Air Heater Vent Scoop - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > Air Heater Vent Scoop
Attention to the TJ owners 1996-2006 NEW LED LIGHT OPTIONSOPTIC ARMOR WINDOWS all sale now !!!!!!!!FS: 2007-2013 Jeep Wrangler "HALO" Angel Eye Kit
Unread 03-08-2014, 07:46 PM   #1
Semper Fi 03
Do these things really work? I can get one for about $25 but, why spend it on one of those if they don"t really do anything. I live in PA and if that will help the heater then, ok I would buy one. What do you guys think?
Semper Fi 03 is offline   Reply With Quote
Unread 03-09-2014, 08:00 AM   #2
Zeep
Waste of money! Will fill up with snow in the winter, and leaves in the fall. Jeep heaters need no assist.
JEEP THE AR-15 OF THE AUTOMOTIVE WORLD
Zeep is offline   Reply With Quote
Unread 03-09-2014, 08:33 AM   #3
biffgnar
biffgnar's Avatar
If just for HVAC not worth it. If you do cowl intake for engine, maybe something to consider, although note with TJs they are supposedly more efficient with the opening facing the windshield.
Thank you Dave Cole, Dynomax, Falken and all the Spec Class sponsors!!
biffgnar is offline   Reply With Quote
Unread 03-11-2014, 05:59 PM   #4
Semper Fi 03
thanks. I was trying to increase the temp of the heater.
Unread 03-11-2014, 06:01 PM   #5
UTWeezul
I've got Mac's cold air cowl intake and it is setup this way. Doesn't change the HVAC system except for more filtration.
98 TJ
35" MTR Kevlars
TNT Phantom Fenders
PSC full corners and modded 3" flares
4.56s, Aussie front and Detroit rear
Building a HP30...
UTWeezul is offline   Reply With Quote
Unread 03-12-2014, 06:32 AM   #6
JBTJ
Then it will not help. If your temp is not that hot, you may have a partially clogged heater core. TJ's have great heaters. Sometimes I can smell my sneakers burning from the intense heat that come out.
JBTJ is offline   Reply With Quote
Unread 03-12-2014, 06:35 AM   #7
Unlimited04
Read tech links in my sig
Unlimited04's Avatar
either bad thermostat, clogged heater core or you got something else wrong.
a hard top helps keep the heat in, but TJ heaters will burn you out once the engine is warmed up, doesn't matter if it's -20F out.
Unlimited04 is offline   Reply With Quote
Unread 03-12-2014, 07:07 PM   #8
Knuckelhead
AFSOC Retired
Knuckelhead's Avatar
Blend door not working properly?...
TSB Information: http://www.automd.com/tsb/jeep_m/wrangler_mm/2000_y/
Knuckelhead is offline   Reply With Quote
