Angry Sparrows - JeepForum.com
post #1 of 11 Old 09-09-2006, 05:00 PM Thread Starter
Hitmanx800
Angry Sparrows
ok so i need to do my front drive shaft, but my local Mech told me like 200-250, should i get it rebuilt or just buy a new one? i have about 3" of lift right now but plan to go to 3.5RE or 4.5RE in the future. so i'm just curious what you guys would do.
1998 Wrangler Sport
OME 2.5HD
JKS Front/Rear Adj. Trackbars
Home Made Disconnects
D30/D44 3.73 Trac-lok
Cragar Black Soft 8's & 32x11.5 BFG MT
Hitmanx800 is offline
post #2 of 11 Old 09-09-2006, 05:08 PM
Marn
Station Wagoneer
Marn's Avatar
1973 FSJ Wagoneer
i would get some happiness sparrows to counteract the anger sparrows...
-Andrew
Illegitimi Non Carborundum
The Beast Build Thread:
Marn is offline
post #3 of 11 Old 09-09-2006, 05:08 PM
Red_
2016 KL Cherokee
Do it yourself for about 120 tops. Its pretty easy, a few hours tops. You just need 3 u-joints, and the centering ball. If you want to be fancy you can pick up a u-joint press as well, makes pulling the caps easier, or you can just beat em out with a hammer. All told not worth taking into a shop
Red_ is offline
post #4 of 11 Old 09-09-2006, 05:18 PM
RnEmOvr
Have Cummins, Will tow.
RnEmOvr's Avatar
$120 is nuts yet less 2+
i redid all 3 u-joint and ball centering kit (carrier bearing) for <$70
RnEmOvr is offline
post #5 of 11 Old 09-09-2006, 05:44 PM
BillR
BillR's Avatar
Where do you get the ball centering kit? NAPA?
'11 JK Unlimited Sport S, stock for now...
'08 JK X, OEM rear locker and swaybar disco!
BillR is offline
post #6 of 11 Old 09-09-2006, 05:44 PM
smunns
I did mine yesterday for around $60. Three Spicer 1310's, and a Rockford 404-0 CV rebuild kit. Bought it all at my local driveline shop.
smunns is offline
post #7 of 11 Old 09-09-2006, 06:43 PM
TJ on the Rocks
TJ on the Rocks's Avatar
I agree with the others , if you have some mechanical ability then overhaul / rebuild the front shaft yourself . Its not all that difficult . A small bottle jack type hydraulic press comes in real handy . I wouldn't recommend a BFH for in-stall of the new u-joint caps , you're more likely to displace or damage the needle bearings that way
I just did mine , 3 u-joints and the centering joint / ball for $ 75 at NAPA .
NAPA part numbers ~
U-joint part number : 210-0153
Centering joint / ball ( rockford brand ) : 260-0782
All greaseable of course , be sure to re- assemble the shaft in a manner that allows you to grease the joints without removing the shaft . Also be sure to align the slip joint to the rear yoke upon re-install . Marking the individual shaft parts before disassembly is helpful to be sure its back together exactly as it was originally built .
Take your time and have fun & save some $$$ while you're at it
TJ on the Rocks is offline
post #8 of 11 Old 09-09-2006, 06:50 PM
RnEmOvr
RnEmOvr's Avatar
a local driveline shop, was called performance clutch and drive
RnEmOvr is offline
post #9 of 11 Old 09-09-2006, 07:28 PM
gUanoTJ
There's a good writeup on how to do this on stu's page:
http://www.stu-offroad.com/axle/driv...iveshaft-5.htm
gUanoTJ is offline
post #10 of 11 Old 09-09-2006, 07:34 PM Thread Starter
Hitmanx800
i will attempt it, hopefully i can rent all the tools at autozone or something
1998 Wrangler Sport
OME 2.5HD
post #11 of 11 Old 04-26-2012, 07:36 PM
rutacon05
just buy a u-joint/ball joint press at harbor freight!
rutacon05 is offline
Angry sparrows??? tjscoot00 TJ Wrangler Technical Forum 3 09-11-2009 06:36 PM
Angry Sparrows JeepPirate TJ Wrangler Technical Forum 28 07-29-2007 09:53 AM
Angry Sparrows only after 4x4??? bigchevyman24 TJ Wrangler Technical Forum 13 07-16-2007 04:31 PM
Angry Sparrows? 05 Rocky Mounta TJ Wrangler Technical Forum 10 06-11-2007 11:24 AM
Angry Sparrows still there!!! jeepaholictj TJ Wrangler Technical Forum 1 06-07-2006 09:06 AM
