#76 | |
aren't you worried that the belt will slip outward causing a misalignment then go flying off?
Vehicles: 1998 Wrangler Sport w/ 5.2L 318 Swap 1998 Grand Cherokee 5.9 Limited - Kolak Ignition upgrade, K&N CAI, DT Headers w 3" Kolak exhaust/Flowmaster 50/Magnaflow CAT, Front/Rear Baer Drilled/Slotted Rotors, Front/Rear EBC Greenstuff Pads, Alpine CD/MP3/iPod Control Deck, RF 6.5 Power Series Separates My V8 swap thread: http://www.jeepforum.com/forum/f9/my-5-2-v8-swap-618350/ |
#77 |
No one has posted any trouble with it yet. I've been running mine like this for 6 months now and haven't had any problems. No irregular marks on the belt either. I would only worry about it if you're revving it crazy high for whatever reason.
Hold onto something... Quick!!! |
#78 | |
I am not aware of any way to align the belt on the TJ. There was not evidence of misalignment before I did the swap, so misalignment should not be an issue after I did the swap. The alternator just bolts onto the mounting surface. If alignment is good before you replace it, it should be good after. I just kept it simple and left the durango pulley on. Last edited by SnatchBlock; 02-04-2010 at 10:14 PM.. Reason: spelling error |
#79 |
I'm not trying to say it's gonna happen, only that having an unused groove on the pulley leaves the posibility for misalignment. The most common pulley to have misaligned is the power steering pulley. I was only fore warning of the posibility! It is possible, and can happen. Not to mention it only takes about 30sec to swap pulley's!
From a technician's point of view, it's impending doom. I see sutch a variety of things go wrong, I carry lots of spare parts & tools.
MY VID'S My Rear Bumper - Tire Carrier My Front Bumper/Stinger My Ammo Can Console ------------------------------------------------------ Friendship is like peeing on yourself: everyone can see it, but only you get the warm feeling that it brings. |
#80 |
I knew what you were saying in your first post and I wasn't trying to prove you wrong. You brought up a valid point about alignment.
I was just stating my experience with the durango pulley on the TJ and there doesn't appear to be an issue with alignment and I haven't had a problem with it and it is not something that worries me. I know what you mean, when you say it is possible for it to become misaligned but if the belt is tensioned properly I would have a hard time seeing how it could flucuate or jumpoff. |
#81 | |
Erik 2006 JL Rubicon, white 4.0L, Auto, 4" FT LA lift, Bilstein 5100's, Currie HD tie-rods, Napa steering stabalizer, Currie lower cntrl arm skids, FT engine/oil skid, FT exhaust, Kilby sterring skid, SkidRow radiator skid, Mastercraft grab handles, Cobra 75WX cb, Wilson 3' ant, trailguide, Mopar iPod adapter, Coverking seat covers, Warn diff guard |
#82 | |
The tensioner nothing but a spring loaded arm with a pulley on the end. It is constantly moving to compensate, and keep tension on the belt. It's not a big movement, but think of the depth of belt grooving, it's not very deep. That little bit of fluxuation as various belt driven systems cause drag, and release tension. That's where your possibility for jumping a groove comes from. Looking at the pic, the outter groove is unused, and if it were to jump to that outter groove, the reaction of the belt woud be minimal, and most likely unnoticed to begin with. It would/could cause the belt to be misaligned as it is leaving the last pulley, and entering the next pulley. That would cause the wear on the shoulder of the belt. The center belt grooves would wear as it crossed the alternator pulley, leaving the possibility to slip back into alignment, or run off one of the other pulleys. Does that make more sense?
#83 |
I don't think any one didn't understand your concern . Some are just not as concerned as others I'd say .
#84 | |
#85 |
So what alternator will work with the 03 and up jeeps? I am wanting to upgrade mine as well. I am looking for a direct bolt on type thing though. Not a bracket fabrication project.
THE "ZOMBIE SLAYER" BUILD THREAD http://www.jeepforum.com/forum/f22/building-zombie-slayer-974742/ _______________________ http://www.biteforce.net |
#86 |
A good way of finding out is going to Autozones site and bring up different years of dodge v8 alts and look at the pictures. This will give you an idea of the connectors involved. I found mine through trial and error. A 98 Dakota 5.2 and a 98 GC 5.2 have different connectors, so you could probably start there.
#87 |
I am also interested in getting a bigger alt. Anymore folks out there have success with this? My 05 4.0 needs more juice. The sterio bumps and dims the headlights.
Rich G. 2005 Wrangler 4.0, RE 3.5 Superflex kit w/ adj. front trac bar, RE Monotube shocks. Currie Adj. Rear Uppers,OR-FAB front bumper with Warn M8000 loaded with steel cable, AA SYE & T. Woods CV driveshaft, BFG 33x10.50x15, 165amp Heavy duty Alt. HID lighting, the rest are Clear lenses & LED, Shuriken AGM Battery, Pioneer Premier DEH-P7000BT, Memphis 16-MR1.1200, 2 Memphis Audio 15-MCP10D4, JL Audio 300/4v2, Infinity Perfect 5.1, MB Quart 6.5. Cobra 29LTD, Fire stick 5', vehicle security system. just4effect 10" single sub, enclosure and amp 4 sale. PM me if interested, local only |
#88 |
See my post #17
http://www.jeepforum.com/forum/f9/update-hi-amp-alternater-swap-918908/index2.html#post8742021
The opinions of worthless people, are worthless. The only problem that you have with anyone in this world, is what you expect of them. Society is no match for a stupid person. "Life Is tough but it is tougher when you are stupid" -John Wayne |
#89 |
I could not find one in a junkyard, besides for the price a new one with warranty...
I went with new.
#90 |
I'll have to do some research for my '97 2.5L. I don't have the plug connector, but instead a flat bar connector that's bolted onto the back of the alternator on two small studs.
1997 Wrangler TJ, 2.5L LO, 5 speed, RC 3.25" lift, Skyjacker shocks, 31's, Lock-Right locker in front, Bestop 2-piece Hardtop |
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
