Almost fixing death wobble - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > Almost fixing death wobble
The Spring DynoMax rebate is here for 2015!FS: Wrangler RGB Multicolor Fog Light LEDs: Awesome EffectBead Lock Wheels! Raceline, Trail Ready, & Trail-Gear
Unread 05-30-2015, 12:11 PM   #1
064banger
If I have death wobble and my mechanic recommends replacing all my TRE's because they are shot (which I believe).
If I only replace my track bar, can I still expect a bit of steering wheel shimmy at about 50mph? Of course the death wobble is almost completely gone.
Thanks
064banger is offline   Reply With Quote Quick reply to this message
Unread 05-30-2015, 01:09 PM   #2
jeepn4life92
What leads you to believe you have a problem with your trac bar and not the tre's that the mechanic suggested replacing?
jeepn4life92 is offline   Reply With Quote Quick reply to this message
Unread 05-30-2015, 01:13 PM   #3
RDaniel2405
RDaniel2405's Avatar
Personally, I would just do both/all of them and be done with it
MY DAILY DRIVER BUILD http://www.jeepforum.com/forum/f22/r...-tj-x-1170452/
WTB Impact Orange half doors.
RDaniel2405 is offline   Reply With Quote Quick reply to this message
Unread 05-30-2015, 01:22 PM   #4
064banger
Yes I do plan to do them all, but I wanted to start with what I have read to be the main culprit. Plus I didn't have a whole day to work on it.
The track bar was included in the mechanics quote. I've read a lot about death wobble and more often than not the suggestion is to tighten or replace the track bar. I confirmed once my old track bar was off that the ball joint end was toast. However I'm not sure if the other TRE's being bad would cause a shimmy and/or DW.
Unread 05-30-2015, 01:39 PM   #5
RDaniel2405
You can install all that in less than 1 hour and with only a few hand tools. But you should get an alignment after doing tie-rods, or DIY.
Unread 05-30-2015, 04:31 PM   #6
joe_jeep
you can get all the tie rods, and drag link for a v8 zj on ebay for about $80.00.
the tie rod is bigger and stronger than the tj stuff. the zj drag link is cheaper than a tj also.
changing the track bar is a good idea too. do it all, then get an alignment.
glfwda #6624
2005 rubicon sahara lj #592
joe_jeep is offline   Reply With Quote Quick reply to this message
Unread 05-30-2015, 04:52 PM   #7
jeepn4life92
Doing the work really doesn't take too much time. I just replaced a tie rod end on one of my jeeps this past weekend when it stripped the threads and fell out on road. Probably took longer to get to the parts store and back than it did to actually replace the tre itself. But like suggested above, I'd get a whole v8 zj tie rod. Tj and zj drag link are the same tho so just buy what's cheaper/better bang for the given brand
Unread 06-13-2015, 07:25 PM   #8
064banger
Wanted to update everyone. I got everything installed and the DW is gone, however I did want to let you know about my experience with the ZJ 4.0 Drag link (Its the DS1311 from Moog).
First of all its not exactly the same as the TJ one. It is much cheaper (which is why I bought it), but if you look at the pic below you will see that it has a longer piece of metal before the threads compared to the stock TJ one. If you look at the next picture you will see my problem. After adjusting the drag link and tie rod end to match my the old one, the tie road end and the drag link are now touching inside the adjustment sleeve. Luckily for me I was still able to get my steering wheel straight... barely. But any further adjustment (in one direction at least) is now not happening. I've not read about problems from anyone else with this upgrade, but just wanted to let you know what happened to me. Last pic is the finished product.
Unread 06-13-2015, 08:46 PM   #9
RenoF250
What is there to align? I am told it is only toe, that is easy enough to do at home.
1985 CJ7 with 1994 4.0, AMC20 4.10
2001 TJ 4.0 Dana 44 4.10 TruTracs
RenoF250 is offline   Reply With Quote Quick reply to this message
Unread 06-14-2015, 12:48 AM   #10
joe_jeep
i did mine with a tape measure. it is fine.
i have all currie suspension, so everything is adjustable to me.
but it drives so good, i gotta be damn close to right on.
a tape is accurate within an 1/8th to a 1/16th, for most that is close enough.
if it dont drive real good, go get it checked out.
glfwda #6624
Unread 06-14-2015, 01:45 AM   #11
Knuckelhead
AFSOC Retired
Knuckelhead's Avatar
I've gotten mine down to 3/32 and it works very well, keep in mind that I don't have the OEM inverted "Y" steering...
TSB Information: http://www.automd.com/tsb/jeep_m/wrangler_mm/2000_y/
Knuckelhead is offline   Reply With Quote Quick reply to this message
Unread 06-14-2015, 11:33 AM   #12
Partsmke
If the thread bottoming becomes a problem in the future, you can cut some of the excess threads off one or both the tre and the draglink, be sure and clean up the threads.
Partsmke is offline   Reply With Quote Quick reply to this message
