#1 | |
All my gauges are dead?
I was coming home today and looked down and all my gauges are dead? The only thing that is on is the airbag light? My spedo,rpm,fuel,oil,temp,battery, all that stuff is dead? Please help
Thanks, Zach
#2 |
Check the connection in the back of the instrumant panel. Might have come loose. I've read on here that it is kind of common.
'99 TJ Experience is something you don't get until just after you need it. |
#3 |
Admin, Jeep in Pieces
Pull the instrument cluster out. Takes about five minutes of removing screws and trim pieces. THen slightly bend the connectors that are exposed when you pull the cluster out, so that they make better contact with the pins on the cluster. That should fix the problem for the time being.
You can do things the right way or the wrong way. Or you can do it MY way...which is like the wrong way, only faster. Ramsey Winches | My Gallery | www.dakuda.com |
#4 |
ok thanks, i did it and it worked
#5 |
the 5 dog
I had the same problem, tho in a different car,
it turned out that the circuit board for the gauge cluster shorted, and the repair is happnin tuesday |
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
