-   TJ Wrangler Technical Forum (http://www.jeepforum.com/forum/f9/)
-   -   Alloy USA Dana 30 and Ford 8.8 Chromoly axle shafts install write up (http://www.jeepforum.com/forum/f9/alloy-usa-dana-30-ford-8-8-chromoly-axle-shafts-install-write-up-433149/)
barry1me 07-02-2007 12:44 PM
I finally was able to install my axle shafts last week. I had been waiting a few months on the locker. For those who arent aware of Alloy USA axle shafts, they are an after market Chromoly axle shaft that is of a higher grade Steel then the OE shafts, different heating treating during manufacturing and thicker ear yokes around the ujoint caps. Once locking the dana 30 front axle and adding some bigger tires you put a considerable amount more stress on the axle shafts and yokes. The warranty supplied from Alloy is a 10 year warranty including the yokes breaking. That covers me for a long time. I also opted for the well touted Alloy Ujoints. They came well packaged, no deffects due to packing or manfacturing. To install the Dana 30 axle shafts you dont have to pull the diff cover, but since we were adding a locker to the front we combined steps. On inspecting the OE axle shafts they were in pretty rough shape due to breaking several ujoints and bouncing around on the balljoints. Removal of the OE shafts is as easy as pulling both tires off, removing caliper, three bolts that hold the bearing carrier onto the knuckle and then out come the shafts. It took about 30 minutes to pull the OE shafts out of the axle.
OE shafts Dana 30
http://i190.photobucket.com/albums/z...e/DSC01259.jpg
http://i190.photobucket.com/albums/z...e/DSC01262.jpg
http://i190.photobucket.com/albums/z...e/DSC01263.jpg
http://i190.photobucket.com/albums/z...e/DSC01267.jpg
http://i190.photobucket.com/albums/z...e/DSC01265.jpg
http://i190.photobucket.com/albums/z...e/DSC01268.jpg
Alloys installed
http://i190.photobucket.com/albums/z...e/DSC01279.jpg
http://i190.photobucket.com/albums/z...e/DSC01280.jpg
http://i190.photobucket.com/albums/z...e/DSC01282.jpg
barry1me 07-02-2007 12:48 PM
Since we did the front axle first, and the locker we were only able to take a few pics before the battery died in the camera
The rear Ford 8.8 axle is a breeze. remove rear tires, calipers, rotor, and Drop the diff cover (in our case pull the allen bolt that hold the plate into to push out on the axle shafts), pull the C clips out and carefully pull the OE shafts out. Once they were removed you replace the OE wheel bearings with the ones supplied from Alloy. Another nice option with the Alloy axle shafts is they have two different lug patterns that are easily changed by screwing the supplied lug studs into the two different patterns on the hub face. We stuck with the factory 5 on 4.5 bolt pattern.
Unfortunatly our camera died about two pictures into the install but here is what I did get.
removal of passengers side caliper and rotor
http://i190.photobucket.com/albums/z...e/DSC01255.jpg
Driverside rear caliper
http://i190.photobucket.com/albums/z...e/DSC01257.jpg
removal of allen bolt to remove the access panel to remove C clips
http://i190.photobucket.com/albums/z...e/DSC01256.jpg
Alloy on the Left VS the OE on the right
http://i190.photobucket.com/albums/z...e/DSC01269.jpg
Notice the two options of bolt patterns:thumbsup:
http://i190.photobucket.com/albums/z...e/DSC01258.jpg
This picture was taken the following day after the Alloys were installed and the diff was closed back up and filled. Make sure to torque the caliper bolts to the proper specification when reinstalling them.
http://i190.photobucket.com/albums/z...e/DSC01277.jpg
barry1me 07-02-2007 12:54 PM
I havent had a chance yet to try these out, but I feel very confident in there design. Im hoping to try them out this week at Mount morris. The people at Alloy are great people, they have a great deal of knowledge in there product and passoniate about the sport. Eric at Alloy will answer any question you have, and seemed very confident in his axle shafts. Overall this is a easy upgrade to the Dana 30 and Ford 8.8 that is relitively inexpensive for what you get. The warranty alone is worth it.
VinoTJ 07-02-2007 02:48 PM
Nice work!
What spline counts did you go with?
I am looking at a re-gear with ARBs and chromoly shafts - I was looking at upgrading the D30 to 30-spline (I heard they are much stronger) and keeping 30-spline in the D44 (can carry my stock shafts as spares).
barry1me 07-03-2007 06:41 AM
Originally Posted by VinoTJ
Nice work!
I thought about doing the 30 spline D30, but then I couldnt have used a lockright locker. I have heard the 30 spline shafts are very strong. I wanted to stay with the 27 spline so if I ever break a shaft on the trail I could have used a factory shaft or find a bit easier then a 30 spline shaft.
barry1me 07-03-2007 07:55 AM
here is the part number for the 8.8 axle shafts.
Note this 8.8 was from an explorer and has the 31 spline axle shafts
http://i190.photobucket.com/albums/z...e/DSC01324.jpg
bryans98tj 07-03-2007 06:49 PM
OK, I have looked all over for Alloy 8.8 shafts.Where did you get yours an what year/model did your 8.8 come out of?
barry1me 07-03-2007 06:51 PM
call eric at Alloy he can hook you up with one of his vendors. Mine was out from an explorer with disk brakes
bryans98tj 07-03-2007 06:55 PM
Thanks Barry
barry1me 04-15-2008 05:03 PM
update:
Jeep hasnt missed a beat, running 35x15x15 TSL's and not even a hicup from the D30. Im quite impressed
Grewe02 04-15-2008 05:15 PM
Originally Posted by bryans98tj (Post 3921346)
Thanks Barry
If you haven't found a vendor by now, check Randy's Ring and Pinion. He has everything.
davo19 01-25-2009 11:41 AM
what socket did you use to remove the three bolts holding the axle in?
Greg_Volkman 01-25-2009 11:52 AM
nice write-up. what's the new diameter of the 8.8 shafts?
emev0l 12-28-2009 10:57 AM
I have some Ten Factory D30 shafts to install and I need to put the stub shaft slingers on, but I'm not positive what direction they go, I've seen a few write ups on this site and others and half of them are on one way and half are on the other.
This is from Stu's site:
http://www.stu-offroad.com/axle/30spline/30spline-1.jpg
This is from this writeup:
Can I get a for sure on which way these go on, I know the ones on the stock axle shafts go on like the ones in the writeup.
jonzer12 06-29-2010 07:32 AM
Originally Posted by barry1me (Post 5092132)
update:
What R&P ratio are you running?
The time now is 04:34 AM.
