Alignment looks off? Supposed to toe in but look toed out?
#1 | |
So I used the do it yourself alignment where you use chalk around the center of the tire and use a tool to make a thin line as you spin the tire. My rear tires measured 62 and 1/8 inches from seam to seam. So I set my font tires to 62 inches. My tires look like they point out not in? I though perhaps I had done this wrong and tried it again from scratch. Front tires are still at 60 inches. What gives? Aren't they supposed to point inward? Any ideas? Thanks.
CHECK OUT MY LJ BUILD THREAD |
#2 |
yeah but that inward point is only supposed to be 1/16-1/8 for 33" tires...not necessarily something you will notice by just looking at it
97 tj- work in progress... Thanks to all who take the time to help transform jeep newbs into self-sufficient jeep-a-holics |
#3 |
The tires look very toed out. Is it just an optical illusion due to perspective of me looking at the front of the jeep to the rear.
#4 |
i measured the back of the front tires they measured 60 1/2 inches and the front of the front tires measured 62. Definetely something wrong.
![]() I figure if I can get the front and back of the tire to match then toe it in just 1/16th of an inch that should work right?
#5 |
Well i'm going to be installing a Currie HD steering kit on my LJ tomorrow and i'll have to align it, hopefully I won't have any issues.
Woogity boogity |
#6 |
Seems I missed a step or in the process. I figured it out. I was measuring the seem of the rear tires not the rear of the front tires. DUH!!! Thanks for the input. Now let the hazing begin.
#7 |
^^^no hazing from me, honest mistake and you figured it out...good job!
Red Jeep Club Member #454 1998 ZJ - The wife's 1997 TJ - Mine |
#8 |
you know i wondered that when i read your first post, but i figured that id offend you for asking haha. glad you figured it out, and no worries, even the moderators on here made mistakes at one point
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
