Angry sparrows or squirrels or what?? - JeepForum.com
post #1 of 17 Old 10-11-2009, 10:54 AM Thread Starter
Bubba3200
05 Rubicon...65,000 miles....When traveling long distances (2-3 hours of driving) I get this sound that is related to the jeep speed not engine speed. It sounds faint like a leaf caught in the heater fan. Raise the fan but the sound dosent follow. Push the clutch in at speed and the sound is steady with the jeep speed. Sound is not very loud but it is there.. I know about the angry sparrows etc and I have pb-blasted the drive shafts u-joints and the front wheel u-joints and it seems to go away for a good while. After rain and a few months of driving the noise comes back but only after a few hours on the road. Like when they get good and hot. I pb-blast and all is good for a good while. Am I masking some trouble down the road by doing this? And do you just go in and change out all the u-joints, because how do you tell which joints are making the noise. I am a good shade tree mechanic but have never replaced u-joints before. Too bad these joints arnt greaseable. Thanks for the help.
Bubba3200 is offline
post #2 of 17 Old 10-11-2009, 12:49 PM
XXRider
Rebuild the drive shaft, you REALLY don't want it to lock up when you are driving. Not sure if the Rubicon's drive shaft is the same but here is Stu's article on how to do it for a regular TJ, doubt it is much different if any.
TJ Front Drive Shaft CV Maintenance
A must-read for new TJ owners/forum members
XXRider is offline
post #3 of 17 Old 10-13-2009, 10:24 PM Thread Starter
Bubba3200
The noise sounds like it is coming from the front. The front drive shaft dosent turn when in 4-H correct? So this would be the rear shaft but the noise sounds like it is coming from the front. Little confused here????
post #4 of 17 Old 10-13-2009, 10:34 PM
Alexia
Alexia's Avatar
The drive shaft is turning all the time in any mode.
2004 Jeep Wrangler Unlimited, Automatic
RC 2.5" Lift - RC 2.5" Rear Track Bar Bracket - JKS 1.25" Body Lift - JKS Front Disconnects - JKS 1" Budget Motor Mount Lift - Spidertrax 1.25" Spacers -
Power Door Locks with Keyless Entry
Alexia is offline
post #5 of 17 Old 10-13-2009, 10:46 PM
alecmcmahon
Remove the front drive shaft and drive around, if the noise is gone, you need to replace your u-joints and cv joint.
-alec
alecmcmahon is offline
post #6 of 17 Old 10-15-2009, 10:35 AM Thread Starter
Bubba3200
OOPS!!!! I mean the front drive shaft dosent turn in 2-wheel mode does it?? One poster says the front shaft turns in any mode? If this were the case then what disconnects the front drive? I have been driving down the road with the noise in 2-wheel and then put it in 4-H and no different with the noise. The sparrow noise only comes when I am on the road (hwy speeds) for about an hour or so. When things heat up I am guessing. So I guess what I am asking is this. If the front shaft dosent turn when in 2 wheel drive and the noise is coming from the front where is this noise from? The noise sounds like it is from the dash area. I am just trying not to change un-necessary parts.
post #7 of 17 Old 10-15-2009, 10:50 AM
mdm
Farm Wheeler
Any time a stock TJ is rolling the front drive shaft is rotating.
Do as suggested and remove the front drive shaft and drive the Jeep. This will tell you if the noise is from the shaft or not.
Keep in mind that free advice can frequently be worth less than you pay for it.
mdm is offline
post #8 of 17 Old 10-15-2009, 10:51 AM
Xlr8n
1967 JK Wrangler
Yes, the front driveshat shaft turns even in 2wd.
To easily identify the shaft as the problem you can simply disconnect the front of the shaft from the pinion yoke and lash it to the frame/CA with a rope or strap. and take it for a spin. If the noise is gone, it's your DC joint. Obviously DO NOT put it in 4wd with it tied to the frame.
Xlr8n is offline
post #9 of 17 Old 10-15-2009, 11:03 AM Thread Starter
Bubba3200
If the shaft (front) turns all the time then what happens in the transfer case when you flip to 4-H or low. If the shaft is spinning all the time then in the transfer case in 2-wheel the gears for 4-wheel are in neutral and then when you flip the lever it engauges with the shaft to hook up the 4-wheel drive?? Is this how it works?
post #10 of 17 Old 10-15-2009, 11:07 AM
NotURMailman
NotURMailman's Avatar
The shaft turns because you don't have an axle shaft disconnect or manual hubs, so it is connected to your tires and turns with them. When you engage 4wd it couples the front output shaft in the t-case to the rear output shaft. When in 2wd the front output shaft is not connected to the front and just idles in the case. (or that's the most simplified explanation I could come up with).
equipped... And loving it!
I drive on the right side, what's wrong with you?
It's difficult to take you seriously. It's like you're an easily perturbed autistic teenager who's drunk typing the whole time.
NotURMailman is offline
post #11 of 17 Old 10-15-2009, 11:13 AM Thread Starter
Bubba3200
Thanks......I am sorta of brain dead this am.....I need to see sunshine. Tired of all this rain.
post #12 of 17 Old 10-16-2009, 09:21 AM Thread Starter
Bubba3200
To change out the u-joints what is everyong going with. I would like the greasable ones not the needle adaptor but the ones you can do with a regular grease gun. Jeep for the most part is a street jeep........thanks.....I see you need 5 u-joints??? Part numbers?? Nappa?? 05 Rubicon
post #13 of 17 Old 10-16-2009, 09:24 AM
Gymguyjeep
Sounds like a bad u-joint. Replace them.
2004 TJ Wrangler Rubicon - 5.25" Total Lift, Antirock, Rokmen Short Arms, Various Skids, Winch, 35" MT tires, Roof Rack.
Matching Off-Road Teardrop Trailer.
1993 XJ Cherokee - 3" Lift, 31" tires
Previous Jeeps - 1981 CJ-5, 1985 CJ-7
Gymguyjeep is offline
post #14 of 17 Old 10-16-2009, 11:13 AM
MJMPC
Next time you hear the noise just spray one thing at a time,rear driveshaft drive it if you still have the sound spray the other shaft drive it and so on.
MIKE
MJM Powder Coating
Elizabethtown Ky.
MJMPC is offline
post #15 of 17 Old 10-17-2009, 11:51 AM Thread Starter
Bubba3200
Are spicer's 5-760x the way to go on the driveshafts? And I need 4 or 5 u-joints?
Nv 3550 On 4 Angry Squirrels. moonshinefuel YJ Wrangler Technical Forum 337 07-09-2012 12:46 PM
2.5 4 Angry Squirrels Jeep Owners Truggy YJ Wrangler Technical Forum 120 05-31-2012 07:19 AM
Angry Squirrels? or...trak Loc? gregdean13 TJ Wrangler Technical Forum 4 01-12-2010 05:57 PM
I have new found respect for the 4 angry squirrels.... XJtheTanK YJ Wrangler Technical Forum 15 11-01-2009 10:56 PM
How to TAX your four angry squirrels Thee_Nickster YJ Wrangler Technical Forum 16 06-16-2009 08:22 PM
