Quantcast Alloy USA Dana 30 and Ford 8.8 Chromoly axle shafts install write up - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > Alloy USA Dana 30 and Ford 8.8 Chromoly axle shafts install write up
JcrOffroad new Crusader TJ/YJ/CJ Bumpers available!!Black Magic Brakes, KOH Weekend Special!!Brand new! XJ Rear DIY Bumper from JcrOffroad!
Old 07-02-2007, 01:44 PM   #1
barry1me
I finally was able to install my axle shafts last week. I had been waiting a few months on the locker. For those who arent aware of Alloy USA axle shafts, they are an after market Chromoly axle shaft that is of a higher grade Steel then the OE shafts, different heating treating during manufacturing and thicker ear yokes around the ujoint caps. Once locking the dana 30 front axle and adding some bigger tires you put a considerable amount more stress on the axle shafts and yokes. The warranty supplied from Alloy is a 10 year warranty including the yokes breaking. That covers me for a long time. I also opted for the well touted Alloy Ujoints. They came well packaged, no deffects due to packing or manfacturing. To install the Dana 30 axle shafts you dont have to pull the diff cover, but since we were adding a locker to the front we combined steps. On inspecting the OE axle shafts they were in pretty rough shape due to breaking several ujoints and bouncing around on the balljoints. Removal of the OE shafts is as easy as pulling both tires off, removing caliper, three bolts that hold the bearing carrier onto the knuckle and then out come the shafts. It took about 30 minutes to pull the OE shafts out of the axle.
OE shafts Dana 30
Alloys installed
Sport TJ build
everything below has a hyperlink to the install/review
Rubicon Express Long Arm
D30 Alloy axle shafts with Alloy U joints
D30 Powertrax no slip locker
Skid row skids engine- gas tank - radiator- steering box
Expidition one trail series rear bumper and carrier
Edge Trail jammer install/review
Bestop Trailmax Aqua seat
Bestop Super top
Before you ask about a product in the Technical forums check out the product review section!
barry1me is offline   Reply With Quote
Old 07-02-2007, 01:48 PM   #2
barry1me
Since we did the front axle first, and the locker we were only able to take a few pics before the battery died in the camera
The rear Ford 8.8 axle is a breeze. remove rear tires, calipers, rotor, and Drop the diff cover (in our case pull the allen bolt that hold the plate into to push out on the axle shafts), pull the C clips out and carefully pull the OE shafts out. Once they were removed you replace the OE wheel bearings with the ones supplied from Alloy. Another nice option with the Alloy axle shafts is they have two different lug patterns that are easily changed by screwing the supplied lug studs into the two different patterns on the hub face. We stuck with the factory 5 on 4.5 bolt pattern.
Unfortunatly our camera died about two pictures into the install but here is what I did get.
removal of passengers side caliper and rotor
Driverside rear caliper
removal of allen bolt to remove the access panel to remove C clips
Alloy on the Left VS the OE on the right
Notice the two options of bolt patterns
This picture was taken the following day after the Alloys were installed and the diff was closed back up and filled. Make sure to torque the caliper bolts to the proper specification when reinstalling them.
Sport TJ build
Bestop Super top
Old 07-02-2007, 01:54 PM   #3
barry1me
I havent had a chance yet to try these out, but I feel very confident in there design. Im hoping to try them out this week at Mount morris. The people at Alloy are great people, they have a great deal of knowledge in there product and passoniate about the sport. Eric at Alloy will answer any question you have, and seemed very confident in his axle shafts. Overall this is a easy upgrade to the Dana 30 and Ford 8.8 that is relitively inexpensive for what you get. The warranty alone is worth it.
Sport TJ build
Bestop Super top
Old 07-02-2007, 03:48 PM   #4
VinoTJ
Nice work!
What spline counts did you go with?
I am looking at a re-gear with ARBs and chromoly shafts - I was looking at upgrading the D30 to 30-spline (I heard they are much stronger) and keeping 30-spline in the D44 (can carry my stock shafts as spares).
