Another Door lock/unclock issue - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > Another Door lock/unclock issue
ANOTHER Rockridge4wd Creation!! Spare Tire Carrier Delete The Jeep Forum Discount is ON!The Original 3/8" Ruffstuff Diff Cover!
Unread 01-08-2015, 12:14 AM   #1
jayfrem
Junior Member
Hello
My full doors started giving me problems when unlocking with a key.
Heard i can spray some WD 40.
Should take the inner panel off and check the locks.
What usually goes wrong on these locks ?
Was someone able to program a remote for door lock/unlock ?
Jihad
Jay Frem
2006 LJ Rubicon - AEV kit, 35", Nth TT, 3"FT, PSC slides and corner crushers,AtoZ bumpers
Land Rover Disovery 1996 on 36.5" IROKS ( locked, 30 spline chromoly axles&CV's, Toy8", Warn M8274-50...)
Range Rover 1983 - mainly stock
jayfrem is offline   Reply With Quote Quick reply to this message
Unread 01-08-2015, 06:27 AM   #2
JEK3
WD-40 may help, but it won't last long. Spend the couple bucks more on an actual lock spray with graphite.
I would recommend popping the inner panel off your door. The mechanism inside is a bunch of thin rods with plastic clips, things sometimes get misaligned or bind up. Can't hurt to take a look. May also help to look inside the other door, just so you know what a working door looks like.
JEK3 is offline   Reply With Quote Quick reply to this message
Unread 01-08-2015, 11:08 AM   #3
jayfrem
Junior Member
Where to find these lock sprays with graphite?
It is snowing and freezing where i am.
Could it be frozen locks ? When i insert key i cannot open or lock the lock ? Both door have the issue. Passenger door is worse.
To take off inner door panel do i need to take off door hande screws and screw near door lock ?
Jay Frem
Unread 01-08-2015, 11:55 AM   #4
rsurran
If you pull the inner door panels off in this weather you are going have a time getting them back on. I would shoot some graphite in the key hole and try that first. I had that problem in warm weather on my passenger door and I certainly wouldn't pull that panel off again without good reason and not now unless you are in a heated garage. The problem is the weather seal at the top of panel where it goes under the window seal.
2005 WK, 5.7L, Gold, Leather
2003 TJ 4.0L Freedom Edition, Flame Red, 5 spd., CAI, Warn, stinger, Hella/KC trail lights.
Dick Surran
"When you stop contributing you are just taking up space."
rsurran is offline   Reply With Quote Quick reply to this message
Unread 01-09-2015, 12:36 AM   #5
oakmckinley
I haven't locked my doors in over ten years. As your experiencing both lock cylinders on mine on the outside are frozen/rusted/dead...
I don't have any trouble opening or closing them though?
My suggestion just don't lock them and don't leave anything valuable in there.
1999 TJ
2010 Mustang
1964 Ford Fairlane 500
oakmckinley is offline   Reply With Quote Quick reply to this message
