Airbag Warning Light On - JeepForum.com
post #1 of 16 Old 05-20-2003, 09:17 PM Thread Starter
usetobejeeper
usetobejeeper's Avatar
Iíve have a í99 Sahara that I bought used with no manual. Iíve ordered the manual but the airbag light is on, has 77,350 miles. Do I need to get it checked per routine maintenance or is it something else?
usetobejeeper is offline
post #2 of 16 Old 05-20-2003, 09:25 PM
Owen
Owen's Avatar
Mine has come on before. I disconnected my battery for about 30 minutes. Hooked it back up hasn't come on since...
Smuggler Re-Born.....
Owen is offline
post #3 of 16 Old 05-21-2003, 09:34 AM
StuckInMuck
Most of the time if it comes on and stays on you might have a airbag controller that failed. Mechanic told me the airbags will still work, but its just goin to show the airbag light until you get it fixed.
97 black TJ w/ a few goodies
http://www.jeepanywhere.com/
StuckInMuck is offline
post #4 of 16 Old 05-21-2003, 09:40 AM
macb
macb's Avatar
put electrical tape over it...
diconnect the battery for several minutes, if it's still there after that then take it to a dealer to get checked out OR get the code yourself and check it out (search on error codes for more info)
Good Luck - and if you work on your airbag - set up a video camera, your tradgedy could be our comedy!
3.5" Terraflex, 1" BL, Flat Belly Pan, Currie Steering, 35s, Cowl Intake, blah blah blah:
Bob Supplee:
or (405) 799-8977
Stu Olson's great jeep resource site:
macb is offline
post #5 of 16 Old 05-21-2003, 09:45 AM
Dakota
You need to get the error code for why the air bag light is on.
The reason is that there are various errors that can cause the light to come on, and at least one of them is dangerous -- that is, the airbag, under certain error condition, can deploy prematurely (i.e. without there being an accident) - such as while you are driving down the road.
So, you need to at least check the code before you decide to ignore it.
'97 TJ Sport; '07 JK X
Dakota is offline
post #6 of 16 Old 05-21-2003, 10:31 AM
CCraig
My has a fuse, not sure about the '99s.
Check that the previous owner didn't pull them!
Just a thought, Chris
'03 Rubicon - 5sp
CCraig is offline
post #7 of 16 Old 05-21-2003, 04:36 PM Thread Starter
usetobejeeper
OK so I took the Jeep to a local shop and it spit out 3 codes, but I have run numerous searches and cannot find the codes. The shop said to call back tomorrow, but the mechanic said that when the light comes on it should disable the airbags. Anyone know where to find the codes?
BTW
Thanks for the input.
post #8 of 16 Old 05-21-2003, 05:53 PM
kyousif
look at the top under FAQ
kyousif is offline
post #9 of 16 Old 05-22-2003, 09:19 AM
Jeep4fun
Jeep4fun's Avatar
My question is: why does Wranglers have airbags? I wish there was a turn off switch for both bags. Hope I never hit a tree or something when offroading
1998 Sahara---Currie lift ,35 mtr's, detroit locker and true-trac, 4-1, sye, drive shaft conversion, metal fusion flat fender, wilderness trail rack, winch, rock gear soft top, etc.
Jeep4fun is offline
post #10 of 16 Old 05-22-2003, 11:28 AM
Dakota
Nanny state is why - your mother the Feds.
Dakota is offline
post #11 of 16 Old 05-22-2003, 12:10 PM
macb
macb's Avatar
never happen...the computer governes that the airbags not work under a certain speed. Also any impact violent enough to set off your airbag - will save your face. You want the airbag.
Bob Supplee:
or (405) 799-8977
macb is offline
post #12 of 16 Old 05-23-2003, 09:12 AM
Jeep4fun
Jeep4fun's Avatar
That's good to know when I am crawling, it won't go off. I know this though, if you cross your hand over the steering wheel when you drive, when the airbag deploys, it can break your arm.
Just like you driving instructor said: hands at 2 and 10
Jeep4fun is offline
post #13 of 16 Old 05-23-2003, 06:42 PM
Tango
Tango's Avatar
thats good to know ....I didn't know about the certain speed thing ....I just pull my fuse's out when I wheel
back to the topic.... you said you bought it used ....I would check the fuse's and make sure the other owner didn't pull them out and never put them back
02 TJ 4.5" of lift , Locked Both ends, with 4.56's pushing 33X12.50 MTR's
Tango is offline
post #14 of 16 Old 05-23-2003, 07:04 PM
TroyBoyM
whatever
Excellent advice and it's something most people don't know or think of. Also, as many people hook their thumbs in the steering wheel, I see many broken wrists. Of course, given that these are often the only injuries (other than some burns caused by the deploying bags) in accidents that would've caused far worse injuries without airbags, I still encourage everybody to use them and not disable them unless absolutely necessary.
TroyBoyM is offline
post #15 of 16 Old 05-23-2003, 08:42 PM Thread Starter
usetobejeeper
OK, so the Airbag Control Module is shot, the shop is asking $265 for a new one, not including installation. Could I buy this part used, or would that be a bad idea? Can you guys point me to an online source for Jeep parts?
About í85 my sig would have read;
í78 CJ7 Rebuilt 302 with a Fireball Cam
T18 Transmission with adaptor kit
3Ē lift with 33Ē Super Swappers
8000lb Warn winch with custom bumper
I sold that Jeep and have regretted it since, but have found my way home. I bought used, and have inherited some problems, but driving my TJ reminds me how much I love these wheelers.
AIRBAG warning light dm0ney TJ Wrangler Technical Forum 5 04-20-2009 02:22 PM
Getting airbag warning light on the dash.... Smelt_one JK Wrangler Technical Forum 5 01-28-2008 02:25 PM
Airbag Warning Light rlabbott JK Wrangler Technical Forum 5 11-28-2007 12:26 PM
Airbag Warning Light Bigmotorjammer TJ Wrangler Technical Forum 2 10-08-2007 09:12 PM
Airbag Warning Light creepycrawly TJ Wrangler Technical Forum 6 09-07-2007 09:46 PM
