Another Lcg, Hiline hood, Mid arms
| DISCOUNT - Chromoly Front Axle Shaft Kits, 87-95 YJ's, 97- | GR8TOPS Introduces the Exogate HD Tire Carrier | Truck-Lite's New LED Headlamp Series |
#1 | |
This has been a few years in the making.
axles HP30 8.8 centered pinion (very easy) Just measure the two axle shaft's length. Cut the axle and sleeve it. Use two long shafts. 4.88 gears Lift 1"bl 2.5 ome Front & rear Acos front 13" travel rs9000 shocks 2" bump stop front 1" bump stop rear 2"mml 35" tires BTF DIY Fenders ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() I will post more pics later. Im not much on typing but the pics are really what you want to look at.
#2 |
Best fresh air setup I've seen yet. Your going to have to give up some detail on that mod.
Scott L. |
#3 |
very nice. thats very close to what I have planned once I hit the lottery
Useful Write-Ups: SEARCH TUTORIAL TJ Tech BOOT CAMP-A Must Read! FAQ: Cold Air Intakes & K&N's Off-Road Tips and Techniques What is a CV shaft and why do I want one? So you want a Tummy Tuck? Tire size, lift height, bumpstops & shock guide DIY Shock Shifters for Long Travel Shocks Lug nuts and bolt patterns Catalytic Converters Busted TJ Track Bar Bolt Fix Brake Knuckle Divot/Groove Repair Coconut Oil for Drilling and Machining Fabrication & Build: My Build Thread Funny: Will it fit in my Jeep? |
#4 |
More pics would make me a happy dude. That's a nice build.
OH WAIT. WHAT? |
#5 | |
What air box did you use for your air intake setup?
99 Gun Metal Blue TJ 4.0 w/ Cooper Discover STTs, Optima Red Top, Kilby Steering and Gas Tank Skids 10 Gray WK 4X4 Hemi Stock 09 Blue Ram 1500 4x4 Hemi Stock JarHead Jeep Club Member #8 www.bbnt4x4.org Go Pittsburgh!!! Go Penn State!!! |
#6 |
You could fit 37's on that thing. Nice rig.
2004 TJ-L with 3-4" of lift, 35's, and no money The Unlimiteds shall inherit the earth. |
#7 |
I just have one question. What did you do with the Vaccum Leak Detection canister on the pass. side? Please post pics on the pass. side.
#8 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() More pics to come |
#9 |
37" tires will rub when flexed, I have some pics to show you.
#10 |
lets see the pics you speak of
to the op. this rig looks very good
2005 Bright Silver Metallic X D30/8.8 lsd, 2.5" Skycrapper springs, TNT Phantoms front/ Genright hi-clear Rear. D30 Lockright, LOD Rear Swingout, hardtop, hard and soft upper doors, Bestop bikini/jammer/duster, Bestop SuperTop, HacknTap, 8000lb Gorilla, Magnaflow, Moabs. 285/75R16s Firestone Destination ATs, Smittybilt XRC Stinger 2006 GTO M6- Under 20k miles... Garage Queen |
#11 |
#12 |
Flex shots please!
I'm forever grateful to Speedycat and RnEmOvr for their generosity |
#13 |
35" tires fully flexed 5/8" clearance from front fender
#14 |
#15 |
No pics of the rear wheel tubs from where you raised those
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
