Ok so my 8.8 is at the shop right now and I should have it back by friday with the brackets welded on and ready to go. The 8.8 has factory 4.10 gears so now I need to get a plan together for the front to get rid of the 3.07 gears up there. I can get my d30 regeared for around 580.00 total (parts and labor) or i found an HP Dana 30 from a 95 XJ with 4.10 gears cheaper but the only one I can find has the ABS. Anything I should know about using this axle with the ABS or any problems? Anything additional I will need to buy or is it the same as the non ABS axles. Thanks for any help.
IIRC the only thing about the axle that makes it have ABS is the tone ring on the axle shaft itself. If it's the larger ujoint shaft don't worry about it. If they are the smaller ujoint shafts just put your shafts in there. The tone ring being on there won't hurt anything.
The axle is off a 95 XJ, I'm assuming based on what I read on these forums it shouldnt have the vac-disconnect, but correct me if I'm wrong.
Related Threads
Jeep Enthusiast Forums
18.5M posts
726.7K members
Since 2000
