Alignment Report for the squirrel... did I get ripped off? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > Alignment Report for the squirrel... did I get ripped off?
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineCustom Tire covers for your Jeep at Jeephut.comThe Spring DynoMax rebate is here for 2015!
Unread 12-13-2014, 02:59 AM   #1
Whizzerbike
A while back I had an actual shop do my alignment. In which I thought would start to help me solve the wandering on highway speeds.
Looking back at the sheet and a few hours of research later I found out this shop had not set the caster even close to what it needed to be. Even my toe was in way to much.. once again probably should have read over the sheet before I left, but I was in a hurry. Here are the specs of what they gave me:
Caster - Initial: L3.41 R3.79 Final: L3.85 R4.15
My final caster for each side wasn't even close to the same. As I have read the factory is 7 degrees. As for my set up with 33s and 5.5" of lift I should be shooting for 5-5.5 degrees of caster.
Toe - Initial: L3.84 R-.79 Final: L-0.60 R0.61
Which in turn means my left front has tow out and the right has tow in?
Their total on my sheet came to 0.01 degrees...
From my knowledge camber CAN NOT be changed on the wranglers and if the information I have been given is correct.. well.. this shop is a wizard and changed my camber.
If someone can tell me if what I have learned from my searches is correct I need to go back and have them reset my caster to about 5.0 degrees and put BOTH tires to tow in at or around 1/8th of an inch correct?
This is the link I have learned my information from: http://www.jeepforum.com/forum/f9/en...g-read-663777/
She thinks my JEEP is SEXY!
Whizzerbike is offline   Reply With Quote Quick reply to this message
Unread 12-13-2014, 05:29 AM   #2
jay-h
Sounds like they don't really know what they are doing, or just throwing BS.
I wouldn't place much confidence in them,but my understanding is that larger tires (deeper sidewalls) would require somewhat more toe in because of larger slip angle.
My toys
'89 Wrangler YJ
'47 CJ2-A
wife's toys
97 Grand Cherokee (ZJ)
87 MB 560SL roadster
jay-h is offline   Reply With Quote Quick reply to this message
Unread 12-13-2014, 07:19 AM   #3
TheBoogieman
Demonic Jeep Freak!
TheBoogieman's Avatar
It's your d35 front axle.
When I had 3.07s I would draft behind birds as an attempt to do the speed limit.
2000' WJ Limited 4.7L-V8/D44/Quadra-Drive/31" MT's/3" lift
TheBoogieman is offline   Reply With Quote Quick reply to this message
Unread 12-13-2014, 08:39 AM   #4
nmtj
What does your pinion angle look like in the front? With your 5.5" lift and lp30, compromises must be made between caster and pinion angle.
As for the toe measurement, dont worry about each side, just means your steering wheel is not perfectly centered, but i would like to see the .01 be -.01.
nmtj is offline   Reply With Quote Quick reply to this message
Unread 12-13-2014, 09:17 AM   #5
zackcj7
In my experience most of the run of the mill tire, alignment shops are pretty clueless when it comes to solid axle 4 wheel drives. Or mounted and balancing large mud terrain type tires. Your best bet would be to take it to a specialty shop like 4 Wheel Parts if you want it set up correctly.
zackcj7 is offline   Reply With Quote Quick reply to this message
