#61 | ||
Wait. What?
#62 |
Can anybody confirm if the 160A Alternator will work with a 2.5L?
#63 |
JEEP THING
i have a 2000 tj with the 4.0... what vehicle should i look for at the junk yard to pull an alternator out of. i read through this thread already and i either missed it or it wasnt clear what i need to look for. what year durango or other vehicle? does it have to be a v8? with a/c? anything else? thanks
Associates Degree in automotive technology Toyota Expert Chassis Technician ASE: A1(engine repair) A3(manual drive train and axles) A4(suspension and steering) A5(brakes) A6(electrical/electronic systems) OIIIIO |
#64 |
For those who changed pulleys, is the pulley you ar erunning Larger or smaller than what came on the new Alt?
That will change the output. Maybe they are regulated somehow, but I would think at various RPM the output would be different.
Red Jeep Club Member # 269 '04 Wrangler 'X' Rubicon Express 2 in lift 31x10.5 Goodyear Duratrac 15X8 Soft 8's w/4.0" backspace |
#65 |
you are correct, the pulley will effect output
Built not bought!!! 2005 Rubicon Unlimited, 5.5 inch custom long arm, 1 inch daystar body lift, River Raider Snorkel, Custom bumper/winch mount, sliders, tire carrier. 37x13.50 R15 interco SSM-16's Bushwacker flat fender. Custom 1/2 cab. Hyline hood vents. Custom tonnue cover and tool box. HID-X off road lights, LED driving lights |
#66 |
A smaller pulley = higher RPM = higher output at low engine RPM
You can measure the stock pulley, and the replacement, then just do the math. You can figure out a percentage of over stock performance.
MY VID'S My Rear Bumper - Tire Carrier My Front Bumper/Stinger My Ammo Can Console ------------------------------------------------------ Friendship is like peeing on yourself: everyone can see it, but only you get the warm feeling that it brings. |
#67 |
subscribed
97 TJ PD club member #007 |
#68 |
I believe most are just changing the pulley from 7 grooves to 6, not actually changing the diameter.
The opinions of worthless people, are worthless. The only problem that you have with anyone in this world, is what you expect of them. Society is no match for a stupid person. "Life Is tough but it is tougher when you are stupid" -John Wayne |
#69 |
My pullys were both the same size. One was 6 groove,the other seven. Since the only problemwas a groove,I left it alone.
Hold onto something... Quick!!! |
#70 |
from what I have read in the past as long as the pulleys are about the same diameter you just use the six grooves that allow the belt to run true , no need to swap pulleys its just an extra groove and don hurt a thing
#71 | |
#72 |
I installed a 136 amp alternator from a 2000 JGC on my 2000 Sport, no problem...
#73 |
#74 |
Nope. It's an easy upgrade to install the heaver wire...
#75 | |
Under high stress, and high RPM a belt actually fluctuates, and it can actually be seen on the tensioner pully. You can look at one when a motor is being reved high, and you will see the tensioner moving back and fourth to keep proper tension. There is a possibility that with an extra groove, and the belt not riding on the shoulder of the pulley, it could jump to the next groove. The belt jumping a groove will cause wear against the grooves in the belt, cause the belt to grab at the shoulder & jump off the pulley, jump off another pulley from misalignment, or possiply shredd the belt. I have accidentally had a pulley misaligned by 1/8in or less. 500mi after I installed it, the belt shredded! I checked it every possible way to clear my name, but turns out the only thing I could find wrong is that I didn't have a pulley aligned correctly. That left me getting reamed by the boss, and a fire chief & 3 fire men that had a rescue truck fail on the way to a call! Granted your not driving a fire truck, but you get the point!
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
