Angry Swallows - JeepForum.com
post #1 of 20 Old 03-01-2009, 11:10 PM Thread Starter
jepmn03
Angry Swallows
I have the classic angry swallows issue and I am going to try to pinpoint it tommorrow. I want to fix the noise, but plan to upgrade to a SYE and a Tom Woods DS. I only want to replace the noisy U joint. Any suggestions from past experience on which one to replace first, or is it usually a random u-joint ??
|______
|l ,[____],
l---L –OlllllllO-
()_)-()_)--o-)_)
jepmn03 is offline
post #2 of 20 Old 03-01-2009, 11:12 PM
MT_Ranger
It's usually the CV joint in the front driveshaft.
MT_Ranger is offline
post #3 of 20 Old 03-01-2009, 11:13 PM
Apex
Recon death squad
Apex's Avatar
Angry swallows? sounds naughty
Apex is offline
post #4 of 20 Old 03-01-2009, 11:52 PM Thread Starter
jepmn03
Ya I Figured The Front, But Is It The One From The Ds To The Axle Or The Two Out Of The T-case
|______
|l ,[____],
l---L –OlllllllO-
()_)-()_)--o-)_)
jepmn03 is offline
post #5 of 20 Old 03-02-2009, 01:20 AM
Mike in IL
Mine were the ones from the T-case, a double U-joint thing with a steel ball. It has a name, I can't re-call it at the moment. Double something joint. Hey, don't laugh. Well, ok, I'm laughing, go ahead, I'm having my Senior Moment thing.
Mike in IL is offline
post #6 of 20 Old 03-02-2009, 01:27 AM
SHAKEnBLAKE
The Double Cardan joint. ^^You were on the right track. To the OP: I think they're usually called "angry sparrows" and you'd have a much better result in a search.
Mine were accompanied by a clunking because I waited too long to fix it. Front driveshaft. It was the "ball centering kit" inside that Double cardan joint (also sometimes called constant Velocity, CV, joint) If it gets really bad you'll end up replacing the yoke like me!
Got to www.stu-offroad.com for a beautiful write-up on a driveshaft overhaul if you've never done something like this.
Ohio4x4.com
SHAKEnBLAKE is offline
post #7 of 20 Old 03-02-2009, 01:42 AM
Dmcastino
Are they African swallows? If so they could probably carry a coconut.
Edit: sorry its almost 3 am, I may or may not be a little slap happy
Dmcastino is offline
post #8 of 20 Old 03-02-2009, 01:50 AM
bmxrules39
what they are trying to say is it is not usually the u joint that makes the noise, it is the CV joint in the front axle making that aweful low speed squeal...
This is located on the TC side of the front driveshaft, it's a "ball and socket" looking thing with a little spring in it, dont loose the spring!
This should help:
http://www.stu-offroad.com/axle/driv...iveshaft-5.htm
bmxrules39 is offline
post #9 of 20 Old 03-02-2009, 03:55 AM
bblhead
I spent about $30 for all three for my front DS. It silenced the Swallows/Sparrows/F-in birds.
Ben
HIS: 97 Sport, 4" Rough Country X-Series, 33" Super Swamper LTB, Airaid Cold Air Intake, Banks Power Exhaust, Looking to "Fix" the axles soon
HERS: 09 Unlimited Rubicon Stock.... For now!!!!
bblhead is offline
post #10 of 20 Old 03-02-2009, 04:25 AM
TheBoogieman
Disturbed
TheBoogieman's Avatar
They're sparrows not swallows.
TheBoogieman is offline
post #11 of 20 Old 03-02-2009, 07:39 AM
L8APEX1
i thought this was going to be a thread about somebodys wife/girlfriend. sorry i had to.
why fart around just replacing one, while you have everything out replace them all
L8APEX1 is offline
post #12 of 20 Old 03-02-2009, 08:05 AM
mdm
Farm Wheeler
The noise maker is the centering ball assembly found between the two u-joints at the transfer case end of the drive shaft.
You've got to disassemble the u-joints to replace it so you might as well replace them while you're there. Since you've gone this far you might as well replace the third u-joint also.
Keep in mind that free advice can frequently be worth less than you pay for it.
mdm is offline
post #13 of 20 Old 03-02-2009, 08:21 AM
LGriffith
What's this sound like, cause I think i might be having some angry birds in there. I have a super annoying squeaking noise coming from somewhere under there, I either thought it was my brakes or a driveshaft so more insight on this would be great. WHat's it sound like? What you need to replace? COst? Thanks in advance!
04 LJ|2.5" OME|RE arms|1" BL|ROKMEN|Savvy|33" MTZ's
LGriffith is offline
post #14 of 20 Old 03-02-2009, 08:30 AM
TimBrown
Where did you get the parts for 30 Bucks bblhead?
TimBrown is offline
post #15 of 20 Old 03-02-2009, 09:11 AM
TheBoogieman
Disturbed
http://www.jeepforum.com/forum/searc...archid=4156886
What's this and why is it so angry? Fropleyqk TJ Wrangler Technical Forum 81 03-23-2010 05:09 PM
03 tJ Angry swallows?? TJbarber TJ Wrangler Technical Forum 14 12-13-2007 03:43 PM
A little angry please help!! xulcuz TJ Wrangler Technical Forum 13 06-22-2007 09:09 AM
Angry Sparrows are gone!! jeepaholictj TJ Wrangler Technical Forum 0 06-16-2006 07:04 AM
Angry Sparrows still there!!! jeepaholictj TJ Wrangler Technical Forum 1 06-07-2006 10:06 AM
