Alignment Opinions lifted TJ - JeepForum.com
post #1 of 9 Old 07-19-2010, 05:36 PM Thread Starter
colgatefootball
Ive had this twice now with both TJs ive had....take the thing to numerous places to get alignment, tires balanced, and people telling you about all the new parts you need blah blah....well when I lived in the DC area after 4 shops ripping me off I finally went to a more $ shop but good reputation, and they fixed it no problem, no hassles, and said aligning a lifted Jeep is different than stock....so here I am in LA and another Jeep, same problems...two alignments later its a little better but not right yet....called Hi Tech and this is what they said, on a lifted TJ 3-4" with 33s the Toe should be 0 (not toe in like stock specs) and caster 4.5-5. Right now my caster is 6.0/5.7 and wondering if thats the final piece to the Jeep driving like crap compared to every other lifted 4x4 ive owned (and thats all Ive driven since I was 16).
Opinions on caster 4.5-5.0 and toe at zero(0)?? What would my caster being a 6.0/5.7 possibly due to the handling or ride of the front end?
I have JKS adjustable control arms, any exact specific length I should have them set at? I think they set them at 1/2" longer than stock.
Thanks
colgatefootball is offline
post #2 of 9 Old 07-19-2010, 05:42 PM
viperbluelx
Never hard of running toe at zero.
04 Rubicon, 5.5" RE LA with Tri-link, 35" KM2, 4.88's
viperbluelx is offline
post #3 of 9 Old 07-19-2010, 05:44 PM Thread Starter
colgatefootball
any opinion on the caster?
post #4 of 9 Old 07-19-2010, 07:22 PM
Mousejockey
Caster seems to vary from rig to rig. Some say 6-7 works for them, others say less. I am getting the feeling that weight, both sprung and unsprung may be a factor in caster on lifted rigs.
Mousejockey is offline
post #5 of 9 Old 12-19-2011, 09:15 AM
LLCoolTJ
How oftern should you get the alignment checked? I have a '06 Rubicon with 3" lift and 33s that I have had since April 2011. This is the first off road vehicle I have owned but I know if I drove my previous cars like I have driven my TJ, the alignment would be jacked !!
LLCoolTJ is offline
post #6 of 9 Old 12-19-2011, 10:10 AM
Gary2
about 5 or so is fine for caster and even at the OE spec isn't going to create and big issues and 3/32 to 1/8" toe in should be fine . The 0 toe is wrong period
Gary2 is offline
post #7 of 9 Old 12-19-2011, 10:29 AM
flying_bosun
Every TJ owner should read and bookmark or print this: The "End-all, Be-all TJ Alignment thread"
Originally Posted by Ron Paul
“Liberty is lost through complacency and a subservient mindset. When we accept or even welcome automobile checkpoints, random searches, mandatory identification cards, and paramilitary police in our streets, we have lost a vital part of our American heritage. America was born of protest, revolution, and mistrust of government. Subservient societies neither maintain nor deserve freedom for long.”
― Ron Paul
"Did you exchange your walk-on part in the war for a lead role in a cage?"
flying_bosun is offline
post #8 of 9 Old 12-19-2011, 10:39 AM
ABQ-TJ
Excellent info!
ABQ-TJ is offline
post #9 of 9 Old 12-19-2011, 10:40 AM
Imped
Imped's Avatar
Any shop that says something along the lines of "aligning a lifted jeep is different than stock" doesn't know what they're talking about. The convention is the same--the required numbers will be slightly different based on drivetrain height and tire size. For 33's, 5* of caster is fine but you've also got to set it within the proper range of pinion angle as well. HP axles make balancing those two parameters much easier, especially when the drivetrain is really tucked up. Set toe to 1/8" in and set the control arms to place the axle such that there's no interference at full bump while achieving proper caster/pinion angle at ride height.
FYI, do this **** yourself and quit relying on others. It's easy.
OlllllllO
IndyORV
Imped is offline
alignment , align , tj , wrangler , long arm , issues , problem
Opinions on my alignment numbers needed please...are these numbers okay or way off? Stacydmcc JK Wrangler Technical Forum 3 10-08-2009 04:20 PM
TJ alignment and overall lifted vehicle "inspection"...where??? 06BlackRubicon TJ Wrangler Technical Forum 1 05-16-2009 01:37 PM
Just lifted... When to get an alignment? sailmike83 YJ Wrangler Technical Forum 13 02-11-2009 04:29 PM
just lifted, get alignment now or after tires? alecmcmahon TJ Wrangler Technical Forum 10 09-22-2008 04:09 PM
lifted tj alignment ???'s rajincajingt TJ Wrangler Technical Forum 3 10-18-2004 03:02 PM
