1st problem- I took off my rear tire and 3rd light off. But ever since then, my brakes lights dont work. How do i fix this other then putting the brake light back on?
2nd problem- My jeep at idle after it's been running awhile will drop oil pressure to 0 and my check gauges light comes on. I've checked oil and see if anything was leaking but don't see anything. Any ideas what might be causing this?
2- Jeep oil pressure senders are notorious for failing, this could be your problem. However to be certain you need to get a mechanical gauge and hook that up, if only temporarily, to verify what your oil pressure actually is.
Seeing as your turn signals work. hazard as well I would think?? Now I'd take a look at your brake light switch, under your dash and attached to your brake pedal support.
it was the brake switch. thanks.
still working on the pressure problem.
Related Threads
Jeep Enthusiast Forums
18.5M posts
726.8K members
Since 2000