2008 Wrangler Unlimited X
VinoTJ is offline   Reply With Quote
Old 07-03-2007, 07:41 AM   #5
barry1me
Originally Posted by VinoTJ
Nice work!
I thought about doing the 30 spline D30, but then I couldnt have used a lockright locker. I have heard the 30 spline shafts are very strong. I wanted to stay with the 27 spline so if I ever break a shaft on the trail I could have used a factory shaft or find a bit easier then a 30 spline shaft.
Sport TJ build
Bestop Super top
Old 07-03-2007, 08:55 AM   #6
barry1me
here is the part number for the 8.8 axle shafts.
Note this 8.8 was from an explorer and has the 31 spline axle shafts
Sport TJ build
Bestop Super top
Old 07-03-2007, 07:49 PM   #7
bryans98tj
OK, I have looked all over for Alloy 8.8 shafts.Where did you get yours an what year/model did your 8.8 come out of?
[SIZE="1"][B]98 TJ-bought-not built
[url]www.PNWJeep.com[/url]
كافر - Infidel[/B][/SIZE]
bryans98tj is offline   Reply With Quote
Old 07-03-2007, 07:51 PM   #8
barry1me
call eric at Alloy he can hook you up with one of his vendors. Mine was out from an explorer with disk brakes
Sport TJ build
Bestop Super top
Old 07-03-2007, 07:55 PM   #9
bryans98tj
Thanks Barry
Old 04-15-2008, 06:03 PM   #10
barry1me
update:
Jeep hasnt missed a beat, running 35x15x15 TSL's and not even a hicup from the D30. Im quite impressed
Sport TJ build
Bestop Super top
Old 04-15-2008, 06:15 PM   #11
Grewe02
Cant edit my user title
Grewe02's Avatar
1980 CJ5
Originally Posted by bryans98tj View Post
Thanks Barry
If you haven't found a vendor by now, check Randy's Ring and Pinion. He has everything.
Andy, KD8EIA
| USN Jeep Hull # 66 | ΜOΛΩΝ ΛΑΒΕ |
| My Jeep's Thread | My Photobucket | San Diego Jeepers!! | VBARC | Military Jeepers |
"Don't take life too seriously, You'll never make it out alive."
"A government big enough to give you everything you want
is a government big enough to take from you everything you have"
- Gerald R. Ford in an address to a joint session of Congress on August 12, 1974
Grewe02 is offline   Reply With Quote
Old 01-25-2009, 12:41 PM   #12
davo19
what socket did you use to remove the three bolts holding the axle in?
davo19
davo19 is offline   Reply With Quote
Old 01-25-2009, 12:52 PM   #13
Greg_Volkman
nice write-up. what's the new diameter of the 8.8 shafts?
-0|||||||0-
He who hunts in a pack is still a dog. The lion hunts alone, and so do I. - Napoleon
Conducting an argument by appealing to authority is not using your intelligence; it is just using your memory. - Leonardo Da Vinci
Greg_Volkman is offline   Reply With Quote
Old 12-28-2009, 11:57 AM   #14
emev0l
I have some Ten Factory D30 shafts to install and I need to put the stub shaft slingers on, but I'm not positive what direction they go, I've seen a few write ups on this site and others and half of them are on one way and half are on the other.
This is from Stu's site:
This is from this writeup:
Can I get a for sure on which way these go on, I know the ones on the stock axle shafts go on like the ones in the writeup.
2001 TJ 4.6 Auto 4.5" AEV suspension 35's
2002 TJ 4.0 Manual 3" BDS suspension 33's
1987 Chevy 1 Ton 12" suspension 44's
1970 Cutlass 442 468CID TH400
1999 7.3 Powerstroke
emev0l is offline   Reply With Quote
Old 06-29-2010, 08:32 AM   #15
jonzer12
Originally Posted by barry1me View Post
update:
What R&P ratio are you running?
2000 XJ, 5.5 lift, locked 8.8,SYE, homemade bumper/sliders,skids, other stuff
jonzer12 is offline   Reply With Quote
Glock Forum
