Aluminum VS Steel Corners. - JeepForum.com
post #1 of 46 Old 02-14-2009, 02:39 PM Thread Starter
RVA_TJ06
The differences I see are (referencing the Genright full corners)
1. weight
2. price
Are is the extra couple hundred dollars worth going with aluminum? Also are the aluminum corners weaker??
Finally paid off...
RVA_TJ06 is offline
post #2 of 46 Old 02-14-2009, 03:17 PM
Imped
Imped's Avatar
Steel bends. Aluminum breaks. I'm still going back and forth between what I want. I love the fact that AL wheels are so light...I picked up a 20 lb 15x8 alloy rim the other day and it was like a feather. Steel wheels of the same size weigh about 28 lbs, a 40% increase. I know that aluminum will break, but it takes a lot to get it to that point. Steel bends easier than alloy will break. But, steel wheels are only $40-65 per wheel, so they are easier to replace. And steel looks great most of the time....until they rust.
OlllllllO
IndyORV
Imped is offline
post #3 of 46 Old 02-14-2009, 03:28 PM
GOLENJEEPTJ
Running Secretly Amok!
GOLENJEEPTJ's Avatar
Just how are you going to be using your Jeep?
GOLENJEEPTJ is offline
post #4 of 46 Old 02-16-2009, 08:47 PM Thread Starter
RVA_TJ06
No rocks over here really. mainly just want to prevent trail damage. oh and it's a DD.
Finally paid off...
RVA_TJ06 is offline
post #5 of 46 Old 02-16-2009, 08:53 PM
mrblaine
Wizard of Brakes
mrblaine's Avatar
1. weight
2. price
The aluminum Genright corners are stronger and lighter than steel. They are 6061 T6 in 3/16's and harder to bend than equivalent steel corners.
There is no comparison as to which to run if you are after a no compromise solution to protecting your rig.
I am Savvy
blackmagicbrakes.com
mrblaine is offline
post #6 of 46 Old 02-16-2009, 08:55 PM Thread Starter
RVA_TJ06
That's what I was looking to hear. Thanks.
Finally paid off...
RVA_TJ06 is offline
post #7 of 46 Old 02-16-2009, 09:05 PM
Jerry Bransford
Administrator
Jerry Bransford's Avatar
I regret not having taken photos of my aluminum wheel with a big dent in its edge and how it turned out after going after the dent with a small sledgehammer for these types of claims. It wasn't even forged aluminum, it was a cheapy cast American Eagle wheel.
Jerry Bransford is offline
post #8 of 46 Old 02-16-2009, 09:34 PM
fratis
fratis's Avatar
hallelujah jerry! ive seen this claim continuously on the internet for years. no one who claims aluminum will break where steel will bend ever has evidence of this. aluminum is a metal it will bend.
fratis is offline
post #9 of 46 Old 02-16-2009, 09:42 PM
mrblaine
Wizard of Brakes
mrblaine's Avatar
Oh, I don't know about all that. Here's a pic of a Mickey Thompson Alcoa Forged rim that would beg to differ.
I am Savvy
mrblaine is offline
post #10 of 46 Old 02-16-2009, 09:43 PM
Jerry Bransford
Administrator
Yep for sure aluminum can and will break but not every time as some claim.
post #11 of 46 Old 02-16-2009, 10:37 PM
QuickSilverCon
I didn't think aluminum would bend until my dad dropped his BBS rim on his A6 into a pot hole and bent the hell out of it. Now I am a firm believer.
Originally Posted by timberwolf0122 View Post
I think you are confusing the right to free speech with the right to be a **** bag, only one is protected by the constitution.
QuickSilverCon is offline
post #12 of 46 Old 02-17-2009, 01:47 AM
fratis
fratis's Avatar
thank you mrblaine you are the first ive seen to actually post any evidence. anything can break, and as jerry alluded to i wanted to help further the concept that aluminum can bend without breaking. i bend a bit of aluminum in my line of work so i truly believe in the form of corner protection they will tend to bend under low speed impacts rather then "shatter" as some automatically believe.
fratis is offline
post #13 of 46 Old 02-17-2009, 01:52 AM
mrblaine
Wizard of Brakes
mrblaine's Avatar
I can argue the other direction as well. Aluminum corners are much tougher than steel and I've actually seen cast rims bent back into shape as Jerry stated.
On the other hand, I know a few sets of Walker Evans rims that are missing chunks after being bent back after some trail damage.
The pic I put up is of a forged rim which shouldn't break like that, but 4 of the 5 in that set did, so I don't think it's anomalous.
But, the topic is aluminum corners and I will bet the cost of a set of the corners you won't break them. They are worth every bit they cost.
I am Savvy
mrblaine is offline
post #14 of 46 Old 02-17-2009, 06:56 AM
Dean O
Dean O's Avatar
Aluminum can bend, I bend it all the time in my machine shop. It will, however, break or crack a lot easier than steel because the properties of the metal just can't take repeated bending, or over bending. Steel is much more forgiving in that regard.
As for me, I've got steel wheels and aluminum corners, they were cheaper!
2000 4-dr Sport XJ- RED 3" lift, moabs and 31" MTs
'97 TJ Sport- BLACK-2" lift and 32"s
Dean O is offline
post #15 of 46 Old 02-17-2009, 07:14 AM
Doctor7474
Aluminum is much more susceptible to work hardening then steel is, and has no memory.
http://en.wikipedia.org/wiki/Work_hardening
Doctor7474 is offline
Aluminum vs Steel Armor? TJoshX TJ Wrangler Technical Forum 14 07-11-2010 02:08 PM
Aluminum or Steel wheels. hmartinez JK Wrangler Technical Forum 5 09-25-2009 04:13 AM
Which Radiator: 2-Row Steel or 1 -Row Aluminum? roadking TJ Wrangler Technical Forum 59 06-23-2009 10:42 AM
Aluminum diamond plate corners damian H YJ Wrangler Technical Forum 4 01-14-2006 09:55 AM
Wheels Steel Vs. Aluminum TimberViking TJ Wrangler Technical Forum 7 04-26-2002 07:35 AM
