Quantcast Alternator Swaps - Page 2 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > Alternator Swaps
Rock Krawler Suspension's for BLOW OUT prices!!!Great deals on Mickey Thompson Tires @ Jeephut.comRCV Heavy Duty Axle Shafts Now Shipping at Baseline4x4.com
Old 11-06-2009, 12:46 PM   #16
Benderff
intentionally left blank
Benderff's Avatar
Thanks for the update F9K9. I have to add I think that is the cleanest looking engine I have seen on here.
Benderff is offline   Reply With Quote
Old 11-06-2009, 01:19 PM   #17
dbbd1
dbbd1's Avatar
I thought you had to do more mods to get it to fit. Direct bolt-on with just a pulley swap? Sign me, it's next on the list. Thanks
The opinions of worthless people, are worthless.
The only problem that you have with anyone in this world, is what you expect of them.
Society is no match for a stupid person.
"Life Is tough but it is tougher when you are stupid"
-John Wayne
dbbd1 is offline   Reply With Quote
Old 11-06-2009, 01:27 PM   #18
cyberiv
is that 160 amps at idle or running?
cyberiv is offline   Reply With Quote
Old 11-06-2009, 08:53 PM   #19
F9K9
Semper Fi
F9K9's Avatar
Thanks but, that is only because I like to wrench and I tend to attract grease and crap in my eyes!
That is probably no where close to output at idle. I can't help you out there, sorry.
I am only telling you that it was a pnp from a '98 alt to my '03 Rubi.
I basically got involved here because I saw that 5-90 was posting up. He saved me countless times when I was a XJ noob on NAXJA.com
I have read about the pulley changes and other requirements for various yrs but, for my situation, it was sweet. I did replace the belt, but there was not a size change. I just carry the old one as a spare.
For those who have fought for it, FREEDOM has a taste that the protected will never know."
'03 Rubicon w/a few changes.
F9K9 is offline   Reply With Quote
Old 11-06-2009, 09:09 PM   #20
joe03dodge
i recently did this. i got a alt. for a 99 dakota it is a bigger case but it bolted rite up and pluged in. It made a big diffrence on the power when using the winch. i did add a 6 gauge wire from the alt. to the battery..
1999 jeep tj 4.0 5spd
R/C 4"x lift 35-12.5-15 swampers
8.8 detroit locked with 4:88s
Dana 30 front with 4:88
i live i ride i am JEEP!
joe03dodge is offline   Reply With Quote
Old 11-06-2009, 09:09 PM   #21
N8Doggz
Originally Posted by F9K9 View Post
My 160 amp alt is for a '98 Durango and works for either V8 for that year. Mine is an '03. Direct plug-n-play.
THanks!!! i have been looking for this! appreciate it!
Midnight Blue '06 TJ//Dana 44 w/4.56/4" Teraflex w/shrt adj arms, 1" teraflex BL, discos, adj trackbar F+R/SYE, Tom Woods shafts/ARB lockers F+R/Yukon frnt axle w/760/ARB Hi output compressor/ Safari Snorkel/KC 6"+8" trails+fogs lights/Procomp Rockcrawlers/35" BFG MT KM2/Warn winch/steering box, oil pan, trans, bellyup,warn diff skids/diamond plate body armor/Olympic Rocker Guards/Herculined/CB/Amsoil all the way around, and a few more things
/l ,[____],
l---L-OlllllllO-
(_) ) ()_)-o-)_)
N8Doggz is offline   Reply With Quote
Old 11-06-2009, 09:29 PM   #22
sduncan
sduncan's Avatar
I wish I knew if the 160a V8 durango would fit my 98 as a direct bolt in.....but my dad has an 03 so I will get this in it for him ASAP.
'98 TJ, G2 33 spl. D44, HP D30,ARBs,4.10s, RE 4.5 LA,33in Mickey Thompson MTZs w/Pro Comp 15x10 alloys,Smittybilt XRC8 w/Amsteel rope, LED tail lites, Rampage top
Link to my Hemi build thread http://www.jeepforum.com/forum/f9/so-begins-5-7-hemi-conversion-1277803/
FOR SALE: 4.0 motor & TF999 trans, Premier Power Welder 195 amp,Fabtech Rockers
PM me for details.......
sduncan is offline   Reply With Quote
Old 11-07-2009, 06:19 AM   #23
crusher242
crusher242's Avatar
I love a good thread without flame.
Hold onto something... Quick!!!
crusher242 is offline   Reply With Quote
Old 11-07-2009, 05:56 PM   #24
F9K9
Semper Fi
F9K9's Avatar
Why not try his on or check out the wiring when your Dad get's his?
Refreshing isn't it?
Reed
Old 11-07-2009, 08:31 PM   #25
sduncan
sduncan's Avatar
I was thinking about that right after I posted...I'll have them side by side so comparing will be easy. I'll post any new info if there is any when we do it.
Old 11-07-2009, 09:41 PM   #26
MLA 97TJ
Does anybody know if this will work on a 97 4.0?
1997 Sport w/ RE 3.5" SuperFlex, RE Monotubes, 33x12.5x15 Trxus M/T, Currie Steering, Currie Anti-Rock, front & rear Rubicon Dana 44 w/ 4.88 gears, factory air lockers, Alloy axle shafts, Superwinch epi9.0, QuickAir II, CB, Hi-Lift Jack & skid plates.
1992 CDN M101 Trailer Stock for now. Future Mods: wheels, tires, bed liner, & paint
MLA 97TJ is offline   Reply With Quote
Old 11-08-2009, 07:51 AM   #27
fatcop
Small hijack.
If a person was to go get one of these at a parts store and they required a core replacement, would they accept any old junk alternator you had laying around in trade?
fatcop is offline   Reply With Quote
Old 11-08-2009, 08:09 AM   #28
JeepRocks86
Some Call me RockDog
JeepRocks86's Avatar
subscribed.
Stretched TJ Future, Coil overs, 40s, 60/14 bolt
My Build Thread.
www.kifourwheelers.com www.indyorv.com
For Sale:
TJ 44 Combo, 4.88s, detroit, Alloy USA shafts, Disc Brakes, HD lower mounts, Clayton tube Truss
35" procomp tires with Aluminum wheels $650
(4) 5x4.5 steel beadlocks $200
3 11"& 2 13" BBCS shocks
Ford Dana 60 Rear $150
Big Daddy Offroad HD tie Rod
(4) 15x8 5x4.5 TJ, YJ, XJ, etc bolt pattern Aluminum wheels $175
JeepRocks86 is offline   Reply With Quote
Old 11-08-2009, 08:39 AM   #29
1SlowPoke
Originally Posted by fatcop View Post
Small hijack.
Yes, they would! Most places do not even check.
1SlowPoke is offline   Reply With Quote
Old 11-08-2009, 08:48 AM   #30
crusher242
crusher242's Avatar
It'll work,but check your plug set up. That's the real trick.
  • gear swaps - TJ Wrangler Technical Forum (12 replies)
  • V-8 swaps - TJ Wrangler Technical Forum (8 replies)
  • Swaps - TJ Wrangler Technical Forum (6 replies)
  • Tranny Swaps - YJ Wrangler Technical Forum (8 replies)
  • Axels swaps - YJ Wrangler Technical Forum (5 replies)
Glock Forum
