Air intake temp sensor - JeepForum.com
post #1 of 5 Old 10-20-2009, 06:32 PM Thread Starter
BomberJeep
2011 WK
I read this on another site. does this seem right?
a buddy did this and i didn't believe him until i gave it a shot: just move the intake air temp sensor from the manifold to the intake tube. There is plenty of wire hidden in the harness to facilitate the move, so you don't have to splice longer wires in. Just remember to plug the hole in the manifold.
The reason this works:
As the engine warms up, so does the intake manifold, this heat gets transmitted to the sensor, so it tells the ECU the air charge is warmer than it actually is, so the ECU retards the ignition timing to prevent detonation. When you move the sensor to the plastic air tube, it picks up the actual air temp and keeps the timing advanced until it senses actual hot air (like when you are sitting in traffic)
What i have personally noticed since i did this:
gained an average of 2 MPG, cruises in 5th much better, crisper exhaust note, passed Calif. emmisions without a cat. converter! Still no detonation either.
Never get between a man and his Jeep - Stacey David.
BomberJeep is offline
post #2 of 5 Old 10-20-2009, 06:39 PM
Jerry Bransford
Administrator
Jerry Bransford's Avatar
I'm inclined to call BS, at least on the part that it passed the Calif. emissions test without a cat. I'm in Calif. and the tester is required by law to check to make sure the catalytic converter(s) is still there and that it hasn't been modified. The tester will fail any vehicle in Calif. that doesn't have the factory catalytic converter installed and working properly.
Fooling the air temp sender can give a few benefits, one aftermarket performance kit includes that modification, but it's not going to pass a smog test like California's as was claimed.
Jerry Bransford is online now
post #3 of 5 Old 10-20-2009, 06:43 PM
Unlimited04
This post/info=my opinion
Unlimited04's Avatar
its a common mod apparently to move the IAT from the manifold to the tube. in fact, 05-06 TJ's came like that from the factory.
but i can confirm that the IAT stays about the same regardless, based on my observations and observations of others with 05-06 via Scangauge.
It won't improve your mileage at all.
Useful Write-Ups:
Fabrication & Build:
Funny:
Unlimited04 is offline
post #4 of 5 Old 10-20-2009, 06:43 PM Thread Starter
BomberJeep
2011 WK
Yeah I wasnt sure after the whole no cat thing in Cali. Just a quick thought tho. In Virginia Beach we dont get sniff checked or even have the ECU read out. think it would still work?
post #5 of 5 Old 10-20-2009, 07:01 PM
Unlimited04
no. it wont make a difference.
IAT talks to the computer to determine the air temp, which indicates air density, which in turn tells the computer how much fuel is needed to maintain the A/F ratio. its all hot under the hood - unless you've got a cowl true CAI, its worthless to do. even then mileage won't be effected in the long run because the computer will adjust back to its baseline.
Useful Write-Ups:
Funny:
Mismatched Intake Air temp sensor InEmberClad YJ Wrangler Technical Forum 6 02-10-2016 10:00 AM
intake air temp sensor voltage? thetjkid TJ Wrangler Technical Forum 9 02-08-2013 06:49 PM
Move intake temp sensor to the air box? Cobra Jeep YJ Wrangler Technical Forum 5 01-11-2009 11:39 AM
Temp Sensor / Coolant Temp Sending Unit malone_ge YJ Wrangler Technical Forum 1 03-01-2007 09:41 AM
Intake Air Temp Sensor question rgs YJ Wrangler Technical Forum 1 09-30-2006 12:55 PM
