Another 4.0 piston skirt thread - Repair or replace - JeepForum.com
post #1 of 42 Old 06-29-2010, 10:28 PM Thread Starter
halo26
Hey Guys,
Long time reader/fan, first time poster...
A little background on my jeep... its a 2000 TJ Sport with the 4.0 and 'supposedly' is about to join the 200k club. I say supposedly because it runs like a champ, has 0 rust, and (from looking at the CarFax) the first owner put 120k on it in 1 year (we have a few theories, some more plausible than others).
Anywho...
My 4.0 just started making a noise I'm pretty sure is a broken piston skirt. I have no loss of power, etc... just the typical knocking (loud when cold, then much softer when warmed up).
My question is, (after I make certain it is a piston skirt) should I tare down the engine and replace the piston (hoping there's no damage done to the wall) or should I just keep wheeling it until I have an issue (more than just a noise) then replace the whole engine?
I'm very much a newbie, so if this has been hashed 100x or is common sense, please forgive my ignorance!
Any help would be GREATLY appreciated!
Thanks for reading!
halo26 is offline
post #2 of 42 Old 06-29-2010, 10:54 PM
Nonya
1st thing you wanna do is short each spark plug while it is running and see if the noise changes. Should at least narrow it down to which cylinder is bad.
Keep in mind a chunk of carbon can make alot of noise too. If it was driven slow it maybe carboned up badly at high miles, it can break off and make lots of noise.
Nonya is offline
post #3 of 42 Old 06-30-2010, 12:43 AM
LRod
I had a 91 that knocked when cold and my 06 has a slight occassional knock. As I recall there was a class action lawsuit regarding a problem with the 4.0 #6 cylinder being out of round or some such thing, do a search on 4.0 knock or something. As it turned out I think they found Chrysler in the wrong but didn't do anything to help the consumer and your stuck with it.
LRod is offline
post #4 of 42 Old 06-30-2010, 05:04 AM Thread Starter
halo26
Thanks for the responses, guys!
Nonya - Is there a way to do this with a coil rail? I've read you can put the injector wire (probably saying that wrong ) and accomplish the same thing... not sure though.
LRod - Exactly... a mechanic friend of the family was telling us he replaced 2 #6 cylinders last month. I've been doing some reading on the knock for the past few weeks and playing 'match the sound' . Was your knock just piston slap or did you have to do something to correct it?
Thanks again for he help... I need all of it I can get!
halo26 is offline
post #5 of 42 Old 06-30-2010, 08:37 AM
Nonya
Pulling each injector connection should unload the cylinders enough to find the noise but i'm afraid you really don't know what you are listening for. A broken piston skirt should be so loud its obvious. If you want to post up a sound sample it would help to ident what you are hearing. A good JEEP dealer service dept might just give you a quick listen for free, ask the service manager for a opinion.
Nonya is offline
post #6 of 42 Old 06-30-2010, 11:48 AM
Dryseals
1980 CJ7
Knock when cold and then quieting as it warms is usually a rod knock. Piston skirts make more of a slap sound and if they are slapping around will wear into the cylinder wall quickly. If your in the 200K club or nearing, I would suspect a rod bearing. You can continue to drive for a long time on a bad rod bearing if needed. But I would start looking at a rebuild.
No sense in just attacking one piece, freshen it up for another 200K.
Dryseals is offline
post #7 of 42 Old 06-30-2010, 11:58 AM
TJ311
Could honestly just be normal wear too. The 4.0 is loud in stock form, but throw a couple hundred thousand miles at it and could be louder. If it's not too loud, I'd say it's just piston slap from wear. As the piston heats up, it expands enough to quiet down. Not sure it's the case in this engine but on some of the engines I've built in the past (with forged pistons) they're a little noisy when cold then quiet down after warm-up.
What weight oil are you running in it?
