Quantcast All settings on heater/ac/fan blow only through Defroster - Page 4 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > All settings on heater/ac/fan blow only through Defroster
Old 05-26-2008, 05:45 PM   #46
gudoldboy
Davey.. You have a vac leak somewhere. You have the same issue I had. Found the split vacuum line and now no worries.
Patriotguard.org Standing for those who stand for us...
[QUOTE=Keelentime;5197679]just ordered my new bikini and bra....
Thank god this is a jeep forum, or that would have sounded a bit fruity :rofl:[/QUOTE]
gudoldboy is offline   Reply With Quote
Old 05-26-2008, 08:52 PM   #47
dz1087
Originally Posted by daveyramone View Post
I've got a similar but more bizarre problem in that the controls work perfectly normal until I get up to speed on the highway and then the HVAC goes from vent to defrost all by itself. Usually around 60mph in 5th gear. I know it's manifold pressure dependent because I can let off the gas and coast for a bit and the HVAC switches automatically back to the vent mode selected. Once I give her gas again, it magically goes back to defrost again. It does the same thing with the A/C on... accelerate = vent to defrost, decel = defrost to vent.
Ideas?
Wife's XJ currently has this problem, I'll be taking a look at it with the info from this thread ASAP.
Air Force Jeep Club - Tail# JF037AD
'03 TJ Sport, Black on White, Stock. [[Gone]]
'99 XJ, Purple, Stock but with new wheels.
Running Doorless? Check your state's Mirror Laws!!
http://www.jeepforum.com/forum/f176/list-state-mirror-laws-565361/
There can be no fifty-fifty Americanism in this country. There is room here for only 100% Americanism, only for those who are Americans and nothing else.
Theodore Roosevelt
dz1087 is offline   Reply With Quote
Old 05-29-2008, 04:50 PM   #48
StrmFshr
Same problem here! Thanx for the info!!!!
StrmFshr is offline   Reply With Quote
Old 06-02-2008, 05:09 PM   #49
zooqi
I was coming from the beach last year and suddenly air started to come from the defroster only. Ac stopped working. I thought I needed to recharge my car which I did and it did not help. I took it to a shop and the guy could not find in an hour what is going on. He told me to bring it over some other times and he needs more time to find the problem. Read this thread and followed the lines and found cracked line next to the battery. Got aquarium airline and connected the lines using electric tape and boom. Everything worked so decided to go next day and get the right hose. Aquarium airline is not strong and collapses with vacumed air but works. Two weeks later decided to spend $1.90 on the right hose and two minutes work.. is working now. You guys rock.. saved alot of money so decided to join the forume.
zooqi is offline   Reply With Quote
Old 06-08-2008, 03:15 PM   #50
02tjsport
This thread is awesome....took me 20 seconds and two searches to find my fix.
'02 TJ Sport - 3.5" RE Springs/Mono-tubes; BFG A/T 33x12.50x15 on ProComp Black Steelies; JKS: BPE's, 1.25" BL, shock conversion, front Adj. TB's, quick discos, Extended Brake lines; FT 3-link rear; JCR 1-ton Steering; Warn 6" Flares; Olympic Slider Bumpers; OME SS; Taurus Electric Fan; 4.88 Gears; D30/D44 Detroit True-Trac Front/Rear;
02tjsport is offline   Reply With Quote
Old 06-08-2008, 04:20 PM   #51
bigj1974
I have one, too. wish I could find it.
bigj1974 is offline   Reply With Quote
Old 06-24-2008, 11:16 PM   #52
02tjsport
Mine was actually leaking on the passenger side.
The vacuum line pictured runs into a T fitting on the passenger side cowl. One side of hte T goes into the cowl and other side goes down the passenger side by the battery tray and runs into the fender below the battery.
Old 06-25-2008, 01:22 AM   #53
SierraDave
I'm having the same problem with my '04. Also, my selector switch will not stop at a few of the positions. Is that normal for a vacuum leak or do I have a bad switch too?
SierraDave is offline   Reply With Quote
Old 06-25-2008, 01:32 AM   #54
02tjsport
You mean it just spins freely past?
When mine was leaking it would still click into position. But it wouldn't change where the air is coming from.
Old 07-20-2008, 02:58 PM   #55
wrx600rr
do I have to remove my battery to hook this up? I found a vacuum line dangling under the battery and I think this is where it goes but didnt know If I had to remove the battery to fix it?
nick
wrx600rr is offline   Reply With Quote
Old 07-22-2008, 02:05 PM   #56
dz1087
nick
It looks like that should connect to a vacuum reservoir on the fender. I need to look at mine but you may have to remove the battery to get to it.
EDIT:
Just read the rest of the paragraph from the FSM - Battery and battery tray must be removed to service the reservoir.
http://www.jeepforum.com/forum/showthread.php?t=565361
Theodore Roosevelt
Old 07-25-2008, 02:47 PM   #57
rebus20
I looked everywhere on mine and cant find a leak. I have vacuum at the connection going into the firewall. I pulled the lines off the back of the switch and had vacuum on some but not others. It will go from defroster to vent/floor but not to vents only. I wonder if I have a bad switch.
rebus20 is offline   Reply With Quote
Old 07-25-2008, 07:40 PM   #58
02tjsport
EDIT:
It may need to be removed to service the reservoir but there is a nipple on inner fender below the battery tray. The nipple points towards the engine. That is where mine came off. the end of the hose was dry rotted and cracked about an inch up. I cut off there and stuck the rest of the hose back on the nipple.
Old 07-27-2008, 09:33 PM   #59
triiko
...just tracked mine down too. It was the vacuum connector going into the vacuum reservoir under the battery tray. (2002 TJ Sport)
triiko is offline   Reply With Quote
Old 08-08-2008, 12:13 PM   #60
Pigshanks
Ditto for me.
Found the boot on the vacuum line under the battery tray split....A bit of electrical tape until I get a new line and all is well.
Thanks guys
02 TJ Wrangler Sahara
07 Patriot North
Pigshanks is offline   Reply With Quote
Glock Forum
