Another exhaust issue - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > Another exhaust issue
XT (ExtremeTerrain.com) has Barricade Off-Road Armor!ROCKRIDGE4WD Introduces a NEW Jeep Wrangler JK *led* tail Nitro Gear Packages Now Available at Rockridge 4wd
Unread 12-04-2014, 07:02 PM   #1
Rubiconzombie
2003 Rubicon 4.0 automatic. The other night coming home from work my exhaust got really really loud. I didn't hit a bump or anything like that I was merging onto the interstate and had to rev the motor to about 3000 rpm's to get into traffic. That's when IT happened. There was no pop or metallic sound that I could tell. My ride home is about 60 miles 40 interstate 20 are decent to good 4 and 2 lane highways. About a mile from my home the road turns to crap as soon as I turned onto my road ( needed paving 10 years ago )that's when IT stopped. This was during thanksgiving break so I had it in the woods for a few days taking my kids hunting no loud exhaust thru the rpm range. Went to drive it to work today and as soon as I turned off the crappy road the sound came back. I had the exhaust fixed 3 months ago they had to press fit the new down pipe/converters as I have the 2 piece manifold design on my Heep. Everything seams to still be intact I can push or pull and the exhaust has no measurable play. I have had a cracked manifold before this sound is much much worse. The gauges have not changed I do not believe this is a internal engine problem. Please let me know what else to check I have another ride F150 but it has a drinking problem.
Never underestimate the power of stupid people in large groups.
Rubiconzombie is offline   Reply With Quote Quick reply to this message
Unread 12-05-2014, 08:48 AM   #2
robncar
Inspect it? That's what I'd do... or take it to a reputable shop and have them inspect it for you.
http://www.jeepforum.com/forum/f9/diy-alignment-kit-steps-w-pics-2264465/
robncar is offline   Reply With Quote Quick reply to this message
Unread 12-07-2014, 10:27 AM   #3
durango-bob
If you get a cold morning, you can fire it up and look for a water vapor leak. But it does sound like you have forced a connection apart enough to get a leak. I'm guessing that you need a smooth surface under the Jeep to reflect the noise back to you.
durango-bob is offline   Reply With Quote Quick reply to this message
Unread 12-17-2014, 11:43 AM   #4
StrokerJeep00
That double collector by the manifold is tons of fun! Mine likes to loosen up as well, that is until I got some decent flange gaskets seated in these and torqued them back down.
StrokerJeep00 is offline   Reply With Quote Quick reply to this message
Unread 12-17-2014, 02:40 PM   #5
pwdrtoastman
same issue here, i have to retighten them almost every week.
pwdrtoastman is offline   Reply With Quote Quick reply to this message
Unread 12-18-2014, 12:35 AM   #6
Knuckelhead
AFSOC Retired
Knuckelhead's Avatar
The "Y" pipe that connects to the 2 piece exhaust manifold doesn't use flange gaskets...
TSB Information: http://www.automd.com/tsb/jeep_m/wrangler_mm/2000_y/
Knuckelhead is offline   Reply With Quote Quick reply to this message
