Alignment, Jeep, and The Machine - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > Alignment, Jeep, and The Machine
Attention to the TJ owners 1996-2006 NEW LED LIGHT OPTIONSBds fox ipf 2.0 racing series shocks now available at rockFS: 2007-2013 Jeep Wrangler "HALO" Angel Eye Kit
Unread 02-06-2014, 05:31 PM   #1
Vic99TJ
Hello fellow jeepers!
My stats so far: 03 Rubi 3.25 suspension lift, Metalcloak Front and Rear Trac Bars, 1.25 BL, 1 MML.Stock everything else.
I have come to the conclusion that my steering is bent. (Or just an excuse to upgrade lol) I'm goin with the ZJ stuff. It's what fits my budget.
I work for a shop and we have an alignment rack/machine.
So my question is do I go with stock numbers? I know I can only adjust toe so stock toe? Or better yet what degree of toe? And also can I use the machine to make sure the axles are centered? More like thrust angle? Thanks
Sent from my 03 Rubi!!!
Vic99TJ is offline   Reply With Quote
Unread 02-06-2014, 09:30 PM   #2
mukluk
When I installed the ZJ tie rod on my LJ I just set the toe to 1/8" toe in, seems to be working just fine for the past 15k miles.
2000 TJ SE - Rusty's 3" susp w/OME shocks, Stock CAs&TBs, 4.88, F&R Truetracs, 33x10.5 BFG KM2, Bestop tire carrier, MM10500 hydro
2005 LJ Rubicon - RC 4" X-Series w/Bilstein 5100, Stock TBs, 4.10, 33x10.5 BFG AT, Bestop tire carrier, Warn M8000, 1350 series drive shaft, ZJ HD tie rod
mukluk is offline   Reply With Quote
Unread 02-06-2014, 09:35 PM   #3
Tuffjeeper
When I asked the same question to a representative at Teraflex, he told me that 7* of caster for a stock Jeep is great, he recommended that the caster be changed to around 5* when the alignment is done on lifted vehicles. I had horrible death wobble when the caster was around 8*, changed it to 5* and its been great ever since. As a matter of fact I drove around without a steering stabilizer for quite some time because it drove so well. I'd recommend going with the 5* caster or close to it if you're doing an alignment anyways.
The Tuff Jeep Build Thread
Originally Posted by plrbear View Post
Destroyed it somehow..... It went wobble wobble wobble boom
Tuffjeeper is offline   Reply With Quote
Unread 02-07-2014, 10:32 AM   #4
Vic99TJ
Ok thanks. But I don't think I can change caster on stock arms. And what is the * for 1/8 of an inch?
Unread 02-07-2014, 10:41 AM   #5
pierps
I think he's using that as his "degrees" symbol.
pierps is offline   Reply With Quote
Unread 02-07-2014, 10:41 AM   #6
mudb8
want it rite or rite now?
mudb8's Avatar
Use cams in the front lowers.
I want your factory 07-up take-off/thrown out JK front/rear Lower Control Arms! Bent ones are perfect also as long as the bushings and cold cut rings are in good shape/useable
HighLine Hood Jeepers
TJ Adjustable Track bars
DIY highline fenders.... 34-37's under 0"-2.5" lifts
shock length, bumpstop extension, tire size chart click here
DIY shock shifters, more uptravel/better ride
2011 E-350 4x4 Van conversion
2006 Rubicon Unlimited
ASE Certified Master Tech/Fabricator @ jeepwest.com
mudb8 is offline   Reply With Quote
Unread 02-07-2014, 04:48 PM   #7
Vic99TJ
Yes I thought it was the proper symbol. And oh ya got to get cam bolts.
Unread 02-07-2014, 08:51 PM   #8
Vic99TJ
I've been doin research and came up with another question. What should pinion angle be?
Unread 02-07-2014, 09:07 PM   #9
apaTJ
The pinion angle is set with the caster. I would be most concerned with pinion angle, for the front it should be pointed directly at the output of the tcase.
apaTJ is offline   Reply With Quote
Unread 02-08-2014, 04:12 AM   #10
Jonny Jeep
Jonny Jeep's Avatar
Stock alignment data from FSM. 1/8" toe in would be 0.13 for 215/75 15 tyres.
"Giving English to an American is like giving sex to a child. He knows it's important but he doesn't know what to do with it."
Adam Cooper (19th century)
Rockauto 5% discount code can be found here... http://www.markviii.org/LOD2/products_services.htm
Online factory service manuals (FSMs) and parts lists can be viewed at http://www.jeep4x4center.com/knowledge-base/index.htm
If the link doesn't work properly, look for the service manual link under Jeep Resources at the bottom of the page.
Jonny Jeep is offline   Reply With Quote
Unread 02-08-2014, 01:17 PM   #11
JStMarie
JStMarie's Avatar
Just a tidbit, use the keyboard stroke <alt> then number pad 2, 4, 8 for the degree () symbol. So, while holding the <alt> key down type (on the number pad) 2 then 4 then 8 then release the <alt> key.
There are a bunch of built in symbols (typical IBM keyboard strokes). I find them useful from time to time.
JSt.Marie
'06 Jeep Wrangler, 65th Edition, stock.
'98 Jeep Wrangler, stock.
JStMarie is offline   Reply With Quote
Unread 02-08-2014, 02:10 PM   #12
Gary2
I think you may be OK with that statement for the rear driveshaft but not the front . Use the search tool and you will see we have gone over this many times in the past . http://www.jeepforum.com/forum/f9/en...g-read-663777/
O5 Rubi TJ, 3" BDS, Currie Currectlync, Rokmen BL , Savvy control arms w/Mc Duroflex Joints, JJ's lower front arms , Bilstein 5100, 33" Cooper STTs, Mc Track Bar
Gary2 is offline   Reply With Quote
