AIRBAG warning light - JeepForum.com
post #1 of 6 Old 04-20-2009, 11:56 AM Thread Starter
dm0ney
So a few days ago I noticed that the word "AIRBAG" was appearing in red on the dashboard instrument panel on my '99 TJ. I thought this might somehow be related to the airbag on/off switch down on the console, but I turned that to "OFF" with the key and the yellow off light lit up, then I turned it back "ON" and the yellow off light turned off, but the red warning light is still showing on the dashboard.
Would this be throwing an error code so I can check to see what the problem is? I assume an airbag isn't something I can work on myself?
Any suggestions?
Thanks.
dm0ney is offline
post #2 of 6 Old 04-20-2009, 11:57 AM
Dmcastino
Did the interior get wet recently? Check your horn, if the horn doesn't work I would bet that the clock spring not functioning correctly.
Dmcastino is offline
post #3 of 6 Old 04-20-2009, 01:00 PM Thread Starter
dm0ney
Nope, hadn't got wet. And the horn does still work.
Long ago when it was still under warranty, I had the commonly reported issue of the whole instrument panel going dead, but I had that fixed by the dealer so I'm assuming it shouldn't be a problem with the connections.
I did find some old posts - one said try pushing the corners of the instrument panel (didn't fix it - like I said, shouldn't be a connection problem) and another said it might be the Airbag Control Module. I guess that warning light does throw error codes, so that's probably my need step to see what codes I'm getting.
Thanks.
dm0ney is offline
post #4 of 6 Old 04-20-2009, 01:04 PM
GOLENJEEPTJ
Running Secretly Amok!
GOLENJEEPTJ's Avatar
Sounds like a clockspring?And the horns sometimes will still work when clock is bad.When mine went out it hadn't got wet and my horn still worked.
GOLENJEEPTJ is offline
post #5 of 6 Old 04-20-2009, 02:01 PM
PANY
Check also the poles/contacts behind the on-off switch. Some times one pole may disconnect due to vibrations, etc.
PANY is offline
post #6 of 6 Old 04-20-2009, 02:22 PM
Dravintoad
Dravintoad's Avatar
Mine comes on every once in awhile.
Give it a whack on top of the instrument cluster. That usually works for me.
Nothing to see here.
Move along.
Dravintoad is offline
Airbag Warning Light rlabbott JK Wrangler Technical Forum 5 11-28-2007 12:26 PM
Airbag Warning Light Bigmotorjammer TJ Wrangler Technical Forum 2 10-08-2007 09:12 PM
Airbag Warning Light creepycrawly TJ Wrangler Technical Forum 6 09-07-2007 09:46 PM
Airbag warning dash light Westy TJ Wrangler Technical Forum 1 12-04-2005 04:47 PM
Airbag Warning Light On usetobejeeper TJ Wrangler Technical Forum 15 05-23-2003 11:08 PM
