Quantcast All settings on heater/ac/fan blow only through Defroster - Page 2 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > All settings on heater/ac/fan blow only through Defroster
Old 03-29-2008, 12:21 AM   #16
sandmc
1992 XJ Cherokee
Originally Posted by Skyryder View Post
These are vacuum controlled through canisters that when vacuum is applied pull a linkage arm that swings a lever connected to the deflector door. Just fixed mine yesterday. The lever that fits into a keyed slot pulled out and was dangling free. There have been other great write-ups on this, and the fixes. Being mine wasn't broke, just pulled out, I placed a drop of silicon on the end to help hold in place, , ,time will tell if it works, so far so good. My problem was the vent door, like where the A/C would blow, not sure but I believe that these little devils are interconnected some way as a couple of them have to move to get the desired result like defrost or floor etc.
Skyryder
'97 TJ
How do you find the other write ups with the fixes? Thanks for the help
sandmc
97 TJ
sandmc is offline   Reply With Quote
Old 03-29-2008, 05:46 AM   #17
Skyryder
Semper Fi
Skyryder's Avatar
I did a forum search to find the write ups, would do it now but have to get to work (yuc) Here is a brief run down.
ok, on the left side, in the middle of the dash center you will see three silver looking cans with linkages hooked to 'em. by moving the cab/defrost/vent etc selector these will move back and forth, now mine were too. The problem is (mine anyway) was this linkage connects to an "L" shaped plastic piece that is keyed and fits into each door that directs the air flow. This L shaped thingee either comes out of the slot or breaks, in my case the center door one came out. It is really tight under there for space, I pulled the bottom and top dash out and got some room to work, even dropped my windshield. any way I got lucky and a drop of glue and mine has been fine. I did a search on this and there a some good write-ups on the fixes. I think all the doors have to move somewhat to get the desired effect from the different vents. Sorry for my rambling,,, one other hint is those silver canisters will pull right off, kinda like a clip on coil wire set up. Hope this helps and contact me again if questions come up
Skyryder
'97 Black TJ - 4 banger - 5 speed
Proud user of the "K.I.S.S." Principle.
Black Jeep Society #264
Skyryder is offline   Reply With Quote
Old 03-30-2008, 05:45 PM   #18
cal45acp
Thanks for the fix.
Took about 10 Sec. to search for the answer to my problem on here. Took only 2 Sec. to fix it. Thanks again. This Forum is a real time saver.
cal45acp is offline   Reply With Quote
Old 03-30-2008, 06:59 PM   #19
dsr30152
Thanks!!
Thanks to all who responded with this problem. I was having the exact same problem on my 2005 Jeep Rubicon UL. This really saved me time and money by not having to take it to the dealer.
dsr30152 is offline   Reply With Quote
Old 04-04-2008, 08:02 PM   #20
sandmc
1992 XJ Cherokee
I have gotten underneath and moved the switches to all the different positions. All the arms are moving, and seemingly engaging the vacuum. When it switches to A/C or blowing in the face, it sounds like it is engaging, but the airflow remains on feet and defrost. Could it be that I have something inside that is preventing the damper from closing completely? Last summer, with the top off, I had some dirt daubers build a nest inside my middle vents. Is there a way to look inside the dampers and check for obstructions? Or is this something I need to let a mechanic do?
Old 04-04-2008, 09:30 PM   #21
Skyryder
Semper Fi
Skyryder's Avatar
Even though the metal arms are moving the plastic keyed piece that is inserted into the door itself may be broke or pulled out just far enough so as not to move the door, these are kinda L shaped white plastic. I guess if you can get your hand there while working the selector (don't pinch your fingers) to feel it out.
Maybe a mirror place right and you can see what I'm talking about.
I don't know of anyway to see the doors unless your tear the whole thing apart.
Maybe rig up a small hose on a vacuum cleaner and see what you suck out or dislodge?
Skyryder
Old 04-05-2008, 02:56 PM   #22
unlimited4x4
DUDES....Thanks for this post. I have been without the cruise control and vent selector for months. I was going to take it to the shop. Based on the photos JEEPnSon posted. thats exactly it. This forum rocks!!!
You just saved me a heck of a headache going to the stealership
05 Unlimited 4x4
I don't want to take Mommy's car. It doesn't have sky in it like Daddy's. - CJsPerson
unlimited4x4 is offline   Reply With Quote
Old 04-05-2008, 08:07 PM   #23
lashkk
Found my problem. Had two broken platic pieces at the end of actuator arms on heater box. Arms move but don't rotate doors inside heater box. Havn't found anywhere to buy just the plastic pieces though. Going to try junk yard. Can adjust the doors with a flat head screwdriver for now.
lashkk is offline   Reply With Quote
Old 04-05-2008, 08:14 PM   #24
lashkk
Just like skyrider only my arms were black on a 97 tj
Old 04-05-2008, 08:18 PM   #25
Skyryder
Semper Fi
Skyryder's Avatar
Might try J-B supper stick stuff depending where there broke at. I got lucky a were just pulled out of the keyed socket.
I did see the part listed on the net someplace ? If I can find it again I'll post it.
Skyryder
Old 04-05-2008, 08:45 PM   #26
sandmc
1992 XJ Cherokee
Found out that one of the keyed pieces is broke today. I hope that you can find the part...I have been looking this evening and have not yet been able to find one. Also, any ideas on how to get the broken key out?
sandmc
'97 Forest Green 2.5L TJ
Old 04-06-2008, 02:54 AM   #27
Skyryder
Semper Fi
Skyryder's Avatar
sandmc
Try screwing in a screw and pulling like a nail. Maybe a sheet rock type screw.
I found the part I hope, I would call 'em first and make sure it's what you need.
The last two (6 & 7) on the list, here is the link.
http://www.tellico4x4.com/index.php/cPath/408_412
Skyryder
Old 04-06-2008, 03:03 AM   #28
Skyryder
Semper Fi
Skyryder's Avatar
Found this site too.
http://www.omix-ada.com/productInfo.asp?itemNo=4886086AB
oops, this is a member only site
Skyryder
Old 04-06-2008, 01:18 PM   #29
sandmc
1992 XJ Cherokee
Just what I need
Thanks a heap! I just need to figure out which one I need.
sandmc
97' 2.5L TJ
Old 04-06-2008, 01:44 PM   #30
Skyryder
Semper Fi
Skyryder's Avatar
Here is another link, I have not needed these parts so I suggest you call 'em
and make sure it's the thingee you need.
http://www.trademotion.com/partlocator/index.cfm?action=getJointLocator&siteid=214358&cha pter=&Sectionids=0,51825&groupid=51827&subgroupid= 3267&componentid=7932&make=17&model=Wrangler&year= 1997&graphicID=WJ97140&callout=11&catalogid=2&disp layCatalogid=0
Skyryder
Glock Forum
