Am I an idiot? - JeepForum.com
post #1 of 13 Old 10-25-2006, 07:21 PM Thread Starter
dougolupski
It's Heep not Jeep
Am I an idiot?
Ok, so I am finally going to check my bump stops after I got my 33's a few months back. So I disco'ed the sway bar and put my jack under the driverside control arm bracket and started jacking. The tire wouldn't stuff I still had a good 7" between top and bottom bump stops and the wheel was nowhere near the fender. I am stupid or do I just need to get a really big jack or a really big mound to drive up on to check it? It was pretty far off the ground and had hardly any spring compression.
Jeep: 07 Wrangler X 2DR Black
Crime Guard Alarm with 2way pager, AFE CAI, DynaPro Exhuast
M.O.R.E. Body Lift, Source Co2 Tank, Stubbied Stock Front Bumper
KMC XD 795 Hoss Black 17" wheels and Maxxis Bighorn 305/70/17 tires
Every mod in the write up section.
Old Jeep: 04 Wrangler X Yellow Built To The Hilt For Three Great Years.
POLISH JEEP OWNERS CLUB #2
dougolupski is offline
post #2 of 13 Old 10-25-2006, 07:23 PM
TJ_Firefighter
TJ_Firefighter's Avatar
i had to use a forklift to finally be able to stuff my 33's all the way up in there...
1999 TJ
4.0L
2" BB 2"BL, ProComp Adj. Front Track-bar, SkyJacker Hydro 7000 shocks
33x12.50 Dunlop RV
Kahki Jeep Club Member #42
U.S.C.G. Jeep Club Member #1
Firefighting Jeep #2
Soon to come: HomeFab Rockers
TJ_Firefighter is offline
post #3 of 13 Old 10-25-2006, 07:31 PM
Jerry All-Bran
Jerry All-Bran's Avatar
yes
drive up a rock
Jerry All-Bran is offline
post #4 of 13 Old 10-25-2006, 07:32 PM
YCP4x4
YCP4x4's Avatar
Originally Posted by Akula47
yes
drive up a rock
or a few fat kids!
2003 Rubicon ** SOLD **
4" Superlift
35" Mickey Thomson Baja Claws
YCP4x4 is offline
post #5 of 13 Old 10-25-2006, 07:34 PM
Jerry All-Bran
Originally Posted by YCP4x4
or a few fat kids!
I saw your first avatar laughed my *** off
Now this one....man i can't stop laughing.....GET TO THE CHOPPA!!!!
EDITmy bad off topic
post #6 of 13 Old 10-25-2006, 07:35 PM
Shrek
You need to load the opposite rear tire to get full compression. Put the right rear tire on a stack of old rims and tires or something like that, then lift the left front. I wouldn't use jackstands as they have a tendency to shift and slide out of place as the suspension moves.
Shrek is offline
post #7 of 13 Old 10-25-2006, 08:05 PM
MT3Geiger
Sure you are. Next question.
2005 Silver Rubicon, 6 speed, Dual Tops + bikini,
2" BB, 1" BL, 33x12.5x16 Boggers, Cobra 75, KC 130W slimlights, OR Fab Rock Doors, and some poison spyder diff guards
MT3Geiger is offline
post #8 of 13 Old 10-25-2006, 08:06 PM
MT3Geiger
Random hijack... Shrek, where in NW IN are you from.
post #9 of 13 Old 10-25-2006, 08:11 PM
Rawkon
or you can just go wheeling, and stuff them. all this crazy mall crawler talk.
http://www.offroadworld.net/gallery/Rawkon/149491.jpg
(edited for blackrubi04)
02 tj RE 3.5 super flex, big daddy tie rod, RE adjustable Track bar, RE quick discos, Currie Steering box brace, Currie Steering box skid,, 33x12.5x15 trxus MTs on black stealies
Rawkon is offline
post #10 of 13 Old 10-25-2006, 09:08 PM
cj847
stuffing
First....the disclaimer that advice you receive on the internet could be not only bad advice it could actually be dangerous.
imho.....you can't check clearance until you have two opposite wheels off the ground. Since you're checking this, I assume you have at least one locker. The easiest way I've found to check it is to drive across a shallow ditch at a 45 degree angle. You will soon find your left front stuffed, your right rear stuffed, and your RF and LR off the ground (don't get crazy here, you just need the wheels an inch or two off the ground).
PS> from this spot that first step out of the jeep is a long drop, be careful. Also, do this in dry conditions so the ditch walls don't cave in. The jeep will also rock back and forth with your pinky finger.
Another way may be to jack up opposite corners until the other two tires leave the ground but the ditch method is a lot more fun.
cj847 is offline
post #11 of 13 Old 10-25-2006, 09:45 PM Thread Starter
dougolupski
It's Heep not Jeep
Thanks, I was planning on taking it out to a little spot tomorrow after work but was curious if there is another way.
If the boss leaves early I might hook it up on the fork lift.
post #12 of 13 Old 10-26-2006, 06:19 AM
noodlestsc
X2 (here are a few of my crappy dark pictures)
http://i8.photobucket.com/albums/a30...p/CIMG5123.jpg
http://i8.photobucket.com/albums/a30...p/CIMG5134.jpg
http://i8.photobucket.com/albums/a30...p/CIMG5126.jpg
But if you just want to see how good it does before you get a chance to get offroad, just disco and drive over to your local dept store or supermarket...something that has a loading dock you can roll a wheel up on to
>>I'd rather be out wheeling in my Jeep thinking about God than sitting in church thinking about my Jeep.<<
'04 TJ. RE 4.5 superflex (3.5 springs), 1"BL, 32x11.50x15 Kuhmo Venture MTs, JKS discos, skidded, Powertrax No-Slip up front, winch, SYE, Tom Woods shaft, soon to be homemade flat TC skid
noodlestsc is offline
post #13 of 13 Old 10-26-2006, 09:09 AM
Flyinbrick
When I "only" had 3" of lift
-Michael-
1997 TJ
White Custom Long Arm with Blue Torch Fab Stretch
Wagoneer Dana 44 Front End w/ ARB, Currie Rockjock 60 Rear w/ Detroit, 37" Baja Claws, Poison Spyder Tire Carrier, Competition Corners, Flat Fenders, Front Stinger, Full roll cage, GenRight Fuel Cell, Snyper Fab Rocker Skids
Flyinbrick is offline
ok so i'm an idiot.. rennie2k5 JK Wrangler Technical Forum 10 04-20-2008 03:14 PM
I'm an Idiot. Hoobly_Goob YJ Wrangler Technical Forum 4 03-13-2008 05:39 PM
what an idiot i am kmo0189 YJ Wrangler Technical Forum 5 10-19-2006 09:16 PM
I am an Idiot. JeepinYahoo TJ Wrangler Technical Forum 1 04-01-2006 05:25 PM
OK im an idiot parpac316 YJ Wrangler Technical Forum 2 10-11-2005 09:51 PM
