#46 | |
For those of you interested...
I was able to track down my stock alt size. '03 TJ with 4.0l. It has a 117a alternator in it, with the following designations: TN 121000-3821, 56041 864AB.
The opinions of worthless people, are worthless. The only problem that you have with anyone in this world, is what you expect of them. Society is no match for a stupid person. "Life Is tough but it is tougher when you are stupid" -John Wayne |
#47 |
At least for a 2000 TJ, the factory part numbers for the stock alternators are as followed along with their AMP rating:
56041565AA 1 ER0 117 Amp 56041685AA 1 ER0 81 Amp I have the 117A unit in mine and want to upgrade to 160A myself for winching reasons.
Mike Fox My Jeep: 00 Wrangler Sport 4" RC LA full suspension system axles (30,8.8) with 4.88 gears ARB F/R SYE and CV rear driveshaft Currie HD steering (Thanks Savvy, Awesome customer service) GY MT/R Kevlar 35x12.50x15 on 15x10 American Racing AR23 Smitty front and rear bumpers w/rear tire carrier Smitty XRC8 winch w/synthetic rope Bestop soft top with tinted windows Smittybilt rear corners and 3" flares, rock sliders with step and 3" front tube fenders Wife's Jeep: 07 Wrangler Unlimited Rubicon 4dr Red Rock Crystal 3" lift with MX-6 adj shocks. Stock other than that. |
#48 |
I just ordered this one.....99-00 NEW JEEP CJ WRANGLER YJ HI OUTPUT ALTERNATOR 175A
175amps - $200 no core - NEW - Bolt in........
99TJ - 4.0 5spd Currie HP9in rear 35 spline Detroit/HPD44 ARB chromos/Banditt One ton steering/ 35x12.50 BFG MTS/Blahblahblah 04 Grand Cherokee Limited V8 - D/D |
#49 | |
#50 |
The difference in the 02 and older are the mounting bracket and location of the alt and plug. if you look its mounted lower and has different positions for the mount. On 03 and newer TJs its mounted higher up and has different mounting positions. The older model durango (98-99) with the V8 5.2-5.9L with ALL power package and AC has the same mounting locations for the newer 03-06 TJs. It puts out 160a max not idle.
Midnight Blue '06 TJ//Dana 44 w/4.56/4" Teraflex w/shrt adj arms, 1" teraflex BL, discos, adj trackbar F+R/SYE, Tom Woods shafts/ARB lockers F+R/Yukon frnt axle w/760/ARB Hi output compressor/ Safari Snorkel/KC 6"+8" trails+fogs lights/Procomp Rockcrawlers/35" BFG MT KM2/Warn winch/steering box, oil pan, trans, bellyup,warn diff skids/diamond plate body armor/Olympic Rocker Guards/Herculined/CB/Amsoil all the way around, and a few more things /l ,[____], l---L-OlllllllO- (_) ) ()_)-o-)_) |
#51 |
I just pulled the trigger on my 98 TJ with a 2.5L. I installed an alternator I bought from the classified section of this forum. I bought a Denso #5602 7913 out of a Jeep Grand Cherokee w/ a 5.9L. I changed the pulley from the 7 groove to a 6 groove and changed the plastic wire guard. I did not upgrade the alternator to battery wire. The only issue I had was getting the new alternator into position, I had to push it up from under the jeep, the factory clearances for the 90 amp did not allow the space for the larger 136 amp alternator.
I took my newly purchased alternator to Reily Zone to get it checked out prior to installation, just to make sure I hadn't purchased a dud. Seems to work fine, my 4 KC light are significantly brighter or maybe I see what I wanted to see. |
#52 |
so would this work on an 02 TJ?. 4.0L
#53 |
intentionally left blank
#54 |
i mean i did, i just didnt want to spend the money for one and end up having to take it back so i wanted a stright anwser...sorry for asking a question
#55 |
Everyone get along now. Also,if your vehicle is not listed look at your connectors and go to the junk yard. You can always do your own research. Then post it upon here.
Hold onto something... Quick!!! |
#56 |
So for us 03 and up guys, specifically 06, which seems to be different in the Autozone system what alternator options do we have. I found the 165 A unit from Load Boss, but it only states up to 05 model year.
#57 |
Thanks for the advice. The swap was easy. Oh by the way you can swap out the old pulley and install it on the new one. Its works Great!!!!!!
#58 |
Wait. What?
#59 |
1999 Jeep Wrangler 4.0 Liter. Swap it with a 2002 Dodge Durango 160 amp Alternator. I took of the pulley from the factory Jeep alternator and put it on the new alternator. The factory clip on my jeep fit perfect in the new alternator. I did have to use a step bit on the ring terminal to make it fit. Install went perfect.
#60 |
Guy's, don't forget that with more amperage you need to increase the size of your primary wire to the battery. I assure you that the factory wire was barely enugh to handle the factory alternator output. I would use a minimum of 4GA, if not 2GA wire to be safe. I didn't notice it any where in the thread, so ignore me if I missed out on that!
MY VID'S My Rear Bumper - Tire Carrier My Front Bumper/Stinger My Ammo Can Console ------------------------------------------------------ Friendship is like peeing on yourself: everyone can see it, but only you get the warm feeling that it brings. |
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
