snorkel(arb) and other inside stuff MODUS TJ Wrangler Technical Forum 15 10-24-2011 04:35 AM
Hood prop or lay the hood right back on the windsheild frame? Jeeeeeeeeeeeeep YJ Wrangler Technical Forum 27 01-29-2010 04:55 PM
Currie lower arms shorter than my old arms? vetdezracer TJ Wrangler Technical Forum 17 12-04-2009 05:13 AM
Short arms w/ tummy tuck, or long arms? P89Jeeper TJ Wrangler Technical Forum 5 08-16-2008 05:47 AM
hiline flares frankiefire702 TJ Wrangler Technical Forum 2 07-11-2007 08:07 AM
