Alternator????? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > Alternator?????
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineSpartan Locker Promo Running now @ ROCKRIDGE 4WD plus FREELifetime LED on Sale at Baseline 4x4 Outfitters LED Light
Unread 01-12-2005, 03:50 PM   #1
2000wrangler
Alternator?????
Hi, new here today! Got a question: I have a 2000 Wrangler 4.0 and it wont start. Battery seems good just wont crank. Could this be the Alternator? I just had Circuit City install XM Radio and a new deck, could they have screwed something up? Thanks in advance for your help.
2000wrangler is offline   Reply With Quote
Unread 01-12-2005, 04:02 PM   #2
igofshn
Locked @ both ends
igofshn's Avatar
If it won't crank, try the battery. Alternator isn't the problem.
2007, 4 door, powered by a minivan engine, locked and riding on 35's.
[Jeep Pics
igofshn is offline   Reply With Quote
Unread 01-12-2005, 04:07 PM   #3
cptn_mrgn78
If the battery is good, it could be the starter.
RIP: '97 TJ with 2in Teraflex with QD's. 32in AT's. Hi-lift jack, two 10in subs and a 500 watt amp. 150watt KC Daylighters. Avalanche Engineering Rocker Knockers.
New: '05 Unlimited
cptn_mrgn78 is offline   Reply With Quote
Unread 01-12-2005, 04:18 PM   #4
airduds
Hard to diagnose with just this info. What do you mean by battery seems good? Did it crank fine after the install for a couple of days or today?
2000 Sport 4.0/both tops/5sp/4.88s/Dana 44 Truetrac rear/Dana 30 Aussie Locker front/Ramsey 9500 receiver mounted for front and rear/RE 5.5" LA/15"x10" M/T Classic II's/Dunlop Mud Rover 35's/TBT Alumi-Flex tie rod
airduds is offline   Reply With Quote
Unread 01-12-2005, 06:44 PM   #5
JeepCrazyKid
Make sure you're battery cables are tight.
Have a voltmeter? Check your battery that way. Using the radio or interior lights is not a good way to diagnose the battery.
JeepCrazyKid is offline   Reply With Quote
Unread 01-13-2005, 08:21 AM   #6
2000wrangler
battery is DEAD.......wont even take a charge
Unread 01-13-2005, 08:32 AM   #7
urbanassault
Fully charge the battery, then perform a parasitic draw test to see how many amps are draining your system. Pull individual fuses until the draw goes away. Using your factory service manual check to see if the XM system was tapped into that circuit.
urbanassault is offline   Reply With Quote
Unread 01-13-2005, 08:47 AM   #8
wile_e_mopar
Take the battery out and take it to local auto parts store, ask them to put it on the charger, they can test it as well. You can also bring the alternator into the store and they can test it. (I know auto zone does it for sure)
2002 Solar Yellow Sport-mine
2008 Jeep Compass-wife's
2006 FXDLI-mine
wile_e_mopar is offline   Reply With Quote
