All settings on heater/ac/fan blow only through Defroster
#61 | ||
Canadian Jeep Club Member #2 2005 Jeep TJ Unlimited |
#62 |
A/C Defrost problem... 06 Rubicon
I LOVE this board! I usually can't open a pickel jar without breaking something... and I found the vacuum hose disconnected and my A/C blows through my vents again!
You guys are all invited to Effingham, Il. "F-N-HAMJEEPCLUB.com" ![]() Send me an email if you are ever in the area. I'll take you out to our club ground for a little wheeln. timothybrown@consolidated.net |
#63 |
OMG!!! I love this forum!!!
I woke up today and went for a ride in the 90 degree Florida sun and as I reached down to turn the A/C on.... oh, oh!! The freakin' A/C wasn't blowing air from anywhere other than the defrost vents!! So, after about 5 minutes of searching on JF, I come across this thread. And, VOILA!!! That little hose was disconnected!!! All I did was reconnect the hose (with a tie-wrap) and it was fixed. Did I say, I LOVE THIS FORUM!!! Thank You, scotch740!! You're the best!!
[COLOR="Navy"]2005 Patriot Blue Rocky Mountain Edition Wrangler OME HD ZJ/LJ Combo Lift, OME Long-Travel Nitrocharger shocks, AA SYE + CV DS, Nth Degree Mobility TT, JKS Adj. Rear UCAs, JKS Adj. Front & Rear LCAs, JKS Adj. Front & Rear Trackbars, JKS 'Quicker' Discos, 33x10.5 KM2s on Stock Ravines, Warn Front and Rear Bumpers, Bestop Tinted Window Kit.[/COLOR] [SIZE="4"][B][COLOR="navy"][URL="http://www.jeepforum.com/forum/showthread.php?p=5322408#post5322408"][SIZE="3"][COLOR="Navy"]See My Build-Up Here[/COLOR][/SIZE][/URL][/COLOR][/B][/SIZE] [COLOR="Navy"]My other posts:[/COLOR] [COLOR="navy"][URL="http://www.jeepforum.com/forum/showthread.php?t=569601"][COLOR="Navy"]Foglight Switch Operation & Pin-Out[/COLOR][/URL][/COLOR] [URL="http://www.jeepforum.com/forum/showthread.php?t=579055"][COLOR="Navy"]OME HD Coils - Let's End the Confusion!![/COLOR][/URL] [URL="http://www.jeepforum.com/forum/showthread.php?t=571323"][COLOR="Navy"]JK 'style' bumpers for TJ? Do they even exist?[/COLOR][/URL] [COLOR="Navy"][URL="http://www.jeepforum.com/forum/showthread.php?t=588694"][COLOR="Red"]Caster? Pulling to right after lift...[/COLOR][/URL][/COLOR] [COLOR="Navy"][URL="http://www.jeepforum.com/forum/showthread.php?p=5664193&posted=1#post5664193"][COLOR="Navy"]LED Third Brake Light made out of a Tic-Tacs Box[/COLOR][/URL][/COLOR] [SIZE="2"][COLOR="Navy"][B]Blue Jeep Club Member #279[/B][/COLOR][/SIZE] |
#64 |
so to sort of revive this thread, Im sort of having the same issue. Except my vents all work. But, I still have hesitation and stalling and the cruise control doesnt work. And when I try to set the cc while in park, the Jeep will stall and if I hold it down long enough, it will die. I have checked all the connectors and hoses for leaks. I sprayed the lines and connectors with soap water and nothing.
its a 04 LJ. Thoughts? |
#65 |
Junior Member
Thanks for the link, this was the problem. The vacum hose at the frme was split about a half inch, I cut it above the split, plugged it in and it worked, now to get a new vacum line.
#66 |
My issue is that the selector doesn't even feel like it's engaging anything... When turned from one stop to another there is the 'suggestion' of detents that it is clicking through but I don't feel like they are any where near as crisp as they should be if it were actually hooked up.
I chased all the vacuum hoses and all appear to be hooked up and not split. FYI my cruise works just fine... I'm thinking maybe my linkage isn't hooked up or something. I'll do a search on troubleshooting the HVAC selector linkage to see if there's any tips on how to find out without removing the dash. Thank you for the help! -Tim |
#67 |
Cracked selector knob?...
#68 |
Knucklehead, thank you for making me want to go create a quick dunce cap and throw it on my head. For some reason when things go wrong with my rig, I always imagine worst case scenario even though any seasoned mechanic will tell you check the easy stuff first. I just KNEW it had to be a vacuum line or broken linkage because a cracked knob would be too easy.
Well, wouldn't you know. I plucked it off yesterday after I got your note and the damned thing is cracked. I'm going to take some needle nose and spin the post that way to see if it changes the airflow and if it does...Eureka! Thank you again, I appreciate the sledge hammer of reality. -T |
#69 | |
#70 |
mine will just blow out of the vents and the floor but when i turn the slector knob it doesnt change. Then knob doesnt click or even feel like it is changing anything knob or vaccumm leak?
#71 |
Pull the knob off and look at the back of it where it pushes onto the hvac post. It is most likely cracked.
OME 2.5" HD|285/75R16 Nokian Vatiiva M/T|Skyjacker Hydros|JKS Front Control Arms|JKS Upper Rear Control Arms|1" PA BL|1" Brown Dog MML|Novak 241OR Cable Shifter Linkage Red Jeep Club Member #565 My Registry Profile For Sale: Cordless Snap-On Impact Wrench WTB: UnderCover Fab No-Body Lift Skid Plate WTB: Rokmen or Currie Control Arms ↑ PM me! Ever had Death Wobble? Please respond to the poll here! |
#72 |
just got a knew knob for my 02 from the Jeep dealership for $8.38 to fix this issue. I tried a few auto parts stores and they said they do not have them, it was a dealer or junk yard item.
#73 |
Weekend Wheeler
How funny this seems to be a really comon problem... I had the same thing a few months back. a zip tie and 5 min and life was good...
#74 |
damn so walked out and checked and knob cracked lol saved me ripping the whole dash apart = AWESOME
Edit : fixed with super glue that will hold till i can get a new one ;-) thanks again JF Last edited by Skelator03; 09-14-2009 at 04:41 PM.. |
#75 |
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
