Aluminum/Plastic radiator crimp seam leaks. - JeepForum.com
post #1 of 6 Old 09-22-2017, 11:46 PM Thread Starter
btn
Has anyone ever tried tightening the metal crimps around the leak tighter with a vise-grip? Any long term luck? Thanks
2000 TJ, 4.0L, 4" suspension lift, 35s, rear D44 and front HP30 both with ARBs. AX15, 4:1 T-case.
btn is offline
post #2 of 6 Old 09-22-2017, 11:54 PM
toximus
Not the answer to your question but leaks or weeps? Mine weeps when the temperature changes.
Hopefully some day somebody will make a good radiator for us.
toximus is offline
post #3 of 6 Old 09-23-2017, 03:58 AM Thread Starter
btn
A very slow leak with drops forming.
btn is offline
post #4 of 6 Old 09-23-2017, 06:36 AM
Bdajeep
No luck. I noticed mine doing what you speak of. I pinched them down when everything was cool. This worked for a couple months until the jeep started getting hot. Plastic busted by upper hose port.
Bdajeep is offline
post #5 of 6 Old 09-23-2017, 01:00 PM
mukluk
Crimping the tabs down a bit on the original radiator on my '00 kept me from having to replace it for about a year, but it eventually had to be replaced anyway. So yes, it does work, but it's more of a short term solution to delay the inevitable.
2000 TJ SE
2005 LJ Rubicon
mukluk is offline
post #6 of 6 Old 09-23-2017, 01:49 PM
Jerry Bransford
Administrator
Jerry Bransford's Avatar
The seams are chemically sealed, those crimps are not what actually seal it so it's leak-free. Once it starts leaking from the seams it's time to replace it since it's not far from coming completely undone.
For a replacement, I'd stick with another OE Mopar radiator. Few aftermarket radiators cool as well and store brands are junk. And don't see a radiator pushing 2 or 3 rows as an improvement. The number of rows in a radiator is no direct indication of its cooling capacity even though some try to make you think it is.
Jerry Bransford is offline
