Quantcast alternator problems - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > alternator problems
Old 06-14-2009, 04:58 PM   #1
jprubicon03
alternator problems
hey i have a problem with my Rubicon it an 03', 4.0L. ya so it all started about two weeks ago when i got back from Iraq and i was home on leave. my jeep started doing these things like when im driving and i hit a bump in the road it almost feels like it drops out of gear or it goes into neutral or somthing. all of my guages start flicking like crazy, the power to everything shuts off!! so when this happens i slow down and pull of to the side of the road and let it idol usually it goes back to normal. now i was heading back to Camp Lejeune i was on 95 south and i was watching my quages and i saw that my battery level starting to go down slowy. i was like what the %$@#!!!
then it all happened at ounce, she died. i the jump started it turned on just enough to get her off the highway then she died again. so ya i think it's my alternator maybe there is somthing wrong with the connectors?! i really dont know maybe someone can help with some advise.
thanks,
SEMPER FI
jprubicon03 is offline   Reply With Quote
Old 06-14-2009, 05:17 PM   #2
bjones71087
i would check the crank position sensor. that doesnt sound like an alternator problem. shouldnt instantly die. when my alternator went out i got about 2 days off of battery alone (died on a saturday night).
bjones71087 is offline   Reply With Quote
Old 06-14-2009, 05:42 PM   #3
Knuckelhead
Knuckelhead's Avatar
Check the battery connections. Remove the cable clamps, clean and grease them...
Originally Posted by Yucca-man View Post
My experience is that poly loves to groan
Knuckelhead is offline   Reply With Quote
Old 06-14-2009, 06:17 PM   #4
Stu Olson
Stu Olson's Avatar
Please explain how the crankshaft position sensor, which is the foundation for the ignition system, causes the voltage gauge to drop or all of the gauges to start flickering, as stated by the OP?
Stu Olson
ARB Locked & Loaded
www.stu-offroad.com
Stu Olson is offline   Reply With Quote
Old 06-15-2009, 05:02 AM   #5
Skyryder
Semper Fi
Skyryder's Avatar
From your description it sounds like you may have an intermittent short. One feed wire might be grounding when hitting bumps etc. Not a direct solid short, just enough to cause the alt to over work and loose juice. Check all your supply voltage lines too, if one of these are loose it also may cause your described symptoms. I would start with the wires that feed your power distribution box (with all the relays etc.)
PS.
C 1/10 about 1970
Skyryder
'97 Black TJ - 4 banger - 5 speed
Proud user of the "K.I.S.S." Principle.
Black Jeep Society #264
Skyryder is offline   Reply With Quote
Glock Forum
