I've done quiet a bit of searching on here the last two days looking for a solution on the newer TJs, from 2003 - 2006, but I haven't been able to figure out anything.
However I don't even have that in my 2006 TJ. So my question is where do I start looking? I tried hooking my ODBII code reader to my Jeep but I didn't get anything back on the Airbag system, might have to get another reader for that maybe?
This may not work permanently, but pull your negative lead on you battery and reset the computer. Don't reconnect for 30-60 seconds. Then reconnect and the computer will reboot..
Yeah I tried that this morning and then the turn the key half way while holding the trip odometer and the Airbag light came back on immediately after the TJ was turned on.
I think this means there is a Wheel Sensor in my Steering Wheel? I've seen plenty of "clockspring" posts for earlier model Wranglers, but I haven't been able to find any information on 2003-2006 Wranglers! Does anyone have any advice!
Does your TJ have ABS?
That sounds more like an ABS wheel speed sensor code.
Doesn't seem like anything to do with the air bag.
Then again, I don't know if I've ever seen a US sales RHD TJ with ABS?
No I don't believe it does, I just did the front brakes I saw no wires around the braking system, not even some hanging from not be connected correctly.
I did find this online, so I've ordered it and it should be here tomorrow:
So I'm going to try that first, again I think the RF refers to the location which would be correct on my RHD TJ, and since I don't have ABS brakes, the Wheel Sensor I assume refers to the Steering Wheel.
LOL that was fantastic! I bought it from Amazon so I've had good luck with returning stuff that didn't fix an issue I was trying to solve which is why I purchased it from Amazon in the first place.
No my code reader didn't spit out a code which just the text I posted from above, so I agree I think I need to look into another code reader that can give me an actual error code from the Airbag System so I can get my Airbag light off correctly!
Is there a way to look at the VIN number to determine if my TJ has ABS or not?
I don't know if airbag codes are displayed using the key trick (key ON-OFF-ON-OFF-ON within 5 seconds, leave ON, codes displayed on odometer). Worth a try.
Just tried that and nothing, I have no check engine light and when I did it, it just said "done". Just ordered another scanner tool, should be here Friday, I'll see if that one works, if not, I'll be looking for a used Snap-On set from about 10 years ago on Craigslist.
The easiest way to see if you have ABS or not is to look for a tray under the brake master cylinder / booster assembly.
If you don't have ABS it will be an empty tray.
If you do, the ABS module will be mounted there.
Yup I realize this, but there are scanner tools out there now that support SRS/Airbag Systems and Protocols, the one I had just got I was told from the manufacturer that it would read the error code and well it didn't.
There can be a lot of reasons for the airbag light to be on. An open anywhere in the circuit is one of them.
Does your Jeep have the switch where you can turn off the passenger side airbag?
I haven't seen anything like that but I've only owned the Wrangler for a little more than a week, I'll go take some pictures and check just incase I miss it!
I was just asking because I have seen a few instances of people getting an air bag light on due to a poor connection and / or corrosion at that switch.
So I found a forum for Chrysler's talking about a bad connection for Passenger Side Airbags and they were able to fix it be disconnecting the connector, after safely disabling the Airbag System first, and cleaning the connector's and putting it back together!
So I went out, undid the battery, opened the glove box, pulled the fuses and waited 10 minutes just to be safe.
What I found next made me laugh. Here is what I found when I went looking for that connector:
The passenger side airbag wasn't even plugged in, it was un plugged and shoved up into the dash board. All I did was clean with pins with a little bit of carb cleaner on a q-tip, let it dry, plugged it back in, put the two fuses back in and then reconnected the battery. I started the Wrangler, and the Airbag light went off immediately.
I sincerely hope this helps somebody out! I wasn't expecting it to be something that easy, but the Snap-On Solus Pro gave me a place to look which I'm entirely grateful for!!!
Thanks
Grant
Related Threads
Jeep Enthusiast Forums
18.5M posts
726.7K members
Since 2000
