Alternator - JeepForum.com
post #1 of 27 Old 07-01-2013, 08:18 AM Thread Starter
captjanes
Alternator
what is a good high amperage alternator for my jeep? the stock 81 amp dont cut it no more. i heard people saying dodge durango. but what years and motor sizes will fit.. part numbers will be great as well
captjanes is offline
post #2 of 27 Old 07-01-2013, 08:20 AM
SlackJaw
baby jeep
SlackJaw's Avatar
subscribed. I put a beating on mine last weekend with some heavy winch pulls.
SlackJaw is offline
post #3 of 27 Old 07-01-2013, 09:19 AM
cwadej
People are using one for a 2004 Durango 4.7L.
160 amps, drop in fit.
I have the threads saved at home, search i guess could find them.
"...They will find the streets are guarded by United States Marines"
cwadej is offline
post #4 of 27 Old 07-01-2013, 11:06 AM
Gary2
It makes a difference what year TJ as to what year or model Dodge or Jeep GC is a match . They changed over the years . I think on my 99 I used one from a 98 Dodge Ram w/136 amp alt years back. Their is plenty already written about the swaps , Search tool is your friend.
Gary2 is offline
post #5 of 27 Old 07-01-2013, 02:08 PM
cwadej
that's good to know before i do it.
cwadej is offline
post #6 of 27 Old 07-04-2013, 07:01 PM Thread Starter
captjanes
I tried searching and couldn't get a answer that I was looking for. Can someone who has already swamped to a bigger alternator just tell me what vehicle they took it off please so I will know for sure that it will work
post #7 of 27 Old 07-04-2013, 07:15 PM
5-90
5-90's Avatar
1988 XJ Cherokee
I have posted a list of potential donors for 117A, 136A, and 160A units - the 117A should fit right in, the larger units will require grinding. Other pitfalls are noted, and the Cham/LSTR numbers given should be usable at any parts house.
If you are replacing your alternator with a higher-output unit, and expect to actually USE that capacity, consider a wiring upgrade mandatory.
"recon" (sic - reckon)(tm) "hihgly"(tm) "seceed"(tm)
"Outback AIDS - Alcohol-Induced Dizzy Spells"
5-90 is offline
post #8 of 27 Old 07-04-2013, 07:37 PM Thread Starter
captjanes
Where did u post this info? I have a 8500lb winch and 6 x 130watts each lights so I use alittle power but not much. The 117amp would be lots for me I would think
post #9 of 27 Old 07-04-2013, 07:44 PM
Necko2529
Necko2529's Avatar
Google 160AMP Alternator for TJ and you'll get ton of info. I actually read some on it this morning just for **** and giggles...
Rokmen TT, Rokmen control arms, Novak NV241 cable shifter, JKS 1.25" BL + 1" MML.
Anybody can take advice if it doesn't interfere with their plan.
RIP "Prescott 19" Prescott Fire Department
Necko2529 is offline
post #10 of 27 Old 07-04-2013, 10:23 PM
OhSixTJ
Junior Member
I have 4 130w lights plus factory fogs and just headlights and fogs alone make my voltage dip bad. And I supposedly have a 117a alternator. I'll be taking it to test it tomorrow, just to make sure.
OhSixTJ is offline
post #11 of 27 Old 07-04-2013, 10:34 PM
Knuckelhead
AFSOC Retired
Knuckelhead's Avatar
What Jeep do you have?
Filling in your profile would help to understand what your dealing with...
Knuckelhead is offline
post #12 of 27 Old 07-04-2013, 10:40 PM
Necko2529
Necko2529's Avatar
Judging by his username, I think he has an 06 TJ...
post #13 of 27 Old 07-04-2013, 10:44 PM
McNasty35
I have an 04 TJ and the alternator of the same year for the darango works great. There is an extra mounting hole that sticks out a bit that I have read you may need to grind off, but I didn't and it fits fine.
McNasty35 is offline
post #14 of 27 Old 07-04-2013, 10:58 PM
Knuckelhead
AFSOC Retired
Filling in his profile would be helpful for any questions he may post in the future...
http://www.jeepforum.com/forum/f9/fi...ofiles-402432/
post #15 of 27 Old 07-04-2013, 11:23 PM
Necko2529
Necko2529's Avatar
You are absolutely right and in his case we don't know if he has 4.0 or 2.4 which I assume would make a difference.
I was just trying to be a smartass... HAPPY FOURTH!
