Another Lcg, Hiline hood, Mid arms - Page 2 - JeepForum.com
post #16 of 70 Old 08-12-2008, 01:30 PM Thread Starter
White99tj
Some under the hood relocating.
The Ford shock towers on the front and rear.
White99tj is offline
post #17 of 70 Old 08-12-2008, 01:37 PM
XXRider
Originally Posted by TJ-Marine PA View Post
x2
What air box did you use for your air intake setup?
+3
Love to know some details on this.
XXRider is offline
post #18 of 70 Old 08-12-2008, 01:38 PM Thread Starter
White99tj
Some of the air intake its a ford mini van filter assy from the 90's explorers also used the same set up.
The filter assy all snaps together. I just cut it down and slid the short end over the other longer one, snaped the inner piece in and siliconed it all up.
Its has been on my jeep for around two year no problems yet.
post #19 of 70 Old 08-12-2008, 02:09 PM
Hydro
Hydro's Avatar
never seen the ford shock towers before, pretty sweet. Whats the advantage to this other than easy access?
tout le monde, tout mes amis, Je vous aime, Je dois partir. These are the last words I'll ever speak and they'll set me free.
Officially driving the Jason Ellis Bandwagon
Hydro is offline
post #20 of 70 Old 08-12-2008, 03:21 PM
TJ-xtreme
it allows you to use longer shocks without lifting anymore so you have more down travel and in effect more flex.
2001 TJ Sport w/ D44, 2.5" Susp. lift,1" BL w/ MML, 35x12.50 BFG KM2's on 15x8 Soft 8's, Smittybilt XRC Front Bumper and Rocker Guards, S/B SRC Rear Bumper, Xenon 4" Flat Flares, JKS Disconnects, 48" Hi-Lift Jack, OBA System, Optima Blue Top, Hella Lighting. More on the way... ;}
JEEP= Just+Empty+Every+Pocket.....
EAT-SLEEP-JEEP OlllllllO
TJ-xtreme is offline
post #21 of 70 Old 08-12-2008, 03:26 PM Thread Starter
White99tj
The main reason I went with the shock towers was. Less bump stop more up travel.
post #22 of 70 Old 08-12-2008, 04:50 PM
That1guy
That1guy's Avatar
2007 WK
Wow thats awesome!
I'm forever grateful to Speedycat and RnEmOvr for their generosity
That1guy is offline
post #23 of 70 Old 08-12-2008, 05:34 PM Thread Starter
White99tj
A few pics of the mid arms
Lowers 27"
Upper rear 25"
Rear trackbar 35"
Front upper ?
Poly performance frame brackets. The 10deg ones work best less trimming.
post #24 of 70 Old 08-13-2008, 06:14 AM Thread Starter
White99tj
I did not take any pics of the rear wheel well.
The area to cut out is diff with every type of suspension set up IMO.
Short arms ,mid arms and long arms all have diff amounts of rear steer when fully flexed.
Not to mention shock length added to the mix.
I pulled the coils, unhooked the rear sway bar and shocks. Then put the tire on on the side I wanted to check and flexed it fully and compressed it fully.
Marked 1" above the tire and cut.
I could not count the # of times that I have pulled the front and rear coils to do all the mod that I have done.
And when you go out on the trail its diff yet.
post #25 of 70 Old 08-13-2008, 09:13 AM
Bennettj13
Crawled, and subscribed. I like how you did the shock mounts a lot. That makes a lot of sense to me. With all of that downtravel, how much of that flex is useless? Do you still get decent traction even with that much droop? Were you still able to use those shock mounts without screwing with the fenders? I'm planning on doing a highline for my build, and I'm looking at the clayton LA lift. By the time it's said and done, I might just do the same with my shocks. Nice build.
::SELLING HALF OF MY JEEP::
Bennettj13 is offline
post #26 of 70 Old 08-13-2008, 09:47 AM
mrblaine
Wizard of Brakes
mrblaine's Avatar
For anyone that wants to do the same, be aware that non sensor safe RTV silicone will take out your O2 sensors if it's in the air supply.
I am Savvy
blackmagicbrakes.com
mrblaine is offline
post #27 of 70 Old 08-13-2008, 11:36 AM Thread Starter
White99tj
With the 33"tires I only rubed on the front factory fenders.
I have 5" of up 8" down travel in the front and 4" up 9" down in the rear.
The rear coils are still tight at full flex, front are loose.
Now with 35" tires highline hood I have 5/8" clearance on the front. The rear I trimmed and have about 3/4". Still have another 1/2 to 3/4 I could trim on the rear.
Full extension on front
Full compression on front
post #28 of 70 Old 08-15-2008, 11:48 AM Thread Starter
White99tj
Some pics of the rear.
You can see where I moved the track bar up and out. This rid the rear from binding at full flex. Track bar is 35" long. Coils dont hit the brackets or track bar.
Man after all the work to make the track bar work I would have been time and materials ahead to four link it.
The other side track bar mount down and out . Bracket is clear of coils and shock.
Some of the front mid arms at full flex.
Some of the flat skid
post #29 of 70 Old 08-15-2008, 08:48 PM
JEEP97TJ
Very nice, great job. I like the shock towers, that's an awesome idea.
Blacksburg, VA
JEEP97TJ is offline
post #30 of 70 Old 08-16-2008, 10:13 AM
H3RTCH
Live Free or Die.
H3RTCH's Avatar
beautiful Jeep- I'll be using a lot of your ideas. BTW I used to have a pedal car just like the one in the one pictures. I had so much fun in that
2004 Jeep WJ Grand Cherokee Overland - My DD
1988 Jeep MJ Comanche 4.0L - Dad's
1999 Jeep WJ Grand Cherokee Limited 4.0L - Mom's
H3RTCH is offline
hiline fender w/snorkel(arb) and other inside stuff MODUS TJ Wrangler Technical Forum 15 10-24-2011 04:35 AM
Hood prop or lay the hood right back on the windsheild frame? Jeeeeeeeeeeeeep YJ Wrangler Technical Forum 27 01-29-2010 04:55 PM
Currie lower arms shorter than my old arms? vetdezracer TJ Wrangler Technical Forum 17 12-04-2009 05:13 AM
Short arms w/ tummy tuck, or long arms? P89Jeeper TJ Wrangler Technical Forum 5 08-16-2008 05:47 AM
hiline flares frankiefire702 TJ Wrangler Technical Forum 2 07-11-2007 08:07 AM
