Airbag Warning Light - JeepForum.com
post #1 of 7 Old 09-07-2007, 06:27 PM Thread Starter
creepycrawly
creepycrawly's Avatar
The airbag light keeps coming on in my jeep. It doesnt always come on and it stays on for various lengths of time, then goes out. I dont know why and I am hoping someone has experienced this and has a simple solution. Thanks.
You can't be first, but you can be next!
creepycrawly is offline
post #2 of 7 Old 09-07-2007, 06:28 PM
Rocky529
Rocky529's Avatar
Your best bet is to take it to the dealership. If you get in an accident, there is a chance they may not deploy.
Silver Metallic finish with black dual tops - Dana 44 Rear
2.25" Suspension Lift with Old Man Emu Shocks
Performance Accessories 1" Body Lift
Daystar 1" Motor Mount Lift
Spidertrax 1.25" Wheel Spacers - 32"x11.5" MT/R Tires
Rocky529 is offline
post #3 of 7 Old 09-07-2007, 06:33 PM
marc1kim
There's a chrysler tech service bulletin that requires replacement of the instrument cluster harness. These are prone to corrosion and cause the symptoms you are experiencing. Some have remedied the problem by removing the instrument cluster and cleaning the terminals, and then coating them with dielectric grease.
05 LJ
08 JKU Rubicon
marc1kim is offline
post #4 of 7 Old 09-07-2007, 06:40 PM
marc1kim
Here's another thread detailing the TSB:
http://www.jeepforum.com/forum/f9/air-bag-light-459009/
05 LJ
08 JKU Rubicon
marc1kim is offline
post #5 of 7 Old 09-07-2007, 07:30 PM
Wheels-Up
you MIGHT have a serious problem....BUT...because of their inherant liability issues, airbag systems usually are pretty reliable. So one way or another figure it out!
I SUSPECT you have a different, very simple problem. I have it as well from time to time. The next time it comes on, place your palms at the upper corners of the instrument panel and press forward & release several times -- does it go out?
If so (as mine does), then your problem is the very common "bad connection" at the two connectors between the dash and the instrument panel. There are many threads out there about this issue as well as ways to clean & tweek the pins, grease, and reassemble.
Wheels-Up is offline
post #6 of 7 Old 09-07-2007, 07:40 PM
Luda
i have my light constantly on, might be due to it being submerged for about 20 minutes, probably shorted the hell out of it
Luda is offline
post #7 of 7 Old 09-07-2007, 09:46 PM Thread Starter
creepycrawly
Thanks gentlemen. I will check on some of these suggestions tomorrow. I wont be taking the Heep to the stealership though. If the airbags dont work, oh well, but I just want the dern light to stay off!
AIRBAG warning light dm0ney TJ Wrangler Technical Forum 5 04-20-2009 02:22 PM
Getting airbag warning light on the dash.... Smelt_one JK Wrangler Technical Forum 5 01-28-2008 02:25 PM
Airbag Warning Light rlabbott JK Wrangler Technical Forum 5 11-28-2007 12:26 PM
Airbag Warning Light Bigmotorjammer TJ Wrangler Technical Forum 2 10-08-2007 09:12 PM
Airbag Warning Light On usetobejeeper TJ Wrangler Technical Forum 15 05-23-2003 11:08 PM