TJ311 is offline
post #8 of 42 Old 06-30-2010, 12:01 PM
Nonya
BS this guy is wrong...rod bearing noise gets ALOT LOUDER hot
Nonya is offline
post #9 of 42 Old 06-30-2010, 12:06 PM
TJ311
I was thinking the same thing. I don't think I've personally ever heard a rod knock get quieter as it warmed up.
TJ311 is offline
post #10 of 42 Old 06-30-2010, 01:30 PM
Nonya
Hes just posting up garbage to aggravate, I have no idea why the owners of this forum put up with it. Him and a few others feel the need to post in every thread i post....weird i know....
Nonya is offline
post #11 of 42 Old 06-30-2010, 07:03 PM
Knuckelhead
AFSOC Retired
Knuckelhead's Avatar
Originally Posted by halo26 View Post
Anywho...
Thanks for reading!
Have you changed the oil and looked for aluminum debris in the drained oil? You could also cut the oil filter open and check there.
I bought a tool for cutting my filters open to inspect them.
Like this:
HAND CRANK OIL FILTER CUTTING TOOL from Aircraft Spruce
The one I bought cost around $60...
Knuckelhead is offline
post #12 of 42 Old 06-30-2010, 09:48 PM
Nonya
heres the other guy that feels the need to post up when ever i post.
Nonya is offline
post #13 of 42 Old 06-30-2010, 09:52 PM
Nonya
Like this:
Useless info........take it to a good mechanic and have the noise diagnosed.
Nonya is offline
post #14 of 42 Old 06-30-2010, 10:06 PM Thread Starter
halo26
Hey Guys,
Thanks again for the responses!
i'm afraid you really don't know what you are listening for. A broken piston skirt should be so loud its obvious. If you want to post up a sound sample it would help to ident what you are hearing..
I'm beginning to think you're right . Posting a sounds is a really good idea, Iíll go grab my camera here and try to get one up (1 when cold, 1 when warm).
Piston slap is my other thought as well.. and the more I listen to you guys, the more possible it sounds.
Right now I have diesel oil & 1 qt of MMO in it... I read on a few threads that people with certain knocks found some relief running it. For me, itís done nothing (possibly even made it a tiny bit worse). I plan on draining it soon (has about 100mi on it) and replacing it with a high mileage oil in the recommended weight.
I'm currently not blowing any oil into the intake and my oil pressure (I think) is ok. It usually sits, after warm, a little above 20 (I think its 20, its the first line after 0.. not near the jeep right now).
Sorry for the delay in posts... GF got into a fender bender today, so I've been pulling the bumper-cover / bumper off her car all night
Thanks guys!!
halo26 is offline
post #15 of 42 Old 06-30-2010, 10:07 PM
Nonya
If you had some idea what the noise was and were sure its from the lower end you could easily pull the oil pan and inspect the pistons. Easy job but i would get a good opinion 1st. A good mechanic should easily be able diagnose the noise in 1 hrs time. Shorting each plug or pulling each injector plug should tell you which cylinder it is and even if its a bearing or piston if the mechanic is good. With the oil pan off you inspect everything BUT you need pro help IMO. Too much basic knowledge is needed to check bearings etc to actually explain how to do it.
Nonya is offline
piston skirt , tj , wrangler , repair , replace
Piston Skirt Blew up...Need advice. alj9115 TJ Wrangler Technical Forum 14 05-18-2010 12:04 PM
Engine Noise = Broke Piston Skirt gabriel05 TJ Wrangler Technical Forum 3 04-04-2010 11:04 AM
2.5L engine knock (broken piston skirt) 2000jeeper TJ Wrangler Technical Forum 0 11-05-2009 04:21 PM
Anyone ever busted a piston skirt? Benpup TJ Wrangler Technical Forum 2 10-03-2009 01:41 PM
Help! Chunk of Piston Skirt in Oil Pan Wulfgang YJ Wrangler Technical Forum 16 11-12-2008 09:12 PM
